Question about Motorola Mobility RAZR V3c Cellular Phone
My razr wont charge tried new battery, cleaned ports etc.!
Mr razr just wont charge bought different chargers, new battery, and cleaned ports...motorola knows they aint right!!!
    Brigadier General:
  • 7,752 Answers
The usb port needs to be replaced on the phone
Posted on Dec 27, 2008
When ever i try to charge my phone it wont charge. I brought a new charger and new battery still wont charge
Hello there,
Have a nice day.
You have mentioned the you have bought a new charger and a new battery but still your handset wont charge.
The problem is from the charging port on your phone. You will need to change or replace the charging port on your phone to fix the problem.
Try to take your phone to any Sanyo service center or any local phone repairer to help you replace the charging port, it has a minimum charge only.
Hope it helps,
Thank you for using the fixya.
Sep 12, 2011 | Sanyo Incognito 6760
Trouble charching battery, after 6 houres only one bar on battery . Charging will not complete.
1 charger
3.charging port
There are three ares to look at,
There are three different things you can try to determine the real problem of your phone, firstly, try use a similar charger to charge the phone to see if it will hold charge, if it does, it means your charger is bad, get a new charger. secondly, another area you will need to look at is removing the battery on your phone and charging the battery of your phone with a similar phone to see if the phone will charge the battery and hold charge, if it did not, it means the battery of your phone is bad and will need to be replace, lastlt, check, the charging port of your phone might be malfunctioning and not charging your phone, if the two above look good, it means the charging port is the problem, replace the charging port and you will see that your phone will hold charge.
Take care.
Jul 05, 2010 | Motorola Mobility RAZR V3
Charging problem - battery?
Try an Antec charger with an adjustable votage output. I tried a new battery, charger, BIOS udate, etc, etc, etc. After fighting it for about 2 months, I found the Antec at Best Buy. Took it home, plugged it in, slid the adjuster up till the "charge" light came on. Been working fine for about 6 months.
Dec 27, 2009 | Fujitsu Computers & Internet
If you tried to make a charger you could have damaged the Pinout or even the charging port on the phone however 99% of the time this common error with razrs is fixed by trying a different battery and or a different charger.
Jan 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Power on Problems
Sounds like your battery is dead. Does the phone respond when you plug in the charger? If it does not respond, you may either have damage in the charging port, or a bad charger. If the phone recognizes the charger, shows that it is charging, but still won't work when you unplug it, I would recommend trying a new battery. You should be able to go to a retail store that sells razr's and ask them to try a different battery in the phone to see if it works. If it powers on with the new battery, buy it.
Sep 18, 2008 | Motorola Mobility RAZR V3
Razr V3 won't power up anymore
try a new battery and also clean the charging port if after the battery and still nothing then you need to take the phone and have it tested.
Sep 10, 2008 | Motorola Mobility RAZR V3
No power
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Jul 08, 2008 | T-Mobile MDA
Motorola V3 RAZR won't charge!!!
hmm well i suppose u try with a new charger 1,, b4 you throw it away
Feb 05, 2008 | Motorola Mobility RAZR V3
its your phone. i had that same problem so i just got a new one and then the new one didnt work either so i got a different model
Jan 29, 2008 | Motorola Mobility RAZR V3
V3 Razr is dead, wont charge
take it to a local cell phone dealer and see what they say. most likley bad charger or bad connections.
Jul 08, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3c Cellular Phone Logo
90 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
