Question about LG HBM 730 Bluetooth Headset Wireless Headset
Print the manual
I attempted to print the manual from my tool bar. The print is so small I cannot read it. Is there a way to print my manual so I can read it?
This problem can be addressed with adjustments to your "Print" window screen that comes up after you click "print" on your Adobe toolbar:
When the "Print" window comes up, click in the "All" button, then move you cursor down to the drop-down list for "Page Scaling" and chose the "Fit to paper" option. make sure the "Auto-Rotate and Center" box is checked (if you usually print "portrait"). Then click OK.
It should come out alright. Here is the URL of the Manual for the LG HBM-730 that I printed from using these adjustments: http://www.megaaccy.com/HBM_730.pdf.
Posted on Dec 30, 2008
I need to know how to take the fuse box under the hood of my 2005 Chevy Impala so I can put a new one in.
Underhood Electrical Center or Junction Block Replacement
Removal Procedure
  1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
  2. Click to Enlarge
  3. Disconnect the positive battery cables from the underhood fuse block terminals.
  4. Remove the tape from the wiring harness at the base of the underhood fuse block base.
  5. Click to Enlarge
  6. Release the underhood fuse block(s) clip retainers using a small flat-bladed tool.
  7. Click to Enlarge
  8. Remove the fuse block(s) and wiring harness lifting up from the base and reposition from the base.
  9. Click to Enlarge
  10. Remove the nuts from the underhood fuse block base.
  11. Remove the underhood fuse block base from the shock tower.
  12. Click to Enlarge
  13. Remove the underhood fuse block lower front terminal positive assurance retainers using a small flat-bladed tool.
  14. Click to Enlarge
  15. Remove the plastic shields from the battery cable and buss bar terminals, using a small flat-bladed tool to release the clip retainer.
  16. Click to Enlarge
  17. Remove the bolts from the buss bar jumper bar.
  18. Click to Enlarge
  19. Remove the buss bar jumper bar from the fuse block(s).
  20. Click to Enlarge
  21. Remove the fuses from the fuse block(s) to access the buss bar terminal release tabs.
  22. Click to Enlarge
  23. Remove the buss bar(s) from the fuse block(s) using a terminal releasing tool, and pulling down and out on the buss bar.
  24. Click to Enlarge
  25. Remove the buss bar(s) from the fuse block(s).
  26. Click to Enlarge
  27. Release the clip retainers from the underhood fuse block(s) battery cable and buss bar terminals using a small flat-bladed tool.
  28. Click to Enlarge
  29. Remove the underhood fuse block(s) battery cable and buss bar terminals from the fuse block by pulling down.
  30. Remove the fuse block and lamp wiring harness from the vehicle, if required.
I copied the info from my database, sorry, it is read only, The way I copied it, read only, no pictures.
Jan 28, 2018 | Chevrolet Impala Cars & Trucks
Will elements 12 work in Windows 10 as Tool bars are too small to read?
Hold down the CTRL key and scroll your mouse wheel.
Or View - Zoom.
To go to 'normal 100% Zoom press CTRL+ 0 (zero).
Nov 18, 2015 | Adobe Photoshop Elements 12 - Mac/Windows
Enlarge text size
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text sizes largest to smallest and Full screen option
Increase the Font Size in Email
Email font size is easily controlled while composing messages, but the messages you receive have been sized by the sender.
Some contacts may be perfectly comfortable writing in size 8, but such text can be a strain on the eyes, even with good reading glasses.
The printed hard copies of email messages with small text are even more difficult to read.
There are a few ways to quickly change font size for ease of reading and better quality print-outs.
Open an email message with particularly small text. Increase the email font size of the text using step 2, 3 or 4.
Click on the "View" selection from the menu bar.
Roll the mouse pointer over the "Zoom" choice.
Click on one of the choices that is greater than 100 percent.
Click "View" and cover "Zoom" to make a larger choice if the first choice does not increase the text size sufficiently.
Click the "View" option on the menu bar. Roll the cursor over the "Text Size" selection.
Choose one of the options that will increase the text size.
For instance, if the current size marked with the dot is "Medium," then click "Larger" or "Largest" to make the print appear bigger.
Use a mouse with a wheel to increase the email font size.
Press and hold the "Ctrl" key while rolling the wheel on the mouse.
The text will shrink as you roll in one direction, and grow bigger as you roll in the other.
Change font size before printing.
Click the "File" option on the menu bar.
Click "Print Preview."
Click the "Size" drop down which may display "100%," or "Shrink to fit."
Select a choice greater than 100 percent to increase text size.
Click the "Print" button to view the results on a hard copy.
Nov 13, 2013 | Computers & Internet
The print on my desktop computer is too small for me to read.
Right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar this will add to your screen toolbar File Edit View Favorites Tools and Help select the view tab from the drop down list will be a Zoom with percentages %
and text s largest to smallest
Hope this helps.
Dec 15, 2012 | Computers & Internet
When I print my telus bill the font is very small, hard to read.. (I wear glasses). When I print a copy of the bill from PDF , the font is larger ??? When printing from thr internet,ie: recipes, if I
Which browser are you using? Internet Explorer? Mozilla Firefox? Opera? Google Chrome? Safari?
If you are using internet explorer: Click Tools/View/Text Size and change it.
If you don't see tools at the top of your browser on a line that says File/Edit/View/Favorites/Tools/Help look for tools over on the right then click it and select Toolbars, then select Menu Bar and it will stay at the top of the browser so you can just click Tools/View/Text Size
If you have Windows 7 press and hold the ALT key for the menu bar to appear at the top of the browser.
Apr 01, 2012 | Computers & Internet
How do I change the font size ?? The lettering is far to small.
Apr 01, 2012 | HP Pavilion dv6000z Notebook
Large print manual for cell GT E1080i (not able ro read small print on manual)
They do not print manuals with a large print font. I suggest you use a magnifying glass to read the manual.
Jun 01, 2011 | Samsung Cell Phones
The print in the manual is so small I cannot read it. I need a larger printede manual
You can zoom in and out from the view menu if it is a pdf file or word file. If it is editable, you can change the font size by using the edit menu or a font bar on the top.
Nov 27, 2010 | Computers & Internet
I can't read the manual, it,s too small How can I get a larger manual with larger print?
You could search for the manual online, download it, and use window's magnifying tool to read it on your computer.
Sep 27, 2009 | Jensen Audio Players & Recorders
LG HBM 730 Bluetooth Headset Wireless Headset Logo
239 people viewed this question
Top LG Radio Communications Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
