Question about Dell Inspiron 630M Notebook
Internal and wireless NIC missing from device manager
I recently reinstalled XP Pro after having problems removing trojan.dnschanger. I had to make a slipstream with sp2 disk because the only XP Pro disk we had was the oldest version. I downloaded all the drivers from the Dell website so everything would be up-to-date. There are no unknown devices in the device manager and reinstalling/reseating the wireless card did not help. Any suggestions?
  • ashleygonzal Dec 16, 2008
    Thanks for the suggestion! Already did that. It didn't work. I even installed another wireless card and didn't get any recognition from the device manager. It's as if the motherboard is bad but everything else is working properly.
  • 679 Answers
Yes try this, go into device manager, start,control panel, system, hardwar, device manager
and uninstall the card, reboot, it should tell you it found new hardware and if you have the proper software installed, it will say it is installing the software for your device, try this first as it will reinstall it as long as the software is there, or you can at that point install from disk,
Posted on Dec 16, 2008
  • George Bill
    George Bill Dec 16, 2008
    Did you try manualy reinstalling the nic in "add Hardware", it will give you the option in there to install it manually, just pick "all hardware", then scroll down and see if your card id there, if not select the spcific card from the ones given, if it is not there, it will ask for a disk, reinstall it, now restart and see if it is in the device mgr, peace
  • George Bill
    is it still not seeing the card?. I really would like to get this fixed for you, as I know how frustrating something lije this can be. I spen several hours with a similar problem last week on a budies machine. It ended up that the same device was installed several times, once I realised it was that, I just deleted the duplicates and bingo, it went right on. I'll help you for free, fo a while until I get another call, is it showing in Device mgr. and if so how many ethernet decices and modems is it showing, it may have it installed in a different place or under another name. Also I am sure you checked this, but, are the drivers current and is it showing the "irq" thar it is on. And just to throw out ideas, for you, does it have to be enabled from the Bios?
How do I fix the dcom server launcher, the computer keeps shutting down after it's been on for about five minutes?
Click Here to Download this program (its free). Install it. Update it. Run a FULL scan of your computer (took about 30 minutes and the viruses didn't pop up until the very end of the scan). Delete ALL of them (note: you have to reboot to delete the ones in windows system 32) There will be a list of about 5-10 infections they should be similar to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\tdssdata (Trojan.Agent)
HKEY_LOCAL_MACHINE\SOFTWARE\tdss (Trojan.Agent)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
C:\WINDOWS\system32\tdssadw.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssl.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssserf.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssmain.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssinit.dll (Trojan.Agent)
C:\WINDOWS\system32\tdsslog.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssservers.dat (Trojan.Agent)
C:\WINDOWS\system32\drivers\tdssserv.sys (Trojan.Agent)
Thanks for using Fixya!
Jan 31, 2010 | Computers & Internet
Acer Travelmate 2300 and wireless
Uninstalled all the driver you have right now
Try finding the model # of your wireless card and find the specific driver for it, It would resolve the problem
May 30, 2009 | Acer TravelMate 2300 Notebook
Cd burner not being recongnized
XP provides buring software for CD-ROMs
First check device manager to make sure CD-ROM is listed. If it is listed, try to use XP to write files to the CD.
Norton should not have affected the CD writing capabilities.
If you cannot write to the CD, use device manager to remove the CD-ROM, and then restart your computer. New Hardware utility will reinstall the required software
Apr 15, 2009 | Computers & Internet
XP won't boot without IBM 10/100 EtherJet NIC
Check the BIOS to make sure the machine is not trying to boot off of the network card (PXE boot) and make the hdd in question the primary boot device.
Feb 26, 2009 | Computers & Internet
Internal Wireless card will not activate
Most likely you need to install the driver for the NIC card. Go to Device Manger under System Properties and see if the Wireless NIC is showing a driver error. If so right click, select Update Driver and navigate the the file on the CD. Once the driver is installed if should function normally.
Dec 23, 2008 | Dell Inspiron 6000 Notebook
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Internal Wireless Adapter for eee 900 device not listed
try Fn+F2 to enable the wireless.
As for the multiple entries in device manager, I'd delete the #2 version
Jul 03, 2008 | Computers & Internet
Can not connect to the internet through a wireless connection after installing windows xp and removing good operating system
Hi vsecrets,
need a little bit more information from you. First off, is your laptop 'seeing' the wireless card? I need you to check the device manager to see to see if there's a yellow exclamation point by the NIC and to check the driver version for it. If the driver IS missing, you need to go the manufacturer's site and download it. If it is there, still make sure there isn'[t a newer version. Let us know what you find.
Apr 19, 2008 | Computers & Internet
Clean XP Pro installed -- now NIC disappeared!
Well once you did a clean install over all of Dell drivers etc etc. You wiped out the restore artion that was on the computer. You have to go to Dells website and under the support tab look for the Nic card that you have inside the computer.
Feb 08, 2008 | Dell Latitude C610 Notebook
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Dell Inspiron 630M Notebook Logo
197 people viewed this question
Alun Cox
