Question about Lexmark X4270 All-In-One InkJet Printer
I keep getting a message about usb port missing
I keep getting a message that my computer is not communicating with my printer. Somethign about the usb port?
I have been using the printer for almost a year, and this never happened begore.
    Novelist:
  • 59 Answers
Hi hbailey10,
It sounds to me as though the USB port simply got reset and so it isn't communicating both ways (this can sometimes happen if you plug in or unplug a difference device in a nearby USB port). Here is my advice:
1) Try disconnecting the USB cable from your computer, wait 10 seconds, and then plug it back in.
2) If you still get the same error messagem then the problem is software-related, not hardware-related. You might try uninstalling and re-installing the driver for the printer. In the event that you don't have the disk from your printer handy, you can download the driver from the following web address:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
If you still receive an error message, try to get the exact wording that we can figure out what's causing it.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Posted on Dec 16, 2008
Just installed a 1200 all in one HP printer and it goes through the motions of printing but nothing is on the paper, i have deleted, reinstalled, check every setting possible, done everything that the...
Many a times the cartridges get empty.There is ink in the cartridges,this ink gets over or many a times dried up.Remove the cartridges and see.There will be a steel color nozzle at the base of cartridge,from where the ink comes out.Touch the tissue paper to that base and see,if there is ink coming out.Actually the ink should come out.There will be two cartridges in the printer.One black and one tri-color.On black cartridge when you touch the tissue paper you will get black ink on tissue.On tri-color cartridge when you touch tissue on its base you will get three colors,that are yellow--- blue and pink.( In printer language its called cyan--- yellow---magenta color).If there is ink in the cartridge then it should print,If you have replace the cartridge,then on its base there is a blue color tape.That tape has to be removed from its base.If the tape is not removed the cartridge will not print.-------- One more thing.Before doing any thing.Just do a self test and see if the cartridges are working. The procedure of self test is as follows:--- " 1) Turn the printer on.2) The power on green light should be steady green,not blinking green. 3) When its steady green at that time.Press the cancel and color button both together. 4) By doing this the green light will flash,and printer will take the paper. 5) On that paper the self test will get printed.But if the printer takes the paper and it comes out empty /blank then its cartridge fault.But if the self test is getting printed,then yes its confirmed that there is communication fault between printer and computer.In this case,replace the usb wire.Try new brand usb wire and see if that is helping.One more thing.When you install the printer driver.At that time never keep the usb wire connected between printer and computer.Only keep one side of usb connected to computer tower.In between the installation procedure.The message will come up on your computer screen" this message reads,connect the usb wire to printer.At that time connect the usb wire".As you connect the usb wire the message will come up on your computer screen.The printer is detected.If this message comes up then only your printer will work.If this message does not comes then,there is any of the three things faulty,that is usb wire,the usb port on printer side or usb port on computer side.If usb wire is faulty you can replace this wire with new and check.Its not a costly wire.But if any of the ports are faulty,then this ports are internally soldered on the main board.This ports needs to be re-soldered.This can be done by any printer/computer repair tech.Its hardly a 10 minute job to re-solder loose usb port. ------------- Try this troubleshooting procedure.This will help. Thanks.Helpmech.
Jan 27, 2011 | HP PSC 1210v All-In-One InkJet Printer
Keep getting the error message "Printer not responding".
How are you connecting the printer to the computer? (USB, parallel, ethernet) Make sure there are no error messages/lights blinking and that the unit is on.
If you are using an USB cable, try a new cable. Also try a direct connection if you have a USB hub or print server in use. Make sure the USB ports are active (not disabled for power saving or security). Test the port with a known working device.
If you are using the parallel cable, make sure it is properly secured. Also try a new cable. Again try a direct connection instead of a print server.
If you are using an ethernet connection, again try a new cable. Check if your firewall is blocking communication with the printer. (Test this by temporarily turning off the firewall. If it starts working, make the printer a trusted part of the network. With some firewalls, you may need to unblock communication for both incoming and outgoing communication with the printer.)
I hope this helps.
Oct 18, 2010 | Konica Minolta Magicolor 5450 Printer
Printer unable to communicate with computer.
Are you using the wireless network printer function or is the printer connected by a USB cable? If you are using the wireless network, launch the printer's Wireless Setup Utility and run through it. (Check for problems with IP, signal strength etc.)
For USB, try resetting the printer (unplug it from the wall for 10 seconds). Check that the computer is looking for the printer on the correct port. Click Start > Settings > Control Panel. Double click on the Printers folder and right click on your Lexmark printer. Choose Properties then click on the Ports tab. Check that one of the USB port options is checked. (If you have a newer OS, Start > Devices and Printers and then right click on the printer.) Also try a new USB cable and a different USB port. If you have a print server or USB hub, try a direct connection.
I hope this helps.
Apr 22, 2010 | Lexmark X3350 All-In-One InkJet Printer
Communication Error
yes may be try with diffrent cable and other usb port.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 06, 2010 | Dell 924 All-in-One InkJet Printer
Lexmark x3470 message "printer cartridge missing"
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Lexmark Z735 InkJet Printer
I just put new ink Cartridges but still wont print
Most of the time the "problem communicating with the printer" message pops up on Lexmark X1185 series when the driver gets corrupted. The best fix for this issue would be to uninstall the software first. Try connecting the USB to a different USB port (Please avoid using USB hubs, if any) and then reinstall the software. This should normally fix the printer communication issues!
Good Luck
Dec 12, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer cannot communicate with the computer
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Sep 10, 2008 | Lexmark Z735 InkJet Printer
Unable to print
To fix a fouled install :
(7) When the sofware asks for the printer connect it and continue
Sep 07, 2008 | Lexmark X73 All-In-One InkJet Printer
Installing printer
Hi there!
1. Try another USB port at the laptop (if you have other USB ports in it).
2. Try a known working USB cable.
3. Try a different laptop/ computer.
This should further isolate your problem.
Hope this helps!
May 04, 2008 | Acer Aspire 5100 Notebook
My printer will not communicate with the computer?
Try connecting the USB cable directly to the computer not via a HYB.
Try another USB port on the computer.
If that doesn't solve the problem there is most likely a problem with the printer.
Oct 18, 2007 | Dell 725 InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
