K9mm-v via k8m800 + vt8237r / amd athlon / running ubuntu 7.10 video problems
Hello, I will try and provide some relevant descriptions of the problem.
1. using onboard video, machine just "lost" or had no visual output on the monitor.
2. switched monitors, same result. put monitors on different box, worked fine
3. put a new (e-gforce 6200) graphics card in agp slot. initially worked!
4. after a few days when bios passed control to OS, i got 5 cursors and seemingly 5 screens, nothing ledgible.
5. took new card out. hooked back up to onboard video
6, no change , get the several distorted screens.
7. went into bios and only change i initiated was to load optomized default settings.
any ideas?
Mike
  • 43 Answers
MY GUESS IS THE NORTH BRIDGE ON MOTHER BOARD IS BAD, REPLACE MOTHER BOARD.
Posted on Dec 19, 2008
What is the Front Side Bus speed of MSI MS-7312 ver 1.0 motherboard
MOBOT Motherboard Spec Sheet MSI K9MM MS 7312 Motherboards org
THE LINK ABOVE GIVES THE SPECS
MSI K9MM-V (MS-7312) Spec Sheet Powered by MOBOT 10428.jpg Part Number K9MM-V (MS-7312) Manufacturer MSI Price Check Find Best Price Downloads BIOS
Drivers
Manuals Chipset VIA K8M800 VT8237R+ North Bridge VIA K8M800 Socket Socket AM2 (940) Processor Types Athlon 64X2, Athlon 64FX, Athlon 64 Number of CPUs Front Side Bus 800MHz HyperTransport Bus Link Memory Type DDR Memory Channels Dual Maximum Memory 2GB External Graphics AGP8X IGP VIA UniChrome Pro South Bridge VIA VT8237R+ Audio 6-channel IDE SCSI None SATA 1.5 GB/s RAID LAN Firewire None USB USB 2.0 Expansion Slots BIOS AWARD Form Factor microATX
Jun 05, 2014 | MSI K9MM-V Motherboard
Where to get Drivers
Hello enter the mainboard number here:
http://support.asus.com/download/options.aspx?SLanguage=en
Or use autodetect, to find the mainboard.
Good luck
Mar 04, 2013 | ASUS K8VQ VIA K8M800 SOCKET-754 AMD ATHLON...
Dont know the ram that it use. wat is the number on the battery
  • K8M800-M7A
  • Support DDR 333/400 MHz
  • 2 x DDR DIMM Memory Slot
  • Max. Supports up to 2GB Memory
  • the battery i dont no
  • hope it helps
  • Biostar K8M800-M7A - motherboard - micro ATX - Socket 754 - K8M800 specifications
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type VIA K8M800 / VIA VT8237R
    • Max Bus Speed 800.0 MHz
    • Processor Socket Socket 754
    • Max Processors Qty 1.0
    • Compatible Processors Athlon 64 , Sempron
    • Memory
    • Max Supported Memory 2.0 GB
    • Supported RAM Technology DDR SDRAM
    • Supported RAM Speed 400 MHz , 333 MHz , 266 MHz
    • Graphics
    • Graphics Controller VIA UniChrome Pro
    • Memory Allocation Technology Shared video memory (UMA)
  • Jul 20, 2011 | Biostar K8M800-M7A Motherboard
    SERACHING DRIVERS FOR MSI K9MM-V FOR WINDOWS 7. WHAT VGA CHIPSET IS IT
    The motherboard you mentioned has VIA K8M800 and VT8237R Plus chipset. Unfortunately there are no qualified drivers for windows 7 for this motherboard. I suggest you to try the generic windows 7 drivers. In case of a problem download the windows XP drivers from this official link and if the problem is still existing try before the installation to right click on the file you are about to install and check at the compatibility tab the compatibility with windows XP sp3 check-box.
    In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
    If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
    Thanks and regards
    Please kindly rate this solution
    Stelios
    direct fixya link: http://www.fixya.com/users/technical114
    Feb 01, 2011 | MSI K9MM-V Motherboard
    I need driver software for MSI K9MM-V (MS-7312) Mother Board
    got to
    http://www.msi.com/index.php?func=downloadindex
    select mainboard
    select amd
    select socket am2
    select VIA
    select K8M800
    select k9mm-v
    this should take to the K9mm-v page just select driver and you have all the drivers and utilities for the motherboard
    Sep 24, 2010 | MSI K9MM-V Motherboard
    I have MSI via k8m800 vt8237r chipset based board and amd athlon x2 dual core 4600 cpu ccan i suppor 1tb sata hard disk
    some of the motherboard select the kind of devices that will work for them, try to test your sata hard disk with another system if it work then try to change the board. or get another system that will support your sata. thanks
    Jun 12, 2010 | MSI K8MM-V Motherboard
    How do i read the motherboard to see what board i have
    The Manufacturer of the mother board is MSI and details are as follows:
    Manufacturer Part # :K9MM-V
    Product Type :Motherboard
    Form Factor/chase: Micro ATX
    Chipset Type :VIA UniChrome Pro K8M800 / VIA VT8237R Plus
    Multi Core Support :Dual Core
    Max Bus Speed :800 MHz
    Socket Type 0 ( 1 ) :- Socket AM2
    Compatible Processors : Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
    It supports 64 Bit Processor
    Multi Core Support :Dual-Core
    Its Supports RAM Technology: DDR II SDRAM
    RAM Installation : 0 MB / 2 GB (max)
    Supported RAM Speed :PC2-4300, PC2-6400, PC2-5300
    RAM Features :Two DDR Channels
    Video Memory :Shared video memory (UMA)
    Audio Codec :Realtek ALC655
    Sound Output Mode : 5.1 channel surround
    Expansion Slots Total (Free) :1 processor - Socket AM2
    You can addin RAM of :2 memory ( 1.8 V ) - DIMM 240-pin
    PCI :3 PCI ( 3.3 V/ 5 V )
    Storage Interfaces
    Additional Connectors : 4 x Hi-Speed USB
    Dec 21, 2009 | MSI K9MM-V Motherboard
    Computer does not work first.
    Does it power up if it does do you hear a beep on post screen, Please Briefly explain what is happening my email : colin.gila@wits.ac.az
    May 08, 2009 | MSI K8MM-V Motherboard
    Sound driver?
    check the website www.asus.com go to the global area  Supports AMD Socket 754 Athlon 64/ Sempron
    - VIA K8M800 + VT8237R
    - Front Side Bus 1600 MT/s
    - DDR400/333/266
    - AMD Cool 'n' Quiet Technology
    - SATA (RAID0, RAID1 & JBOD) If this is your Board just type k8V to the search bar ...if still you cant download the driver i will send it to you by email... just give me your email add....
    Oct 24, 2008 | ASUS K8V-MX Motherboard
    Computers & Internet Logo
    387 people viewed this question
    Alun Cox
    David Payne
    David Payne
