I just got my speakers but there is one problem, the left speaker plug doesnt work. Both speakers and the subwoofer work but when i plug the left speaker in there is no sound through that speaker. Is there anyway to fix the plug?
I have the same exact problem. This is why I don't like speaker cables that are permanently attached to the speaker. Arg. Now I have to go through the hassle of returning these!
Allstar, A good place to start would be the jack of the malfunctioning speaker, the cable that connects it to the speaker or the jack it plugs into. You?ll need a multi-meter to test and isolate the fault and a soldering iron and associated tools once you find the fault. Less likely but still possible is the chance that the system amplifier could be at fault. Before you start tearing into your speaker remember that doing anything will void your warranty. I strongly suggest that you simply return the unit to the reseller you got this from noting that it was defective upon receipt. Let us know if you have any other questions and please don?t forget to rate this post.
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
same problem.. it is frustrating especially since only a week old
