Goodmans gdvd300r ic304 in psu what is its type number
    Problem Solver:
  • 8 Answers
Number should be on the Ic...
Posted on Dec 17, 2008
GDVD300R Manual
Check this link to download it.
Feb 25, 2013 | Televison & Video
LG 42PC3RV-ZJ PSU part numbers
Go to Shopjimmy.com and type in your Model Number.
Oct 08, 2012 | LG Televison & Video
Just need type of refrigerant R-22 or 410a for a goodman ckl60-1
Can't tell from the model number because it is incomplete. But if you will look on the outside unit there is a placard that states the information about the unit. It is located below the electrical compartment. If will tell the type of refrigerant the condensing unit came charged with and how much.
Hope this helps.
Sep 10, 2011 | Goodman CKL60AR60 Air Conditioner
What type of capacitor comes with a 5 ton Goodman Air conditioning unit model number CK60-1C
The best way to know what size capacitor it needs is to look on the label of the fan motor itself. It will tell you the size it needs. Condenser fan motors get replaced all the time with different capacitors needed. If you cant find a label or its too weathered, try to find a model number on the fan motor and any local A/C supply store will be able to look it up. Hope this helps.
Jun 21, 2010 | Goodman CKL60AR60 Air Conditioner
Need an gms8, control module .goodman furnace
Go to www.americanhvacparts.com or www.furnaceparts.com On the first site type model number of unit upper right corner and pictures of parts will show on screen. Rus
Mar 14, 2010 | Goodman GMS80904BNA Open Flame Mid-Size...
When powered up the 6.3 amp psu fuse blows any ideas thanks
Replacing a blown fuse once is necessary, twice to be sure that the first had reason to die, then no more as you could be damaging something in addition to the failed part.
This indicates that something basic in the power supply has turned into a wire. The first thing to check would be rectifier diodes that process the incoming AC; these are cheap and easy to check with any multimeter with an Ohms or diode setting and should measure a bunch in one direction and little in the other. With a diode check range, you should find ~ 500-700 millivolts (units are not indicated), on the Ohms range from several hundred to maximum 1 K Ohm in on direction and off-scale in the other.
Beyond that, you will find possibly discrete transistors or a module (on a heat sink for both) for which you will need the pin-out to roughly measure it. The type numbers are a mix of letters and numbers, the production period will be only four numbers so you need the type number to search for the specs and connection diagram.
If these check out OK, then I think your technician days are over and it's time to let a pro look further. Be aware though, the cost of labor and the potential lack of parts availablity can stop the repair completely so if you can't find something already mentioned, like too many things today, it is doomed to the scrap heap.
Jul 16, 2009 | Goodmans GDVD70W6 DVD Player
Power edge 1800 bought october 2006. It does have a DELL 650 Watt non-redundant power supply, type nr. PS-5651-1. Can I replace it with a standard ATX power supply, or is the connector not standard wired...
Dell uses proprietary psu's. You will need to contact them for replacement psu or find a supplier that makes psu's that can be used as a Dell replacement. Hope this helps.
Jul 07, 2009 | Dell PowerEdge 1800 Server
Distorted picture
still having to do with your power anyway make sure your mains is not too high or fluctuating .if buy a voltage stablizer then change your power module
Jul 23, 2008 | Goodmans W280NS Television
Goodmans 27 inch LCD
Sounds like the power surge may have blown the fuse in the TV. You can replace the fuse and see if that works. If not, more damage to the power supply unit may have occurred.
Jun 09, 2007 | Goodmans W280NS Television
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
