I have a computer with a FIC VI13L Motherboard that is suppose to support 3GB of memory. But when I insert 2 1GB memory sticks, reports "Insufficient memory to initialize Windows. Any suggestions?
  • Sandy426 Dec 19, 2008
    The memory sticks are labeled: 1GB DDR-400 PC3200. Are they the right ones?
  • Sandy426 Dec 29, 2008
    The memory sticks have 1GB DDR-400 PC3200 on their label are these compatible with this motherboard?
    Problem Solver:
  • 7 Answers
Is it the right type of memory stick? the ram should be DDR SDRAM.
Posted on Dec 16, 2008
How do I connect the front panel speaker and microphone jacks to a FIC VI13L motherboard? There are a total of 5 wires: Spk L, Spk R, M IN, M BIAS, and GND.
Hello try to download the manual from here:
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=109
The manual will show you how to connect the wires.
Or visit INTEL here:
http://www.intel.com/support/motherboards/desktop/sb/cs-015851.htm
You probably need the AC97 configuration, Not the HDAUDIO
If you connect it wrong you will burn the sound chip !!!!!!!
Best of luck
Aug 06, 2013 | Computers & Internet
Gateway gt4016 motherboard
It has Parallel ATA
PATA or also generally known as IDE,
http://en.wikipedia.org/wiki/Parallel_ATA
1) Harddrive:
101311 - Western Digital, 200-GB, 7200RPM, PATA harddrive,
http://support.gateway.com/s/PC/R/1008842/1008842cl2.shtml
2) Motherboard:
105553 FIC KTBC51G
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553nv.shtml
Product Views; F - Primary IDE Connector,
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr7.shtml
Left side of motherboard, near the black long Ram Memory slots.
This is where the Harddrive plugs in.
Product Views; E - Secondary IDE Connector;
http://support.gateway.com/s/MOTHERBD/FIC/105553/105553mvr6.shtml
Near the black long Ram Memory slots, and next to the blue Primary IDE Connector.
This is Serial ATA, or also known as SATA,
http://en.wikipedia.org/wiki/Serial_ATA
Uses this style of SATA data cable, and connector on motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
(NOTE* Color does NOT matter for cable connector.
Color really doesn't matter, for a SATA connector on the motherboard, either.
You are supposed to plug the Primary SATA harddrive, into the SATA 1 connector, on the motherboard.
The beauty of SATA is, that you can plug into any Ol' SATA connector on the motherboard, that you want to.
BIOS will find the harddrive with the Operating System on it, and will find all the other SATA devices plugged into the motherboard, too )
You do NOT have SATA.
Regards,
joecoolvette
[You may be interested in this,
What's Inside: Computer > Computer Hardware > Explore These Categories,
http://computer.howstuffworks.com/
Also to the left;
Computer Peripherals
Computer Security
Computer Software
Internet
And,
http://www.hardwaresecrets.com/
Click on the headings at the top;
Case, (Computer cases), Cooling, CPU, (Processor), Input, Memory, etc.
Has basic information leading up to technical ]
Nov 30, 2012 | Computers & Internet
How many slots for dram chipsets? For AZ11/ AZ31 motherboard? Thanks!
FIC AZ11 (First International Computer {Inc}
3 Ram Memory slots.
Supports SDR Sdram at 100MegaHertz, or 133MHz. (PC100, and PC133 respectively)
Maximum Total Amount is 1.5GB
Maximum Amount for EACH ram memory slot is 512MB. (1/2GB.)
Uses the VIA KT133 motherboard chipset,
(Northbridge - VIA VT8363
Southbridge - VIA VT82C686A/B)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Socket A processor socket for AMD processors. (Also referred to as Socket 462)
http://www.xbitlabs.com/articles/mainboards/display/fic-az11.html#
FIC AZ31
3 Ram Memory slots
Same type of ram memory as above, same total amount, and amount for each ram memory slot.
Uses the VIA KT133A motherboard chipset.
(Northbridge - VT8363A
Southbridge - VT82C686B
Socket A processor socket.
http://en.wikipedia.org/wiki/Socket_A
http://www.baber.com/baber/411/fic_az31.htm
Oct 30, 2010 | FIC AZ 11E Motherboard
I need the network drivers for FIC VI 13L Motherboard
Your required name is Realtek 8201 You can download it from this link, http://download.driverguide.com/driver/VI13L/FIC/d225785.html Just click on the "DG DOWNLOAD" button. Good luck..
Jan 15, 2010 | FIC VI 13L Motherboard
Where do i put he memory
From the manufacturer's web-site:
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=557
look at the "green" slots in the picture of the motherboard.
That's where the RAM goes -- note that the RAM has a "notch" that is *NOT* in the "centre" of the stick; so, the RAM only fits *ONE* way into the slot.
On that web-page, it says:
• Supports six memory banks using three 184-pin DDR SDRAMs.
• Supports up to 3GB memory size.
• Supports DDR400/DDR333/DDR266/DDR200 SDRAM
Note: PC3200 (DDR400) maximum 4 banks only.
So, if you buy DDR400 RAM, the maximum is 2GB (2 sticks @ 1GB/stick); if you buy DDR33 RAM, the maximum is 3GB (3 sticks @ 1GB/stick).
Dec 01, 2009 | MSI Microstar KT6 Delta (MS-6590)...
Unusable memory
When you reformat a memory stick it creates a trash folder which stores all the data incase you need to use it again. Put your memory stick in your psp then connect your psp via usb to a computer, in the computer view of the momory stick make sure you have the 'view hidden folders' option checked, then delete all folders & files on the stick. Remove the psp from the computer & reformat it again you should find 8gb available again
Jun 01, 2009 | SanDisk Memory Stick PRO Duo for...
Asrock p4s61, tried 1gb pc3200 to max memory to 3gb, won't boot.
you quote one of your memory sticks as being pc 2700 when earlier in your text you qoute pc3200.
Firstly pc 3200 is 400 mhz clock speed memory.Secondly, pc 2700 is 333mhz clock speed and you acnnot mix the two on the same board. Thirdly does your board support 3ghz anyway. If you are running a board at 400mhz, pc2700 memory will not run at 400mhz.
Solution, take out the pc 2700 memory and all will be well.
May 02, 2009 | Asrock P4S61 Motherboard
Memory upgrade issue
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
Jan 23, 2009 | FIC K8-800T Motherboard
RAM Memory
If the memory modules are PC2700 or higher, they need to be installed in Slots 2 & 3, slot 1 only supports PC2100 & lower. I had the same problem with mine. Also, make sure the BIOS is set to "AUTO" under the RAM settings. Hope this helps.
Dec 16, 2008 | FIC VI 13L Motherboard
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
