Blomberg washing machine stuck on rinse. Have tried unplugging and leaving for some time which did work once before but no luck.No operation or door lights.
  • 9 more comments
  • AdrianUK Dec 16, 2008
    Model no. 1503AS Dial states stuck about 7/8 through rinse cycle. Had to drain drum through trap at front. Operation light should be on but all seems dead.
    Door wasn't locked.
    Seems like no power at all to machine. Front loader.
    I thought the idea of this was to avoid calling technicians. Any ideas?
  • AdrianUK Dec 17, 2008
    As there is no power at all is it likely to be the circuit board and can anyone give me an order of which I should check things i.e board, pump, door lock etc
    Have taken top off machine and unplugged as many leads as possible from circuit board. Having a problem taking board out because of attachment to dial and controls on front of machine.
  • AdrianUK Dec 19, 2008
    My machine has no signs of power. It had completely stopped before I touched it to drain off water . This happened once before and after unplugging and leaving ten mins worked again. No luck this time. Can anybody tell me the procedure they would follow to establish the fault please.
  • AdrianUK Dec 20, 2008
    Have taken door lock off. It has three terminals marked 1N 2C 3L. With a continuity meter across all combinations of terminals there is no reading at all. Does this indicate that the lock is faulty or is there something else I should be doing to get a reading? If the lock is faulty and replaced could the timer circuit board also be faulty and how do I test that?
  • AdrianUK Dec 21, 2008
    Can anyone answer my last question please?
    SEEM TO BE GOING BACKWARDS HERE IN TERMS OF ANSWERS.
    Thanks will try a new door lock
  • Washing Mach... Master
  • 3,463 Answers
On the door interlock you have as you say, three wires, to eliminate the door lock, join the 2 wires together that go to L and C , this bypasses the door interlock completely.
If the m/c starts to operate, then it proves the door lock is not functioning, that does not mean to say that it is faulty, but it does prove you have a live feed to the lock,which derives the power from the control unit. the return feed is through the common wire.,you then need to test with a meter whether there is a neutral feed to the lock. to do this put your meter on mains voltage range
240volts, and test across L and N, you should get a mains voltage reading, if you do not then you have no neutral feed to your door lock.
This being the case, then I
Posted on Dec 20, 2008
  • Barry Coates
    Barry Coates Dec 20, 2008
    I don't know what happened there, but as I was saying this being the case, then I would say the control unit is faulty., because this is where the neutral feed originates..
    If the m/c does not start after bypassing the door lock, then obviously you are getting no supply to it from the control unit., which is most likely to be the cause of your problem., you can then trace the neutral feed back to its origin.
    I am giving you this advice on the assumption that you are competent to use a meter, and know what you are doing.
    Electricity is a silent killer.
    Plz rate my advice to solving this problem.
    Thanks, and merry xmas.
    Guru:
  • 449 Answers
Whatever happens, don’t go fixing a broken washing machine by yourself. A repairman ought to do that job. You may, however, perform these basic operating checks:
  • If the washing machine doesn’t turn on, check the cord, the plug, and the outlet. Sometimes the cord wears off and you’re going to have to replace it.
  • Check the fuses and the circuit breaker. Who knows, it might just be a household electrical problem, totally unrelated to your washing machine.
  • Some washing machines are installed with a safety feature in that it won’t spin until the lid is properly closed.
Remember these things before calling the repair man over, or the joke’s on you.good luck
    Genius:
  • 2,920 Answers
It sounds like you need to replace the control panel
  • 199 Answers
There are only few reasons why "no power at all":
  • circuit breaker tripped
  • plug/fuse defective
  • open AC cord
  • any of door switches open or will not engaged
  • transformer for low voltage control/secondary circuit faulty
  • controller circuit board faulty.
please check if there is a wiring diagram inside the panel below the door. use a voltmeter or ohmmeter to check voltages and continuity of wiring and parts.
hope this helps.
Posted on Dec 19, 2008
  • Bernie Role
    Bernie Role Dec 21, 2008
    1. when switch is not pressed or engaged, two terminals should read 0 ohms;
    2. when switch is pressed, the opposite pair of terminals should read 0 while the original pair should read no continuity.
    hope this helps.
    Sergeant:
  • 306 Answers
I had a the silmilar pob once in my machine. it was corrected by the technician wher he found out that only the wire at the backside-down of washer is of loosely connected.. and he tightened it..prob solved..        if not Check the pressure switch -the system that determines correct water level in the drum. Its a round item about 3 inches across with several wires connected, it sits under the top cover. Its an air operated switch which tells the machine water has reached the correct level. Disconnect the thin rubber pipe from the switch and blow down through it to clear any blockage. Switch itself may be faulty but its more likely the pipe is blocked.
