Question about Refrigerators
I have a kitchenaid refrigerator - 8 years old - the freezer compartment door won't seal because the rail/track for opening and closing the door is cracked - I have been chasing replacement parts for 6 months - always 20 days on backorder - is there another valid source of these rails - or is there a way to get Kitchenaid to get them for me now vice waiting for the computer parts-ordering system to finally kick in
  • nautilusjt Dec 19, 2008
    the model number is kbr36mhsoo - ser nr. qj3000059 - the part number for the bracket/rails is 4388545 - I have no reason to believe the seal is bad, the door cannot shut properly because of the broken rail which allows the right side to sag about a 1/4 inch. My problem ( after working with Kitchenaid parts folks directly and going thru two different "authorized" repair organizations) is that KA has been saying for 6 months that the "are on backorder and will be available within 10 - 20 days".  K/A is clearly waiting to have enough to  order to justify the effort to place an order - in the meantime I sit without a freezer.
    I neither need a real way to get the parts or a way to get high enough in the K/A chain to energize them!
    John Mitchell
    oops - kbrp36mhsoo     John m
  • Refrigerators Master
  • 19,396 Answers
You need to replace the door seal, this is not a difficult operation.
You find parts and diagrams by entering model number here.
Posted on Dec 16, 2008
How do I unlock the bottom freezer door?
I don't think this model has a lockable door. Is it just stuck?
Jan 02, 2015 | Frigidaire FGUN2642LF Gallery 26 Cu. Ft....
Why is there frost on the underside of the bottom shelf of the freezer door of our Kitchenade Supra side by side refrigerator?
You're getting moisture into the compartment somehow...check door seals and the door cams/hinges make sure its closing correctly....air from outside getting in will freeze up....
Oct 02, 2012 | KitchenAid Refrigerators
Kitchenaid kbfs25ewms2 freezer leaking water
Normally I would agree a water line is the issue however on this particular fridge this is not the case. If you open the freezer door, notice the placement of your hand. Unless it is dead center of the handle this is the cause of the problem and what I believe is a major design flaw. Depending if left or right handed, every time the door is opened the metal tracks that hold the door are being bent. If you remove the bottom freezer basket you will notice the back support bar that is attached to the metal rails is not longer straight.What ends up happening is, certain times when the door is pushed closed it seals completely and other times it does not. The times it does not, there is inch gap between the rubber seal on the door and the fridge itself(left or right side). The freezer warms up and items start to melt. As the cycle of freeze and thaw continues you end up with the entire basin full of ice. Eventually when the door does not shut properly and the ice melts it has nowhere to go expect your floor. This is why sometime you will have a pool of water and sometimes you won't but it always leak from a corner. Learned this first hand and ending up ruining 30sq of hardwood floor
Feb 02, 2012 | KitchenAid KBFS25EW (24.8 cu. ft.) French...
On the KitchenAid Model KSSC42QTS, the small door on the ice-maker dispensor that seals off the freezer is loose. It does not appear to be broken, but is loose in the compartment. Does the dispenser need...
do not reattach the old door but replace the door with a new seal . some of these units had poor door closure when new . the new door is better . and you will have dissamble unit to install door .
Aug 11, 2010 | KitchenAid Model: KSSC42QTS
My fisher and paykel refrigerator keeps freezing my food, then its ok, then it freezes up my food again, I have adjusted it, but still no good.its 8 years old
you will need to check your damper door between the freezer and refrigerator compartments and watch to see if its opening and closing when you adjust your refrigerators cold control,then if it doesn't move after adjustment the control will need to be replaced
Jan 08, 2010 | KitchenAid KSCS25FKSS Side by Side...
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
Oct 13, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
