Question about Panasonic Workio DP-150PA Copier
Panasonic DP150 FX Workio information screen is saying "Warming Up"
My information screen on my printer is saying "Warming Up" and Tray-1cel. Please help, I cannot use the ADF or make copies or fax but the printer will print from the computer. Whe I do print something it give me a message at first that say's "Out of Paper" Please help.
    Problem Solver:
  • 10 Answers
Remove the paper drawer and check at the back of the mc where the cassette was for paper
Posted on Mar 23, 2007
SOURCE:
I have problem on my printer workio 1820 e,it always say add paper tray no.1 which already has paper...i dont know whats the problem
your interlock switch of the front door is not working. u have to remove the front cover and then short or replace the interlock switch.
Jul 02, 2011 | Panasonic Workio DP-1820E Copier
I encountered an error code E02-01 on my Panasonic Workio 1520 printer. What do I need to do to reset or fix it?
1 st check for paper behind tray! If prob still occurs tray 1 lift motor would need to be replaced!
Jan 03, 2011 | Panasonic WORKiO DP-1520P All-In-One Laser...
Panasonic DP1820E check printer E02-02 red spanner
yep!
e2-02 means there is a machine error of lifting motor assembly for tray #2.
For sure this time you can't use your tray #2.
you may check it sometimes there's just a paper clogged at the rear of the paper tray. just remove your 2nd tray to see if there is a paper clogged inside. Otherwise the cover/case of the lifting motor is damaged and you will need a service technician to fix and replace it.
Mar 14, 2010 | Panasonic Workio DP-1820E Copier
Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
Mar 27, 2009 | Panasonic Workio DP-2000P Copier
Panasonic DP 2500 paper tray error
Make sure that you don't have too much paper in the tray. There is an overfill idicator on the back of the tray. Push the tray in firmly. Then try to print. If not, reset the printer by pushing "reset" button.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 21, 2008 | Panasonic Workio DP-2330 Printer
ADD PAPER
Check the upper limit sensors if they are moving nicely and freely check out put or simply swap the sensor with other tray. "Or try with dust blower/dust buster can" Good luck
Jun 17, 2008 | Panasonic Workio DP-2500E Copier
Panasonic Workio DP-1820P
Printer Error E02-01 appears when paper tray number 1 lift-up motor is unable to lift papers, Check whether the gear box of the motor is broken , normally replace the whole unit
Apr 30, 2008 | Panasonic Workio DP-1820E Copier
Panasonic workio dp-1810p
pls check out the sensor lever below the drum if it is freely moving.
because that is the sensor concerned for j33
Sep 01, 2007 | Panasonic DP-1810P Laser Printer
Panasonic Workio DP-150PA Copier Logo
132 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
