Question about Roper RGX4634KQ Gas Dryer
Dryer will not fire
Dryer tumbles and goes through cycle ok, but will not fire, igniter comes on for short time but never fires the gas, gas supply is good, flame sensor is good, thermal fuse is good, never hear gas solonoid ckick.
Roper RGL4632BW (2 or Z)
  • blake55 Dec 19, 2008
    ADVICE WAS GOOD PLACE FOR TROUBLESHOOTING, ONLY PROBLEM WAS MISCOMUNICATION, GAS NEVER COMES ON, I GET NO FIRE , ONLY IGNITER COMES ON, GAS NEVER SEEMS TO COME ON.
  • blake55 Dec 29, 2008
    Ended up being the solonoid on the gas valve, I checked contanuity between the two terminals from solonoid and had none, replaced and dryer worked fine. Thanks for all your help
    Scholar:
  • 68 Answers
You have a thermal overtemp sensor that has failed, they are located in maybe two spots, but the diagram on the dryer should show you where they are.
Most can be jumped over with a jumper wire, some are resistive devices that send back a signal based on changing temp and resistance, but most can simply be jumper across from one side to the other, and if stays on, there is your problem, for a gas valve to fire, and then go off, it is either a thermocouple device with pilot, or one of those overtemp devices I mentioned. If the valve was bad it would not light at all, so it is one of those devices not the timer, not the board, not the anything it is an overtemp or thermocouple device.
Will
Posted on Dec 16, 2008
  • William Babbitt
    William Babbitt Dec 20, 2008
    If the ignition is there but no signal to the valve, then check the connections to the valve, something is not telling the valve the ignition is lit and safe, there are only a couple things that could be, bad valve, if it is intermittent, that could be it, and most likely is, because everything else checks good.
    Next time it does not come on, tap on the side of the valve GENTLY and see if it is a mechanical bind.
    Will
White knight gas tumble dryer lights then cuts out
Flame sensor next to the burner is eather bad or there is a bad connection at the flame sensor (that's why the kick works)
Jan 05, 2014 | Dryers
Igniter Works, but Gas won't fire up on Sensor Dry, Will on Timed Dry
PLEASE do not use this dryer until it is fixed. it may be a saftey hazard. From the sounds of it. Your ignitor is only getting a signal every now and then. Now either is a coupler in there to tell the ignitor when to fire and when not to fire. It seems that it is going out only alloweing the dryer's ignition to come on only when a new cycle is started. That is where i would start... check with an appliance repair shop and find out if it will be something you can do your self or if it is something they have to do....
Now I do STRONGLEY recomend that you have a service technicion come on and service your dryer do to the fact that it is a GAS dryer. if something inside the dryer where to get pinched or broken it could cause a bigger problem....
so please take this advisment under consideration....
Thank you.
Aug 04, 2008 | Whirlpool GGX9868J Gas Dryer
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
Dryer no heat
This is a gas dryer ?
First verify you have an adequate gas supply . No kinks in the gas line & the gas valve is not partially shut off .
Been a long time since I worked on a gas dryer , but from what I remember there is a fan that forces air through the burner ? Is that working OK ?
You probably have one or more sensors that determine if the flame lit properly . Trace that down and check them .
The waste gases must exit the dryer . Is the vent OK ? Or stopped up ?
God bless
Wyr
Dec 21, 2013 | Dryers
Roper RGX5634KQ2 Dryer will fire initially, and heat up. It will stay fired up for around 1-2 minutes, and go out. After another couple minutes, the igniter fires, but there is no flame. This continues...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Could be a coil...but I have learned that it usually is the ignitor...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 02, 2010 | Roper RGX4634KQ Gas Dryer
I have a gas dryer that the igniter plug glows, but does not light the gas. One time when I had the front panel off the gas ignited and the dryer heated, but only burned for a minute then shut off. Now I...
with front off it will short cycle. If ignitor glows and then goes out without lighting, you have bad burner coils. The 2 black round things on burner assembly. Unplug unit then unplug coils and remove bracket with 2 screws. install coils and test.
Aug 27, 2010 | Dryers
Gas Dryer. Heat for only one burn cycle.
Try vacuuming out the intake and exhaust of the burner to remove any lint or other debris. If no help, the main burner may need to be replaced.
Feb 03, 2010 | Dryers
Sometimes does not ignite.
you have a bad timer rotory dial that will not pick up the signal for the ignitor to fire
Jan 30, 2010 | Kenmore 73952 Gas Dryer
Maytag dryer dg712 does not stay lit
Yeah change the coils read my page on intermittant coils HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 12, 2009 | Dryers
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Roper RGX4634KQ Gas Dryer Logo
121 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
