Question about SanDisk Sansa Clip MP3 Player
MY SANSA WONT PLAY SONGS, IT SHOWS ARTIST BUT STUCK IN PAUSE
MY SANSA IS BATTERY OPERATED IT IS NOT PLAYING THE SONGS I HAVE DOWNLOADED, WHEN I TURN IT ON AND SELECT PLAY ALL ARTIST OR JUST PLAY CERTAIN SONGS IT STARTS TO BROWSE THRU ALL THE SONGS BY ARTIST. AS IT DOES THIS IT SHOWS THE ARTIST NAME AND THEN ONCE IT GETS TO THE LAST SONG, I PRESS PLAY AND IT DOEST DO ANYTHING, IT'S LIKE IT'S STUCK IN PAUSE. IF I HIT THE NEXT BUTTON IT STARTS THE WHOLE PROCESS ABOVE ALL OVER AGAIN.
  • 8,596 Answers
Some songs are in the wrong format, or your DB is corrupt. Either way:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
Plays six of twenty mp3s and the rest come up as
Delete songs and Format (Helps with try to delete BAD TRACKS and folders that will not delete
Labeling Unknown Songs: open Windows Media Player and go to library click on artist. The sub folders will be named by the artists and the unknown songs will be in the sub that say's unknown. Click on unknown then right click on the title bar put a check next to artist and album artist. Right click song under artist or album artist or both and type in the name of the artist etc.... This change in your computers Music folders also then sync with your sansa or media player then load songs to it........
Jul 27, 2010 | SanDisk Sansa e250 MP3 Player
Stucked at Refresh database
When the Sansa reads "refreshing database," what it is doing is going through all the songs you've loaded on to it, pulling out the "tag" information (Artist, Album, Song Title, Genre) so it can add this information to its own database which it uses to display the songs to you in its menus.
If it gets stuck during this process, usually it's because of a corrupt song file, or a song file in a format it doesn't understand.
Note that the e280 is only able to play MP3 and WMA audio formats. If you've loaded a different type of audio file onto your Sansa, you'll need to remove them.
If the songs you've recently loaded have all been MP3 and/or WMA, you may have loaded a corrupted file onto your Sansa. Try removing the songs you recently added, and see if the problem goes away.
Feb 27, 2010 | SanDisk Sansa E280 MP3 Player
I can't drag and drop music from my library to the sansa clip. I have downloaded songs using Rhapsody and I can see where my device is but it wont allow me to drag my songs to it... I have purchased the...
Account Status
You need to connect to Rhapsody once every 30 days to continue playing your subscription tracks. When you reconnect, the 30 day license is renewed. The indicator will change from full circle to a quarter cycle as the days pass, and you will be warned when your tracks are about to expire.
Rate This Song
1. In playback mode, press the Submenu button.
2. Select Rate This Song.
3. Press |<< or >>| to change the rating (Negative to 5 Stars)
4. Select Negative to ban this track from playing again.
Purchase
2. Select Purchase This Song.
3. When you connect the player to Rhapsody To Go, the track will be added to your Purchase Bin. You can decide if you would like to purchase it at your leisure.
Add To Library
2. Select Add Track to Library
3. A confirmation message, "Song has been added to your Library". Your song will now be a part of your device Library.
Artist Info
To display the artist information, press the center button 2 times when the song is playing back.
Account Info
1. From the Main Menu, select Settings.
2. Select Account Info.
Feb 26, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip 8GB is stuck in pause mode
You mean it hangs up at pause mode and you can't turn off you device? if so, push up/press power button and hold for 10 to 20 seconds until the device turn off.
Then, turn on. if it' working. You should update new firmware.
Good luck
Jan 17, 2010 | SanDisk Sansa Clip MP3 Player
Sansa not playing songs
-Tha Mp3 Doctor
Dec 16, 2008 | SanDisk Sansa Clip MP3 Player
Mp3 player is stuck on pause
In Sandisk Mp3 Players there is a small bug if u copy songs more than 75% it will stucks like that so use less than 75% memory
Thank U
Take Care
Bye
Apr 12, 2008 | iLO (2 GB) MP3 Player
Shaker wont turn on
you have to hold the play pause button until you hear a noise and music starts playing
Mar 04, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa won't play songs
my mp3 player skips songs while playing it does'nt play the whole song it keeps skipping
Dec 24, 2007 | Audio Players & Recorders
Won't upload a certain cd
It seems odd that the device wont play 1 particular artist. If you downloaded it from URGE, it may be subscription content and that may be causing the error. I would try burning the music to a cd, then re-rip them back to your computer to see if that strips out the problems. Best of Luck.
Sep 17, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
582 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
