Hp Pavillion 5000 notebook
My hp laptop is having a bad day, we use this for business. It comes on and goes to the different type modes, I have tried safe mode all the way down to select last known working one and neither of them work, it rolls to another screen and shows the windows xp logo and gets caught in a "loop" reverting back to the mode screen again. Help.. Thanks in advance for any feedback. my laptop wont boot up pass windows xp logo it keeps restarting at the same screen
    Sergeant:
  • 324 Answers
Bad day, huh? Here area couple of quick and easy things to try that may fix your problem. Then again, they may not,but it never hurts to try!
Step1
1) Take out your laptop battery.
2) Remove your AC power cord, that's the wall power, removeit.
3) Now hold down your poser button for at least 30 seconds.
That will drain any static electricity that has builtup on your laptop system board and many times fixes the problem of ablack screen. After the 30 seconds re-connect your laptop to the wall power andhit the power button normally and see if the laptop comes back up. Reinsertyour battery.
If that doesn't resolve the situation try step 2
Step 2 Bad memory Your memory (RAM) may need to be removed, andthen put back in (reseated). The videoshares the system's memory, and will not function if there is a problem.
1) Reseatmodule(s).
2) Swapmodule, preferably with known good.
Hope this helps the situation and makes your day go better!
Ron
Posted on Dec 16, 2008
MY HP PAVILLION 6262 LAPTOP WONT POWER UP, LIGHTS COME ON FAN STARTS, BLACK SCREEN. GOES OF AND TRIES TO START AGAIN AFTER A FEW SECONDS. HARD DRIVE, MEMORY AND SCREEN ALL CHECK OUT OK. IT ALL STARTED WHEN...
see if you can boot into safe mode as the pc starts tap F8 - should be presented with a menu - choose "safe mode" from the menu if that works, then try a system restore to before the problem started start>programs>accessories>system tools>system restore choose a date before the problem started
reboot
Mar 24, 2010 | HP Pavillion DV6227 Notebook
HP Pavillion dv2500 laptop will not boot up.
Pressing the f8 key doesn't work either? This should boot the laptop to safe mode, if it doesn't then check the memory cards before you do anything else, try to get somebody with the same type of memory card to lend it to you. If that doesn't work, then your HDD is corrupted, and to re-install Windows.
Sep 05, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavillion zx 5000 screen black
GO ON LINE AND TYPE THE MFG NAME, MAKE, MODEL, SCREEN WENT BLACK.
ENTER
ROD
May 12, 2009 | HP Pavilion dv6000z Notebook
two things possibly, first, the cmos battery is flat causing cycling reboots, or you need to press and hold the power button while its booting up to turn it off to bring it out of restart
Aug 18, 2008 | HP Pavilion dv8000t Notebook
Ive reboot my laptap hp pavillion zv 5000 but sound doent work
i agree with exon33 as long as you are useing realtec you can do that anything else and you better off using the disks that came with it
Apr 21, 2008 | HP Pavillion ZV6000 Notebook
Hp pavillion zv6000 white screen on startup
bad video maby bad ram bad screen one of them or bad power chips on mobo worse case
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
HP Pavillion dv 5000
have you recently loaded any new hardware or software to the system.  if so... this may be the source of the problem.  you would want to load in safe mode and remove whatever you changed.  that would then fix the problem.  i wouldn't jump to the conclusion that your operating system is corrupt just yet.  it sounds as though it is doing exactly what it should when it comes upon a conflict in the system.
Dec 21, 2007 | HP Pavilion dv4000 Notebook
Hp pavillion trying to boot from dos mode
This is a common HP laptop problem.
Please try these steps, if they dont work you will have to do a restore.
Please let me know how you make out.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372724&cc=us&lc=en&dlc=en&product=1137817&dlc=en&lang=en
Dec 08, 2007 | HP Pavilion zd8000 Notebook
HP Pavillion dv6000 Vista notebook crashes when entering sleep mode
This is a common problem with HP Pavilion laptops, including mine. Check and make sure there are no non-OS programs running that are trying to control power settings (like a power monitor program running in the system/task tray) and then turning of hibernation in the POWER SETTINGS and then for all "WHEN I CLOSE LID" and "WHEN I PUSH THE SLEEP BUTTON" and "WHEN I PUSH THE POWER BUTTON" select DO NOTHING, then APPLY. Then SAVE SCHEME AS and choose any new name. This will disable all sleep modes forever, but at least you can get on with normal use.
If you are geeky, try going into the BIOS and DISABLING anything marked WAKE ON, and disabling anything having to do with automatic power features, and then try hibernating and so forth normally through the OS again. Sometimes this works if there are conflicting settings in the BIOS also trying to increase power efficiency.
Good luck...
Nov 08, 2007 | Computers & Internet
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
