The power zoom function doersn't seem to ne working...no matter what focal length on the lense,,,Nikon ompatible lense- the indicated focal length on the SB-600 stays at 14mm. Any ideas...
I struggled with this one but then, on the basis that if all else fails read the manual I found the answer. It's soooo simple. The wide-flash adapter is set. That's the little pull-out screen at the top of the flash which folds down over the flash-head. If it's pulled forward it activates the wide angle setting automatically. Push it back in and you'll be fine. tony k
Just spent 2 hours trying to resolve this problem so top marks to the guy who said:
"Simply push the Wide Flash Adaptor fully back into the flash head until it clicks and BINGO. That's was all that was causing it to remain on the 14mm wide angle setting.
You can re-set your flash by turning on its power then remove the batteries for a few seconds and replace them. Also, if have not done so switch to NiMH rechargeable batteries. Costco=20 bucks
I have done this all (with teh Batteries) but the problem still exists.
It is not possible (by pressing the "Zoom" switch) to change to the automatic mode.
I am unable to activate the power zoom function. Pressing zoom does not make the "M" disappear. The focal length remains at 14.
POWER ZOOM DOES NOT WORK
HELP ME OUT
[email protected]
Same as jimdadma: the power zoom is stuck at 14mm and I cant get the M to go away
Thanks...it worked...the wide angle adapter was down and fooling the lense
I can manually zoom but can't turn off the M so that auto zoom will work. I don't even see that on the CSM. This is all I see on the CSM. Wireless remote flash mode, Sound monitor, Auxiliary ready-light, LCD Power Illumininator. I do not see menu choices for Wide-Area AF-Assist Illuminator, Standy function or Poiwer zoom function. Holding down the zoom button does nothing.