Also check the filter - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction. Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Remove the back cover, locate hose, remove the tensioner clip by squeezing the tabs together, remove the hose, take out filter and clean.
Posted on Dec 17, 2008
  • AbdulRahiman S Dec 17, 2008
    if there s no power comin then sure the prob s wit the wires either main wire or inside wires.. and its loose connection..try to chek out tat
  • AbdulRahiman S Dec 21, 2008
    dont forget to rate it.. good luck!!
  • 19,396 Answers
If there is no power getting to the panel, then that means that when you accessed the trap, you either caused a short or a broken circuit.
Check the house circuit breaker for the appliance
Test a different AC socket.
If power cor is fused (like in UK) check the fuse on power cord.
If none of the above fixed it, then there is a lose wiring inside the machine, and the machine must be taken apart to fix the problem, in that case you will need a tech.
Always unplug the machine when you do repairs.
You can find machine diagrams by entering model number here.
  • Ginko
    Ginko Dec 19, 2008
    It is useless running around the problem like this , times and times again. The problem is simple, it is just that to fix some fault you need to be a technician , or you need to call a technician.
    When the fault is not an user level repair, a DIY fix can endanger your goods and your life.
    Regartding the Fix:
    If machine is not starting at all is either a defective circuit board (they have a fuse on it ) , o r a short on wiring the caused now broken contact.
    This is an easy fix for a technician, but should not be repaired by the user.
    The first thing to do is checking if there is power to the board.
    The repairman test the appliance with live power in.
    The user instead MUST NOT perform any testing operation with live power in.
    I quote from your last your comment :
    "This happened once before and after unplugging and leaving ten mins worked again."
    That was because the problem was due to accumulation of electrostatic charges on the TV capacitors. By unplugging and draining out power, the appliance restarted working.
    "No luck this time"
    This time it is a blown capacitor or fuse, either the board or the single component must be replaced.
    "Can anybody tell me the procedure they would follow to establish the fault please."
    Sure, access the control board assembly, test voltages in, there is no voltage find the broken contact, if there is voltage, replace control assembly or find faulty component.As mentioned this should be done by a technician.
    I suggest instead to test the fuse on the control board, and to visually inspect the control board with power UNPLUGGED.
    If you read (using a multimeter) that the fuse has blown, replace it, if you find a bulged capacitor, replace the board. This kind of repairs must still be done by a technician.
  • 112 Answers
Well come sir
that prblem you have ask to fixya
is very simple
it is totally linked to a short sarket you should have to repairer from a good are near you elctrtion
who can solve your problem
if you wants to solve its your self.maybe you have to makes new problem
  • 827 Answers
Hey there mate,
There might be a switch to enable a second rinse cycle, which is set to the OFF position. This will forward it to the "extra rinse" portion of the cycle and spin out the rinse water.
Otherwise, it is getting stuck because the timer assembly is seizing in some way. It could be the washers, the bearing etc. If you were to do a small wash, and then take out the whole timer assembly and take it apart, you will probably find that the timer motor is quite hot to the touch. You could order a new timer assembly for the model. That should stop it sticking in mid-cycle. But that can be pretty expensive as you can see from the link below, the timer motor is a hefty amount and the entire timer assembly is even more expensive than that. A new machine might even actually be worth considering, as the timer assembly unit, alone, could set you back at least £250
http://www.espares.co.uk/parts/washing-machines/blomberg/1503as/p/1085/165/0/396525?page=2
But first see if the model does have a second rinse portion to the cycle and make sure it is switched on. Worth a try before you order any parts, or end up buying another washing machine!!!
Good luck with that and Happy holidays from myself and all at Fixya!
Chris (ziraffa)
    Sergeant:
    Champion:
  • 247 Answers
I would myself check the motherboard first and then trace my steps forward that you know what has power and what doesn't
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, may I offer a possibility? The unit is waiting for the completion of a cycle, could it be drain? Have you tried cleaning the filter, drain sump, drain valve, impeller, pump drain hose? Although of course it is a messy job.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 19, 2008
    Hi again and appreciate the update,
    The technically correct procedure for a completely dead appliance is to check for the presence of the supply voltage and determine at which point it stops.
  • Louie  Role
    Louie Role Dec 21, 2008
    Hi again,
    Offhand:
    • the door switch is faulty. It is one of the most used/abused part since it activates/deactivates every time the door is opened. Of the 3 terminals, at least a pair should read a continuity on the engaged position, looses it when disengaged but the other pair would by then have continuity (most likely);
    • the time is likely to be good. Although of course the possibility is till there;
    • in most designs, there are two (2) door switches, one goes to the control board, the other cuts off the main supply to the entire unit.
    Cheers.
  • 275 Answers
Sonds like a programming issue rather than a mechanical one, since it's stuck on a cycle and would not move forward from that. You will need a technician to come see it for you and see it they can reprogram it for you.
