Question about Panasonic SA-XR25 Receiver
Need resistance value for R743 on power supply pcb for SA-XR25
R743 is been getting hot and is now open, i wish to replace to see if unit works. The power supply PCB part number is RJB2681BA. it has got so hot the cermic is gone so cannot see any colour( yes i am english!) bands.
The colours are: gold/blue/orange/red
Posted on Feb 16, 2011
How do I fix DC peak (IPM fault) On lg ductless inverter outside unit
This fault is caused by an over current in the inverters DC power circuit. If the DC part of the circuit exceeds 14 Amps fault code 21 will be displayed. This is caused by either the inverter PCB being faulty or compressor being short circuit or grounded. Disconnect the electrical connections to the compressor and check the resistance of the compressor windings, measure from U to V, V to W and W to U the values should be between 0.25 and 5 Ohms each.
The next test is to measure the resistance of the compressor windings to earth. Using a Megger (High Voltage Meter) measure the resistance from any of the 3 compressor terminals to an Earth point (pipe work). The value should exceed 2 M Ohms.
If the compressors fail these tests it will need replacing. If the compressor is OK... CHANGE THE PCB
Aug 05, 2016 | LG Heating & Cooling
Tip
ERROR CODES AND DESCRIPTION
2X Blink - Main Power Error
A 2X protection mode blink pattern can be activated due one of the
following defects.? Loss of REG12V (LVP)*
? Loss of -125V (Single Line)
? Excessive -125V Level (OVP)*
? Loss of Power-ON Signal
? Excessive PFC Voltage (OVP)
? Excessive PFC Temperature (OTP)*Low Voltage Protection (LVP)
*Over Voltage Protection (OVP)
For more check the following link. Use the search tab on the top right corner to find your product
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 15, 2015 | Sony Kdl-32ex720 - Series 32" Ex720 Bravia...
Riso HC5500 S01-204 error
  • Code: 001 S96
  • Description:Power supply remote signal not connected The control signal cable for the ON/OFF control of the 24/38-VDC output is disconnected. The signal wire grounded inside the power supply unit has been pulled up by the IP PCB to detect the level.
  • Code: 003 S97
  • Description:38-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 38-VDC resistance inside the power supply unit. The detection level is approximately 18 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
  • Code: 004 S97
  • Description:24-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed by the IP PCB based on the signal resulting from dividing the 24-VDC resistance inside the power supply unit. The detection level is approximately 11 VDC. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec). No detection is performed when the interlock SW is open.
  • Code: 006 S97
  • Description:3.3-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 3.3-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
  • Code: 007 S97
  • Description:1.8-VDC power supply voltage error A voltage drop is detected when a voltage drop is sensed in the 1.8-VDC power supply on the MIP side of the IP PCB. Voltage polling is conducted at 100-ms intervals by the IP-CPU. An error is detected when a voltage drop is sensed 10 times in succession (approx. 1 sec).
  • Code: 008 S96
  • Description:Control panel not connected The absence of the control panel unit to be connected to the MC PCB is detected. Since this configuration lacks this panel, this error indication will not be issued under normal operating circumstances.
  • Code: 009 S96
  • Description:Print counter not connected The absence of a print counter is detected.
  • Code: 011 S96
  • Description:CIS PCB not connected The connection of the CIS PCB cannot be confirmed.
HP Printer Support Phone Number 1 850 610 1013 HP Support Assistant
Dec 11, 2013 | Riso Office Equipment & Supplies
Im having trouble setting up my SA XR25 reciever. I have 2 small bose speakers with a subwoofer. how do i connect the speakers to the reciever?.
Go to Bose.com, find the exact product in the roll down and it will lead you to manuals for the speakers.
Register and download the free manual for the SAXR25...
http://www.retrevo.com/support/Panasonic-SA-XR25-Receivers-manual/id/312dj786/t/2/
Feb 13, 2011 | Panasonic SA-XR25 Receiver
I don't have a remote for my panasonic sa-xr25. Can I turn off the surround/enhanced button from the receiver?
Get your reading glasses out. There's a button marked "Enhance Surround" two clicks to the left of the Volume Control.
Mar 24, 2010 | Panasonic SA-XR25 Receiver
The sound is distorted and overwhelmed by static
Depends what the real problem is.
Is it related to certain sources only - try new or reseated cables,swap it to a different input; single channel - swap to isolate; or certain controls that have become noisy? A shop might be able to get some tuner cleaner into them.
Mar 12, 2010 | Panasonic SA-XR25 Receiver
Looking for a new Panasonic SA-XR25 6.1 Channels
A quick search only revealed on online retailer that still had one in stock:
http://abcdealz.stores.yahoo.net/pansarx25.html
I strongly suggest calling them to verify that the unit is in stock prior to placing the order online.
Alternatively, set up a saved-search on ebay to alert you if one is posted, or post to "Want it now". (http://pages.ebay.com/wantitnow/index.html)
I suspect the unit is still under warranty. Call Panasonic to verify:
1-800-211-PANA
Apr 18, 2009 | Audio Players & Recorders
Resister burnt
Guest and Lesfix. RU83 located on the DRC8335 VCR PCB is a 51ohm 1/4 watt 5% tolerence resistor, color coded green-brown-black-gold. As to zener diode DU83, I haven't been able to determine it's value yet but am working on the problem.
Be aware when either or both these components fry, this indicates you need to replace the following two overheating capacitors on the power-supply board, which were directly resonsibile for knocking them out:
• C216 1000µf 16 volt (upgrade to 35 volts)
• C218 1000µf 10 volt (upgrade to 35 volts)
Could you email me regarding this problem when you have time. Mention Fixya and DU83 in the subject line so I realize it's from you. Thanks. mikeadams110@yahoo.com
Oct 02, 2008 | RCA DRC8335
Receiver has lost audio
There are four surface mounted caps, 22uf/10v under the surround processor PCB on the main PCB.
Just replace them all.
That took care of my static problem.
Mar 17, 2008 | Panasonic SA-XR25 Receiver
Panasonic SA-XR25 Receiver Logo
132 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
