Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Blwoing cold air
I have an Amana Air Command Eletric Furnance and it just started blowing cold air. ANy suggestions?
  • Ken Bledsoe May 11, 2010
    Sounds like the element is not engaging. Do you have volt ohm meter?
    Guru:
  • 462 Answers
Possibly, A thermal fuse located in the heater element circut could burn out. the CIrcut would show full voltage to the element but no heat out. Often there is also an auto reset high limit swich this could be out also opr instead of the fuse. THE FUSE IS ALWAYS LOCATED WHERE IT CAN "SEE" the elements. I E Inside the case where the elements are.
Posted on Feb 28, 2009
Is the thermal fuse connected directly to the element. Also if it is not that what else could it be.
Posted on Mar 13, 2009
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Furnance comes on but the air stop getting cold just blows air ....what could be the problem
It sounds like it could either be low on refrigerant or the compressor has stopped working. Start by verifying that all the breakers and controls are in the on position. If the outdoor unit is running but you have no cold air, you may need a HVAC company at this point.
Sep 08, 2013 | Ruud UBHC Air Conditioner
Ac turns on and the fan blows air but not cold air. When switching from fan to ac mode i hear a buzz sound like it had switch to ac but still its not blowing out cold air. Any suggestions?
mcdevito75, Needs service either a chrge of freon or the need for a new thermostat and That is what it sounds like to me, (the compressor could be bad also, the buzzing sound) hope not expensive repair.
Jun 23, 2010 | Amana PBC101A00A Air Conditioner
Amana gas furnace,air command 80 sv. does not ignite blows cold
Hi check out the pressure switch jump it out and see if it lights also check the igntion coil is glowing
Feb 09, 2010 | Heating & Cooling
Furnance just started blowing cold air, checked reset button..checked filter???
Check if they have a "sail switch" that senses combustion air flow before allowing fire. These are a small vane in the combustion air intake that moves a microswitch when air is flowing.
Dec 16, 2009 | York Furnace Draft Inducer Blower Fasco #...
Furnance not heating
Make sure that the thermostat is set for the proper medium that you are using being gas or electric. Inside the cover of the thermostat should be a setting for either eletrical heat or gas heat. Set this switch for what your system is G for gas or E for eletric. This may solve your problem. Good Luck hope this helped you some
Dave
Oct 26, 2009 | Intertherm P3RA-036K Air Conditioner
Air is barely blowing out of the vents, hot or cold.
The blower motor resister shorted out common problem. It is located behind the glove box on the HVAC assembly.
Jul 16, 2009 | 2004 Jeep Grand Cherokee
Rheem criterion gas furnace
Check freon, you will need guages on the condensor, also make sure the cond, outside unit is operating
Jun 14, 2009 | Amana Comfort Zone 12M32PBEH Air...
Amana PTH123B25AJ Heat Pump Air Conditioner Logo
242 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
