Question about Photography
Ricoh KR-10 locked focus ring
I just got a Ricoh KR-10, and I the focus ring won't move (aperture works fine). It's almost as though it's locked or something. I don't want todamage it, so I've been gentle with it, but I'd really like to get itworking so I can take some photos! Any suggestions?
  • 1 more comment
  • moore_kathle Dec 16, 2008
    Since it looks exactly like the lens in the instruction manuals that I've found online, I would safely assume that it's the lens that came with the camera. It doesn't look like its damaged in any way - the whole camera appears to be well taken care of - everything lines up and there are no scratches or dents or anything to indicate that it would be broken.
    Here's a picture of it - other than needing a cleaning, it looks fine :)
  • John Buettner May 11, 2010
    moore_kathle,
    lens has no lock on the focus ring. what kind of lens, what is the mm?
    is it the normal 50mm or is it a zoom lens?
    check to see if there is no impact damage.
    is the lens barrel perfectly parallel with the focus ring?
    Scholar:
  • 185 Answers
you can fix this if you have a jeweler's screwdriver ( x- head ).
1-take the lens off the camera.
2-take off the front name plate with a thin knife blade just right of H of RICOH name. gently pry the name plate up till it pops off ( not screwed on ).
3-remove the three screws from the plastic ring, ( large ring ).
4- pull the ring off.
5- where the metal ring touches the plastic lens barrel apply a few drops of light machine oil.
try to move the focus ring back and forth until it's free.
it can be further broken down but then the lens will have to be re-focused. as long as there is no impact damage this will work.
Posted on Dec 16, 2008
Aperture ring won't turn
When the camera is set to autofocus, let the camera do the focusing. If you want to focus manually, turn off the autofocus so you can turn the focusing ring.
Sep 30, 2012 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
I am new user for DSLR, using old 50 mm 1.8 manual focus on D80, unable to see any inmage on playback (shows information). Will this lens work with D80, using settings as manual mode, f22 . Please guide...
Turn the aperture ring to its smallest setting (largest f/number). You control the aperture from the camera body, as on a lens without an aperture ring. Turn the mode dial to M (manual). The camera's exposure meter will not work with this lens. You can use another lens to get an approximate exposure, or take pictures and review them and/or use the histogram to fine-tune the exposure. The camera won't autofocus, of course, but the in-focus indicator in the viewfinder will still light up to indicate proper focus.
Jun 17, 2011 | Nikon D80 Digital Camera with 18-135mm...
Message: Lock lens aperture ring at minimum aperture (largest f-number) I think I'm doing this but the message won't go away and the camera won't work.
You must lock the aperture ring to f/22, so the camera can engage the aperture adjustment lever on the lens. Then, you can change the aperture with the command wheel.
When you change the aperture with the command wheel the aperture ring on the lens doesn't move when the camera actually adjusts the lens aperture.
Take the lens off and locate the aperture adjustment lever on the lens mount.
Unfortunately, this won't work with older AF lenses. So if you are using an older lens, the only thing you can do is change the camera setting to M (Manual) to adjust the aperture on the lens yourself.
May 16, 2011 | Nikon D60 Digital Camera
It is brand new Tamron 28-75 f2.8 for Sony mount. When it is focusing on an object and rotates from one end to the other velocity causing to shift image slightly in the direction of rotating AF ring....
You should turn the aperture ring on the lens toits smallest setting (largest f/number). If the ring has a lock, lock it inplace. You control the aperture from the camera body, just as you would on alens with no aperture ring.
Let me know if you need more information
Thanks
Feb 18, 2011 | Tamron 28-75 F2.8 XR AF Lens
I have a Nikon D60 and have just bought a 50mm AF 1.8 D lens but find I can only use the aperture setting at 22. Is that right ?? why can't I use the other aperture settings ??
The D60 camera sets and triggers the aperture that you have selected (or the camera has selected if in auto mode) and sets the aperture as you take the picture. Moving the aperture ring on the lens will not work, in fact once you move it from the f22 position the camera will stop or possible show and error. on my older Nikon AF lenses there is a small lock to lock the aperture ring in the lowest position when mounted on a digital camera, it is found near the f2.8 side of the aperture ring. when you want to set the apertures manually, you put the camera in aperture or manual mode and set the aperture you want by moving the the rotating wheel on the grip part of the camera. the aperture you select will show in the window, you do not have to move the ring on the lens,it must remain the f22(highest numerical) position.
Oct 24, 2010 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon D80 Err
You did not mention what error mesage you got. If it is a flashing "F--" then it has something to do with your lens.
This usually happens to lenses that have an aperture ring. Do the following:
1. Turn off your camera.
2. Move the aperture ring clockwise and lock it
3. Turn on the camera and see if this works
If this does not work, unlock the aperture ring and move it counter-clockwise then lock it again.
This should fix your problem
Jan 01, 2010 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80 shows err message. still after full reset it wont work
Check if your battery is charged. Are there any error messages? Otherwise, if your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
Sep 17, 2009 | Nikon D80 Digital Camera with 18-135mm...
Format Error message
The aperture ring must be locked in position when using automatic aperture control. When the aperture ring is in any other position the 'format error' message appears and the camera is inoperative. Now that my ring is locked in position the camera works fine.
Sep 13, 2009 | Nikon D70s Digital Camera
I am having a nikon D80 camera. In the display it shows Error. I i click the camera no focus,no picture in the memory card.
This may be due to the aperture ring in your lens. Try the following:
2. Move the aperture ring clockwise then lock
3. Turn on your camera and try again.
If this does not work, do the same thing again but turn the aperture ring counter-clockwise.
Jul 31, 2009 | Nikon D80 Digital Camera with 18-70mm Lens
Lens
If this is a manual focus lens, you will need to do two things (and an optional third thing.)
1) On the side of the camera, you have to switch the focus mode switch from "AF" (Autofocus) to "MF" (Manual focus) . . . Yeah. I know, you probably already did that. <grin>
2) When you press Menu, go to the Custom Setting and change the Allow aperture setting to on, so that the Pentax K100D will then work with manual control of the aperture ring. You need to do this or the K100D will not work with manual exposure lenses (M lenses) or even autoexposure lenses (KA, KA2, FA, etc.) when you move the aperture ring from the "A" position to one of the manual aperture settings!
3) This is optional, but in the Custom Setting you can also turn on the Fl in manual focus mode, so that even though you don't have autofocus capability, you will get a beep indicator when you have successfully managed to manually focus your lens.
I have a few nice manual focus lenses that I have a lot of fun playing with on my K100D.
Take care & Happing Imaging!
Glen
Jun 09, 2008 | Pentax K100D Digital Camera
Photography Logo
197 people viewed this question
Top Photography Experts
TC CAMERA REPAIR.Com...
Marvin
Marvin
Are you a Photography Expert? Answer questions, earn points and help others
