Question about Dryers
Burner would not stay on
No heat build up due to burner keep shut off every minute.
  • zukondalat Dec 16, 2008
    Hi Will
    (Thermocouple or overtemp device). My service book does mention about the hi-limit thermostat switch, but I am not quite sure it's the problem.
    Do you think the air restricted after the blow turned on?
    Thanks you.
  • zukondalat Dec 17, 2008
    Hi Will
    It's Maytag high capacity commercial dryer (DG32). The burner repeatly shut off every 5 seconds while the machine was running (this operation starts out at cold condition).During that 5 seconds span, the burner was normal but the heat was not there (enough to dry anything). First, I thought the cold down switch but I was wrong. At this stage, I will by pass the high low temp switch.
    Thanks you.
    Scholar:
  • 68 Answers
Bad or weak thermocouple, or bad or weak overtemp device, there are probably two of the overtemp devices look like a huge button in many cases, if it has a thermocouple that is also a probable cause, it could be a thermal on the motor, but I doubt it, jump out the thermals and see if stays on, if so that is the bad part, if it has a thermocouple replace it, if it is of any age it won't hurt to change it anyway.
Will
Posted on Dec 16, 2008
  • William Babbitt
    William Babbitt Dec 16, 2008
    I won't rule it out, the motor could cut out, but are you saying the air quits or just blows cold?
    Lets do this
    Start at the beginning, when it started, how old the furnace, the model and serial again, details as best you remember in the order it started to fail on you.
    If you are blowing warm air, and then two minutes later blowing cool, it is most likely a limit.
    If you are blowing hot for two minutes and then nothing, that is another story.
    Give me all the details no matter how unimportant, and let's do a clean paper start on this.
    Will send to wbwill@sbcglobal.net
Model # UOBC-112QBGA The burner kicks on then the blower. After a few minutes the blower shuts off but the burner keeps running until it hits the high limit switch and shuts off
if when blower shuts off if still voltage to motor bad motor over heating if no voltage check board and safety circuit also see if overheating
Mar 22, 2018 | Heating & Cooling
My majestic fireplace lights and the burner lights and I turn on the switch and the burner stays lit for a minute or two then I hear a click and the burner and pilot light shut off
yes this would appear to me to be the classic symptoms of a bad thermistor , this little device proves that fire has lit (via heat) and keeps gas valve open , otherwise gas valve times out and shuts off (safety)
Oct 15, 2016 | Majestic Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
Raypak 403A, burners will not stay lit for more than a few minutes.
i'm thinking after the main valve opens the pressure could be dropping in the pilot tube. this could be due to a dirty, plugged and sometimes spider web inside the pilot tube. rare but does happen, nice warm home for a spider. good luck. if not let me know. could also be weak pilot coil.
Jun 09, 2017 | Pool & Spa
Hi I have an xl80 the burner lite and heats up till at desired temp, after burner goes out the fan keeps on running 15 minutes or so. If I go down and shut off power switch to furnace then the fan shuts...
Hi, sounds like you have a problem with the heat anticipator in the thermostat. If you replaced the fan limit, and with it running that long after the burners shut down, it would be in your stat. If it fires up after resetting breaker, was the stat set to call for heat? If not, the stat is faulty. If you remove the front to get to the stat wires, take a jumper wire and jump from RH or RC to W. Heat will start. Let it run for a minute or so and remove wire. If the fan shuts down with in a min. or so, you will know it was the stat. Good Luck and let me know the out come!
Shastalaker7
A/C, & Heating Contractor
Feb 11, 2011 | Heating & Cooling
Dry will not blow heat
Check the entire exhaust vent tubing before buying anything for this dryer to repair.. Most dryers only need a good cleaning to get the heat back running correctly. A moister sensor is working if the lint build up is more than just dust in the vents tubes. Any build up the sensor detects and keeps the heat off. Sometrime you will get heat for awhile although it will shut the burner down quit soon
Jun 09, 2010 | Amana NDG2335AW Gas Dryer
Dryer not staying on.
High limit trips due to over heat. Clean vent and line and filter.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 06, 2009 | GE DBSR453EBWW Electric Dryer
Furnace runs about 1 minute, then total shutdown
What type of gas supply line do you have? Is it black pipe or copper? If it is copper, there can be a film like substance that builds up on the inside of the copper. The debris will the get caught in a pre screen where the supply enters the valve thus cutting the supply of gas to the unit. Also, the thermocouple may be bad. You didn't say that you replaced it. Try replacing it as well. Also, you could have a limit switch turning the system off and thus cutting the gas off completely but it is highly unusual for the pilot to be cut off as well unless the pilot is being blown out when the gas is shut off. Also, turn the unit to fan only without calling for heat. Using a flame of some sort, put it into each baffle of the heat exchanger. If your flame is being blown around in one of the baffles, then you have a hole in the heat exchanger and what is happening is that the roll out switch is cutting the unit off and the air still moving through the heat exchanger is blowing the pilot out. I have seen this actually happen. If your furnace is in excess of 15 years old, it does need to be checked for possible holes. If it is in excess of 25 years old, it is a huge possibility that the unit has already developed a hole. If you feel hair coming out of one of the baffles, then shut the unit down immediately and have it replaced!
Apr 05, 2009 | Heating & Cooling
Open Questions:
Dryers Logo
101 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
