Question about Whirlpool GH7145XF Microwave Oven
We burned perforated plastic inside window of door.
Does this perforated vinyl offer any protection or can it be removed to allow see thru glass?
    Scholar:
  • 68 Answers
Explain this to me in more detail, write me at home wbwill@sbcglobal.net, this could be dangerous, I don't know what you mean you by burning anything, but if you burn't something, why, and will that happen again, and what is this perforated vinyl?
Is it the enclosure of the oven, see through the glass?
Explain this to me, soon as you can.
Will
Posted on Dec 16, 2008
Door glass is lose and seal is leaking..moisture is forming on inside of glass
That is normally caused by the clear plastic adhesive cover either having been removed or missing. It covers the perforated door inner and stops condensation and food particles from getting inside the door cavity where is cannot be cleaned.
Feb 14, 2011 | Goldstar MV-1526 Microwave Oven
Our oven door has become dirty from juices spilled and has got in bewtween the glass on the door. Can this be taken apart and cleaned out????
Depending on the make and model of microwave it should be cleanable.
If you have countersunk screws along the outer of the door edge, unscrew the screws and then the plastic from should pry off allowing access to clean the inside portion or let you remove even more screws allowing access to the inside.
Some have a plastic bead on the inside of the door that covers up the screws. That is held on by long plastic clips, covering the screws that hold the front on.
Hope that helps.
Dec 10, 2010 | Microwave Ovens
How do you remove Whirlpool microwave mh7140x door to replace white plastic door face?
If you are referring to the disassembly and replacement of the door, just follow these steps:
1. Open the door all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
2. On MOST microwave ovens, all you have to do is remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to release the clips that hold it in place so you can pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
3. With the inner panel removed, locate the door handle screws and remove with a screwdriver.
4. The panel glass should be "sandwiched" in place (double layer on most ovens) and should either lift out, or have retaining clips holding in place. Remove and set aside.
5. The remaining piece(s) comprise the door frame. Replace as necessary.
REASSEMBLY: Re-insert the panel glass, followed by the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
There are several parts sources available that you can use to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this advice is helpful.
Nov 03, 2010 | Whirlpool MH7140XF Microwave Oven
Own Whirlpool Microwave oven Model MH6141XKQ. How does one clean the "inside" glass of the door. By inside, I mean between the two glasses on the door.
You will need to remove the door and take the door apart to clean between the glass. This process is not that difficult. Just follow these steps:
1. Open the door all the way and lift straight up at the hinges to remove from oven.
2. Place the door, face down on a soft surface to protect the door and glass. A layer of towels on a countertop or table is recommended.
3. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass.
4. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Make sure you remember how the door is assembled as you take it apart. If you forget, the following webistes have illustrated parts listings to show how your door is assembled:
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool Microwave Ovens
How can I clean the door glass thru the perforated screen
Warm soap and water - rinse with just water after..
Please dont forget to rate well ;o)
Aug 11, 2009 | Maytag MMV1153A Microwave Oven
Leaking Microwave door seal (between grated and back of door)
I think that you can get the plastic wet, ie sponge, or lick.
Jun 26, 2009 | Microwave Ovens
Can't clean the inside of the glass door--the screen blocks it
Have to replace the door. You probably removed the protective plastic cover inside the unit intended to keep material from passing through the screen into the area where the glass is located. That was my problem. I thought the plastic was shipping material. My Bad! No way to clean the glass from the inside because they "never imagined" someone would remove the plastic cover.
Nov 10, 2008 | GE XL1800 1100 Watts Microwave Oven
Cleaning inside of microwave door
THE DOOR ON MY MAYTAG MICROWAVE OVEN HAS A SCREEN OVER IT. I HAVE SOME FOOD SPATTERS THAT PENETRATED THE SCREEN AND I CAN'T CLEAN THE GLASS THAT THE SCREEN PROTECTS. HOW CAN I REMOVE THIS SCREEN TO CLEAN THE GLASS?
Oct 01, 2008 | Maytag MMV1153A Microwave Oven
Can't see inside oven
yes, the tape is simply there to protect the face until the consumer gets the product home.
Jun 01, 2008 | GE JES1358 Microwave Oven
Microwave door has burn spots on the glass of the door...
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Whirlpool GH7145XF Microwave Oven Logo
116 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
