Question about Amana ARGS7650SS Gas Kitchen Range
Gas smell i can smell gas coming from the regulator i beleive i checked the lines with soapy water no leak im pretty sure it is coming from the small hole in the orfice.
    Scholar:
  • 33 Answers
Dear Kgeibel,
The orifice is basically a small nut with a very small hole in it. This small hole lets all the gas into the grill. If it is blocked or has leakage in any way (dirt, cobwebs, spiders, etc.) it must be cleaned out. To access the orifice you must unscrew the gas valve from the burner. On models with an igniter, you must first remove the four screws holding the control panel on before you can unscrew the gas valve. Once you have access to the gas valve, remove the regulator hose. It's a good idea to use two wrenches to do this. Grasp the flat part of the gas valve with one wrench and hold it tightly. With the other wrench, remove the regulator hose. Then, loosen the flat lock nut located at the end of the valve next to the air shutter. Once loosened, you can unscrew the entire gas valve from the neck of the burner. (The air shutter and bug screen will also come off when you unscrew the gas valve.) With an adjustable wrench, unscrew the orifice from the gas valve and hold it up in the air to view any possible obstructions. Run a broom straw or some other small rod through the orifice to make sure it is clean. BE CAREFUL not to do anything to make the hole in the orifice bigger.
please rate this solution.Thank You Kgeibel
Posted on Dec 16, 2008
What would cause a gas smell around a safety valve
IF you believe there is a serious leak get out and call the fire department. If not you can use soapy water in a spray bottle to check for leaks. Note that some regulators have small releases of gas when the diaphragm moves and this is normal.
Mar 17, 2016 | Kitchen Ranges
Weber grill replaced hose because of faulty regulator had smelled gas and low cook temp. grill is 4 to 5 yrs old. Connected new hose did soapy water thing no leaks at hose connects. Still smell gas when...
Lisa, when you conducted the soapy water test, how long did you leave the soapy water on each fitting, before you determined there were no leaks? Sometimes, it can take 5 minutes or more for a leak to show up. You should also soap text the tank valve itself.
If no burners were ON when you tested for leaks (and apparently didn't find any), the problem still lies in the Hose/Regulator assembly connections or the tank valve, When you test the tank valve, do it after the valve has been opened very, very slowly (Slow motion, slow).
Hope this helped you to further troubleshoot and solve the problem
Jul 11, 2011 | Weber Genesis Silver B Grill
My charbroil masterflame 7000 is leaking gas. I beleive I need to replace the regulator and hose. Please advise on how to get the old hose off and put the new hose on. I need a diagram if possible. I would...
If you have already disconnected the hose from the tank. Track it back to where it connects to the burner(s) manifold. It should be up under the grill head. You should see a brass nut. Using an appropriately sized open end wrench, loosen this nut and the hose will disconnect from the grill.
The new Hose/Regulator Assembly will simply attach in the reverse order of how you removed the faulty one. After installing the new one and connecting the hose to the tank. Open the valve on the tank about halfway and check the connections for leaks. Thick soapy water, brushed on with a paint brush will work for detecting leaks. Look for bubbles other than those made by the soapy water. If you see one, tighten the connection a bit more. Be sure not to cross thread the nut, when installing it.
If you haven't purchase a new one yet, you can the Hose/regulator Assembly at any home center or hardware store that sell gas grills and accessories. They run about $30.00.
Hope this helped you and Happy Grilling.
Jun 19, 2011 | Char-Broil CharBroil Master Flame Gas...
Is it normal to get a faint gas smell when you hook up you'r gas dryer?
Absolutely. Your dryer runs on gas, and the gas kicks on when the heating element engages. It should be so faint though. If you smell it continuously then check your connections with soapy water, if their is a leak then shut off the gas and try using soap pipe dope, or teflon tape on the threads, then recheck. My guess is its the regulator near the heating element. Good luck
Feb 21, 2011 | Kenmore 77632 Gas Dryer
Small gas leak smelled inside house from GE Adora (just 2 yrs old). Have moved stove and have put soapy water with paint brush on every connection including regulator...don't see any leak evidence...any...
You may have to use dish soap straight, do not use the brush. I use an old spray bottle and dish soap straight, not watered down, to find my leaks. Gas is a very low psi. Soapy water will not bubble up. It can and will just be pushed out of the way. Do not forget any other gas appliances in the house, hot water heater, stove, any thing that uses gas. Please check all. Recheck your stove and even any connections inside, on/off valve etc. Hope this helps Fixya up.
Dec 13, 2010 | Microwave Ovens
Everything hooked up but smells like gas. Checked line with soapy water mix. No leaks. What's wrong?
If everything is hooked up and you still smell gas you still have a leak. The gas valve could be letting out gas if the burner is not igniting, however it sounds like you have a small leak on your line which will not be detected by just soapy water. You need to go to a hardware store or a place like home depot and get what's called MegaBubble Leak Detector or a similar brand of leak detector. What this stuff is designed to do is bubble up with massive bubbles where your leak is and it will detect even the smallest leak. If there is no large bubbles there is no leak. Don't be afraid to over do it when putting this stuff on the pipe.
May 10, 2010 | Kenmore 74602 Gas Dryer
We just replaced the propane gas line. Our stove is gas and it lights, but neither of our gas water heaters will light. Both water heaters are new and have been working for about 4 months before the...
You have to purge the air from the lines.
At the water heater, take a wrench and loosen the gas line until you smell gas coming from the line. Then tighten the gas line. Check it for leaks with a soapy water solution. Let the gas smell clear, then light the pilot on the heater.
May 25, 2009 | Heating & Cooling
Smelling Gas and Soot in Oven
well its pretty normal u will smell gas when its preheating but if u think its not then u can pull the oven out and check the gas line connection is tight if it is then u can also get a spray bottle of soapy water and spray the whole line and if u see alot of bubbles then there is ur leak and for the soot problem u can use the clean cycle which all it does is reach a very high temp and pretty much burns everything like crumbs to a crisp and all u have to do is basically wipe it out with a damp cloth and maybe a mild soap and sponge good luck
May 18, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Oven - Very bad gas smell
Very Dangerous! turn off supply to appliance, supply ventalation and call service tech. If you are very familiar with gas appliances and know what you are doing then you can try to locate the leak using soapy water or leak detector liquid. make sure all flames and other possible sources of ignition have been eliminated. Keep room well ventilated. Spray leack detector on all fittings and look for leaks replace or tighten parts as needed. This responce is asuming you have not blown up already, seriously dangerous situation you have there.
Jan 07, 2009 | Ovens
Amana ARGS7650SS Gas Kitchen Range Logo
160 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
