Question about Datamax DMX-I-4212 Label Printer
Image files won't print only name no image
I have sent several image files to the add-on module 'z'. The image will not print, only the name of the image. I reformatted the module and tried again with no luck. I then tried to send it to another memory module. This did not work either. When I print the directory list, I see nothing in the modules that I have sent the images too. Please help!!!
  • 27 Answers
I can help you with this. Please let me know what method you are using to send images (software, dmxconfig, dpl..) and also the type of image (bitmap,jpeg, pcx,etc..). With Datamax printers, 4 types of image can be used: bitmap,pcx,img, and 7bit datamax image file. Another thing to know is that the image must be a black & white, monochrome image. You can use a program like microsoft photo editor to make this change. You can use DmxConfig, Utilities.exe, & DPL (datamax programming language) to load image to printer. Let me know the answers to my above questions to proceed with solution.
Posted on Dec 29, 2008
Quick books won't print
Could be from several issues.
Try locating the file named qbprint.qpb, and renaming it to oldqbprint.qpb. Then reopen QuickBooks and try again.
Sep 14, 2012 | Intuit QuickBooks Pro 2008: Windows
I have tried several times to print a PDF file. The file gets sent to the queue, and then disappears without printing. I would appreciate any help or advice. Thank you.
This most often caused by a postscript error or insufficient memory in the printer.
You could try too see what happens if you instruct acrobat reader to print as image.
This setting is usually found in the printer selection screen under advanced options.
Note this setting is available for windows, for apple I'm not sure this option exists.
Jan 04, 2011 | HP LaserJet 4si Printer
Unidentified Image
When a camera records a picture certain information is written in the image file. When you see it in another camera, the second camera reads the stored information and may be able to display the name the date and so on depending on the information stored.
However if someone sent you pictures attached to an e-mail message, they are often compressed and the information about the images may not be available. So, not fin ding the name of the image, the camera says unidentified image.
If you want you can rename them, but you will not be able to restore the meta information that was stripped off the image when it was sent by e-mail. Identified, or not the images are still viewable.
Jan 06, 2010 | Canon IXUS 80 IS Digital Camera
I want to have the date/time stamped right on the photos. does this camera have that feature? Cannot find that in the manual. All it says is date/time settings and that it is used in the file name.
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Apr 22, 2009 | Olympus SP-350 Digital Camera
Printing Acrobat 9 pdf file to the Imagerunner 7200
In acrobat go file, print and press advanced. Check print as image. Print the job again and see if you get different results. This does the image processing on the PC. Your document may have a postscript error in it and your device may be set not to print PS errors.
What driver language and version are you using?
Try updating your driver to the newest version, get device status.
You may also wish to try PCL printing for that file. (as a workaround)
Do other files have the same problem? What about when sent to another printer entirely?
Mar 05, 2009 | Canon imageRUNNER 7200 Copier
Appcrashes
The problem is cause by an application called webshots which downloads images and automatically updates you desktop.
While this pacakage is not itself malware there are several pieces of malware which masquerade as webshots.
First I would suggest checking Add/Remove programs in control panel to see if you can remove it and then you need to install an upto date version of anti-virus and anti spy-ware software to check your not infected with some nasty.
Please let me know if you need any further help.
Regards
Nick
Oct 26, 2008 | Computers & Internet
TO Print the image using IPL.
I've printed images over 500kb. Can you print a small image? If not, perhaps the driver is the problem.
If you're trying to send a text file of IPL commands to the printer, set up a Generic Text printer driver, to to send the file as ascii characters instead of as a graphic image. You can set this up in addition to your Intermec driver.
Go to Printers and Faxes, Add Printer, Next, Select the Port, Select "Generic" Manufacturer, "Generic / Text Only" Printer, and give it a name like "Text". Cycle the printer power to clear previous attempts, then print the file to this printer name.
Aug 22, 2008 | Intermec EasyCoder 3400 Thermal Label...
Printing Backwards like a mirror image
You need to change the printer properties.
You can do this a few ways:
  • Click File , Print , then click the Properties button.
  • Click File , Print Setup , then click the Properties button.
  • Click File , Print , Setup , then click the Properties button.
  • Click Print , Properties , then click Printer Assistant .
  • Click the Taskbar Printer icon.
  • Right-click the applicable 3740 icon in the Printers folder, then click the Printer Preferences button.
Click on the "Basics" tab.
The 3rd option under "orientation" will say "mirror image".
Make sure this is un-checked.
Mar 24, 2008 | HP DeskJet 3740 InkJet Printer
SCANER,PRINTER,COPYER
Saving a scanned image on the computer
1 Load an original document facedown on the scanner glass.
2 Close the top cover.
3 From the desktop, double-click the Lexmark Imaging Studio icon.
4 Click Scan.
5 Select the Photo, Several Photos, or Document option.
6 Click Start.
7 From the Save or Edit screen menu bar, click Save.
8 To save to another folder, click Browse, and select a folder. Click OK.
9 To rename the file, enter the name in the File Name area. To assign the name as a prefix to all of your photos,
select the “Start all photos with File Name” check box.
10 To save the photo as another file type, select the file type from the File Type drop-down list.
11 To select a date for the photo, click the drop-down list, and select a date from the calendar.
12 Click Save.
Jan 22, 2008 | Lexmark X2500 All-In-One Printer
Datamax DMX-I-4212 Label Printer Logo
825 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
