Question about Sony FD Trinitron WEGA KV-20FS100 20" TV
Dead from cable surge from blown Time Warner splitter.
Techman was helping me, but he logged out. I have the TV open, and found from the repair manual that there's a F601 fuse that could be the culprit, but I can't find it. Is that a standard glass fuse or something else?
    President:
  • 1,284 Answers
On that Sony the only glass fuse would be on the primary side where the A.C. cord enters the TV. If it's blown then you have a bad rectifier diode or some other shorted power supply component.
Posted on Mar 22, 2007
SOURCE:
My 32 incn Hisense Roku tv can I hook it up to my time warner cable instead of wireless connection
Yes, you can. You would need to hook the cable box up to the tv using an HDMI cable for it to work. Hope it helped!
Jan 08, 2017 | Optics
Why don't DVDs show on TV?
From your description, my guess is that your DVD player is not connected to your TV.
Mar 11, 2016 | Televison & Video
Missing link between DSL Cable and D-Link Systems HD Media Router 1000 (DIR-657)
What is the Time Warner modem? Make, Model? If you have a Ethernet port RJ45 connect the wireless device via a ethernet cable. You may need a splitter if there is only one Ethernet RJ45 port. Example: http://www.amazon.com/StarTech-RJ45-Splitter-Cable-Adapter/dp/B00009XSZE
Apr 24, 2013 | D-Link Computers & Internet
Modem
Your connections are screwed up. Call your cable company for help in getting you straightened out.
Apr 24, 2017 | Telebit Refurbished OPEN BOX EXTERNAL...
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Vizio tv freezing up
You're not getting enough signal to your cable box. You most likely have too many splitters on your cables and or your cable is not hooked up close enough to a line. Your cable guy will probably need to come out and string out a new cable line from the telephone wire, to your house, to your TV. It's typically a free service with most cable companies (at least Time Warner).
Nov 12, 2009 | Vizio L37 Television
Wii hook up to time warner cable box with a dvd
I needed another part... an RCA cable splitter to put two cables into the same TV connection.
Nov 09, 2009 | RCA Televison & Video
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Codes to make my Time warner remote control the tv
Here's the list from Time Warner
http://www.timewarnercable.com/Carolinas/site.faqs/Equipmenta/Remotes/Digital-Remote-TV-Codes
Oct 26, 2007 | Toshiba 36A50 36" TV
Sony FD Trinitron WEGA KV-20FS100 20" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