Posted on Dec 16, 2008
  • Alan R
    Alan R Dec 16, 2008
    No power at all? so you cannot change anything on the control pannel?
    Sergeant:
    Novelist:
  • 327 Answers
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • classyexpert Dec 16, 2008
    f your washer doesn't seem to work at all, check these:
    No power
    Lid switch
    No power
    Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
    Lid switch
    If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
    Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
  • 113 Answers
A good idea to check that the pump is not clogged. If the washer goes into rinse and than trys to drain but cant. It will shut down and usully lock the door. Im assuming this is a front load washer. thanks Dave www.washermd.com
  • 1 more comment
  • Dave Dec 16, 2008
    Its filling with water, agitating, but when it goes to rinse and spin it stops. No spin at all correct? If its a cold water rinse but isnt getting the cold water due to a bad water valve on the washer or the cold water on the house turned off, it will stop and either give you an error code or simply turn off. Check to see that the cold wate is indeed on and working, no clogs in the screens. Next try switching to a warm water rinse and see if that works. Also the washer needs to verify the door is locked before spinning, listen to hear if the door makes a clicking noise to lock.Do you have a way of testing voltage like a voltmeter? We can test to see if the pump is working. Still can very well just be clogged. Let me know..thanks
  • Dave Dec 16, 2008
    You cant reprogram these machines. Its simply replace. If your getting no power to the panel. First look for the obvious. Is the panel locked, thier should be a button that says panel or control lock on it. Not door lock. Hold this button when u find it for 5 seconds, it will unlock. Also check the outlet make sure of no tripped fuses, make sure your getting proper voltage to the washer. Last of all if your getting no power, you have a bad control panel and need to replace the panel. Especially if youve been able to pull the power before and plug it back in and have it work, Thats a sign of that board going bad. Be sure to check all connections to the board , make sure nothings loose, unplug it before you do this. dave
  • Dave Dec 16, 2008
    Theres nothing else on this machine (that I know of anyway) that will cause no power to the board, not a pump, not a motor, not a door switch. Only the board itself, or t he power supply.
  • 734 Answers
What is the model number of your machine?
  • futureloginn
    futureloginn Dec 16, 2008
    First let me know whether the machine gets stucked after completing the rinse or it doesn’t at all because if it gets stucked after completing the rinse cycle then there is a problem with spin motor.
Smelly washing machine
Hi Haydn.
One of the main reasons for smelly machines is because the door is left closed and mould is growing in the drum and door seal.
Using some chlorine bleach will help. Put some in the drum and do a 'Rinse & spin'.
Leaving the door slightly ajar will allow the drum to dry and it will also allow the rubber seal to relax, thus maintaining a good contact with the glass when in use.
Once it's established mould can be difficult to get rid of entirely.
Good luck.
Nomess
Jan 11, 2015 | Bosch Washing Machines
Error code 1000 on blomberg washer
We found a way to reset the computer and solved the problem.
1. Press and hold pause turn off machine and turn back on holding pause all the while.
2. This should reset the computer. All lights will light up on LCD display.
3. Release pause button. Turn off machine, turn back on and begin a new wash cycle.
woo hoo!
Apr 08, 2013 | Blomberg WM87120 24" Front-Load Washer...
How to reset my washing machine blomberg
you cannot reset it anyway its NOT that, you have a door sensor fault most likely or a MCU problem look get a service manual and follow that.
Mar 10, 2012 | Blomberg Washing Machines
There is a moldy smell....I have ran a load with no clothes and just bleach and it smelled ok for a week and now smells again
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub/basket, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Oct 24, 2009 | GE WSXH208A Front Load Washer
Can't interrupt the washing cycle on coin operated Mah21pddww
Unplug the washer, wait three minutes for the door to unlock then do what you need and plug it back in. Should still have the time left on it that was there when you unplugged it.
Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
Dead Washing machine
seems issue with the control panel. try unpluge the unit and pluge back after 10 min and chk.
Aug 12, 2008 | Washing Machines
My washing machine door wont open
Sorry for VERY late solution. I have an LG front loader machine and it has just broken. While surfing the internet, I found your blog. LG front loaders have a weak door handle, that breaks after a few years of operation. All the LG models seem to be the same. Replacement door handles are relatively inexpensive and readily available.To open your STUCK door, I would use a thin butter knife....slide the butter knife between the door and the frame of the machine until you hit the metal latch. Push the latch towards the centre of the machine and open the door.In the interim until you can get it fixed, this workaround method will work, enabling you to continue washing.Hopefully LG will make future models door handles out of cast, or something stronger!
Jul 29, 2006 | LG WD-1080FD Front Load Washer
Washing Machines Logo
472 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
