Question about Fuji FinePix A345 Digital Camera
I cannot change my setting on my camera from video
I purchased a xd memory card 1gb for my camrea and it is not working. I tried changing the set up and I believe that I have changed so many things that I do not know how to get it back to where it should be so I can use the camera. it is stuck on video but it is also not storing anything in the camera it acts think it is taking a video but i cannot pull it back up on the camea to loo at it.
  • wendy adams Dec 19, 2008
  • 1,800 Answers
Hi.
try to format the SD card in the camera and try to use it in video mode and capture mode.
if that did not work thats means u r facing a hardware problem:
main board ;memory card reader circuit...
Posted on Dec 22, 2008
  • 4,806 Answers
Make sure the "write protect" switch on the SD card is in the off possition, power off the camera and remove the battery for a minute or two, return the battery and SD card and power up the camera, see how you go.
Kind regards and Merry Christmas
    Scholar:
  • 145 Answers
What I understand from your question that you want to reset the settings(correct me if I am wrong).
The simple way to do it is :-
1. Swithcoff the camera
2.take out your memory card
3. Swith on the camera
4. Go to setup and select reset.
Now your camera is in Default settings. Your can start from begining
Posted on Dec 19, 2008
  • 365 Answers
Try to reset the camera.try to check whether the SD card is damaged or you have inserted it in the wrong way.using the reset you can bring back the camera to the old good working state.thank you
  • JITHIN ANTONY Dec 22, 2008
    have you checked all
  • 495 Answers
  • Fuji Master
  • 19,396 Answers
If camera is the Fuji in title, it should support one GB memoryy card, test the card on a different device, the SD card may be defective.
Posted on Dec 17, 2008
  • Ginko
    Ginko Dec 17, 2008
    Take off the battery to reset the camera, then put them back, and try switching the mode selector from video to single picture mode. If it still does not switch, then there is an internal error, probably a defective mode selector , or a fault on the main board.
    In this case the camera must be taken apart and inspected by a technician to fix the problem.
Hi i have an finepixa350 digital camara , i had lost the xd picture card the came with it so i got an Olympus xd m+ 2bg card and it keeps coming back "card error" help!
Your problem is that you have purchased an incompatible memory card.
The largest capacity xD card which your camera can use is 1GB, but it works better with a maximum of 512MB as 1GB can make the camera operations a little sluggish.
There are no updates to enable your camera to use the latest xD cards as the limitation is a hardware issue due to evolving technology.
You therefore only have two fixes: replace the xD card with a maximum 1GB capacity (but preferably 512MB), or replace your camera with one of the recent models which accepts the 2GB xD card.
I hope that I have provided you with a clear explanation and practical options to fix your problem. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Oct 04, 2010 | Cameras
Can I buy a memory card for my camera?
yes. search for these types: *OLYMPUS D-435 Olympus xD-Picture Card / xD Card 1GB (Type M)
OLYMPUS D-435 Olympus 2GB xD-Picture Card / xD Card (Type M)
these are the compatible storage cards for your camera.
Sep 07, 2010 | Olympus Camedia D-435 Digital Camera
Memory card problem? Or camera?
try formating the card again it sounds like it has been reformated or re sized by another program
Aug 03, 2009 | Cameras
Changing memory settings
the camera allows for 8 pics to be taken using its internal memory (IN). If you want to be able to get more images than that you can purchase an xD picture card that gets inserted to the camera that will allow for more images to be taken and stored. The camera more than likely supports 1gb or 2gb capacities of xD cards.
May 27, 2009 | Olympus X-875 Digital Camera
My new memory card will not work for the Olympus Camedia D-560
The problem is that the largest xD card that your camera can support is an M or H 512mb card. The 1gb card is not compatible. The firmware in the camera cannot support memory storage with that capacity. The camera came out before those cards did and there no plans to upgrade the camera to allow those types of cards to be supported.
Apr 04, 2009 | Olympus Camedia C-350 Digital Camera
Olympus c-740 reads card error when 1gb xd memory
its non supportive to 1gb card as you will have to get the device upgraded to make it support 1gb.
Mar 03, 2009 | Cameras
Memory card
Fuji uses 16MB xD card with the camera, which won't hold too many 4 Megapixel photos at the highest quality setting. So you should plan on buying a larger card right away. xD cards are currently available as large as 1GB, and I think 128MB is a good starter size for most people. Be warned that xD cards tend to be more expensive than CompactFlash and SD cards.
Jun 13, 2008 | Fuji FinePix S5000 Digital Camera
Blurred subjects
Fuji uses a 16MB xD card with the camera, which won't hold too many 4 Megapixel photos at the highest quality setting. So you should plan on buying a larger card right away. xD cards are currently available as large as 1GB, and I think 128MB is a good starter size for most people. Be warned that xD cards tend to be more expensive than CompactFlash and SD cards.
Jun 05, 2008 | Fuji FinePix S5000 Digital Camera
USB device not recognized
you can buy a memory card that suites your camera ( xD, sD, MMC) you should see your camera manual to find what type of those memory cards works with it, then transfer the images to the card. after that, you can buy a memory card reader for cheep from best buy or whatever store and transfer images to PC easily.
Dec 27, 2007 | Samsung SC-MM10S Camcorder
Olympus XD card low level formatting help needed
purchase another card (smaller memory and cheaper...as a test). install it. if it works, then read file folder names under windows and then copy these folders over to the 1GB card.
Jun 03, 2007 | Olympus Camedia D-540 Zoom Digital Camera
Fuji FinePix A345 Digital Camera Logo
19 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
