Question about Logitech X-530 Computer Speakers
Logitech x-530 5.1
Hey my popz gave me a logitech surround sound package only thing was it didn't have a manual in it, so no matter how hard i try i can't figure out how to get all speakers to work, only 2 will work at a time, and it kinda sucks that 3 won't work, so its kinda useless, if anyone has one of these systems could you scan your manule and send it to me at my email, or at least give me some advice thank you
  • 3,130 Answers
Re: Logitech x-530 5.1
Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting. Go here to get an operations manual for this setup.*11Q7xi&p_accessibility=0&p_tbl=9&p_id=2924&p_created=1126107772&p_olh=0 Good Luck
Posted on Mar 22, 2007
Need logetech manual for a530 not included when purchased
Posted on Jun 27, 2009
Logitech x-540-new
sound blaster live-new
hp/a712n pc/windows xp/760mb of ram/old
cannot get bass to work on my system, i have surroun sound but does'nt sound to good w/out bass/application is blanked out,any ideas on how to make better
Posted on Apr 30, 2008
SOURCE: Logitech x-530 5.1
Get an Audio Manager(Realtek) then open it and choose your amount of speakers.Or go to control panel then sound->Right-Click speakers->and select configure speakers. Hope this helps.
Posted on Apr 09, 2009
0 characters
3 Points
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
I am currently on Windows 7 Ultimate and I have surround system of Logitech X-530 and the front 2 speakers a playing sond how do I solve this to make the other work as well? Additional information: I also...
Hi...hard time with your logitech Speaker., do you have a 5.1 sound card install inside your pc, like 6 outputs and two input jack on your sound card... a pro sound card to make your logitech X-50 work like a charm if you dont have... I suggest to by a creative soundblaster pro 5.1, but if you do have a surround sound card with 6 input jack install in your pc and fail to work properly...ride down the model of your sound card and check if it compatible with windows 7., just download the patch for it... good luck.
Nov 02, 2010 | Logitech X-530 Computer Speakers
How do i hook my x-530 surround sound speakers to my computer
Hi there. This link has all that is required for x-530
It has manual, faqs, how-tos.
Hope this helps.
Jul 26, 2009 | Logitech X-530 Computer Speakers
Im trying to connect my Logitech X-530 to my PS3.
You need a digital decoder that is compatible with the ps3 and the speakers.
You would then run a digital optical link from the ps3 to the decoder and the normal speaker cables from the decoder to the speakers.
Decoders can be quite expensive and it can sometimes be easier to buy a set of 5.1s with the decoder either built in or included with the package.
Apr 10, 2009 | Logitech X-530 Computer Speakers
Not all speakers work,en?|downloads||dd
Jan 13, 2009 | Logitech X-530 Computer Speakers
Logitech x-530 5.1
Aug 27, 2008 | Logitech X-540 Computer Speakers
Speacker problems
cheak sound card settinsg for 4 ch 5.1 output or in audio main menu ok
Feb 01, 2008 | Logitech X-530 Computer Speakers
Logitech x-530 speakers connected to Highlander DVD recorder
YOu need to install the right drivers, for your sound and video card, latest. and Direct X9c.
Jan 13, 2008 | Logitech X-530 Computer Speakers
Logitech x530 surround sound speakers sometimes make noise
Hi Nick
As you talk I remember a spair speakers I have a long time ago, brand Creative 5600, has a bad resistor inside the speaker SB, or board, you also check for bad cable at the back or static.
another thing is your volume control, sometimes if you down a few notch you may ...not feel the hit or beep, but check things first.
good luck
Nov 21, 2007 | Logitech X-530 Computer Speakers
Logitech X-530 Computer Speakers Logo
1,517 people viewed this question
Top Logitech Computer Speakers Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
L Pfaff
L Pfaff
Are you a Logitech Computer Speaker Expert? Answer questions, earn points and help others
