Casio G'zOne Boulder Cell Phone Logo
l edwards Posted on Aug 04, 2012
My phone doesn't recognize a micro sd card
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Aug 04, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
4998
Points
99
Check the card slot points and restart the cellphone after putting card
  • Gavin Rieser Oct 13, 2013
    That's a terrible solution. What if you just put it in and made sure everything was right? What then?
Micro SD slot in my Kyocera Hydro isn't reading Micro SD card
test the sd card on your pc first to see if it works before you put it into your cell.
HTC inspire doesn't recognize micro SD card
Please restore fact your mobile and then see.
1helpful
2answers
How do i shut off write protection
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
1helpful
My micro sd card is locked how to unlock
3helpful
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
How do I upload pictures from my Samsung Strive onto my Gateway laptop comuter.
1. Purchase a micro-SD card with an adapter for a normal-sized SD card.2. Plug in the micro-SD card to the back of the phone. Make sure the power is off when you do this, of you could unintentionally harm your phone.3. Power back on, and transfer the pictures to the micro-SD card.4. Shut the phone back off and remove the card again. Place it into the adapter.
If your Gateway laptop has a SD card reader:
5. Put the adapter into there.6. Transfer the pictures to you computer. Done!
If your laptop doesn't have a SD card reader:
5. You'll need to purchase a second adapter that adapts the regular-sized SD card to a USB port.6. Following the manufacturer's instructions, put the SD card into the second adapter.7. Transfer the pictures to your computer. Done!
Best of luck, Juseppi
I just uploading the data from my laptop to my micro sd card, it's been loaded but after if we unpluged it from laptop & load it in phone then only one Folder sowing the data & rest are...
Try to reformat your micro sd card using your phone, then plug it into your pc to copy files. Don't forget to properly eject your sd card not just unplugging it. If this doesn't work try reformatting it using your pc then properly eject it.
1helpful
2answers
Hi i have got new memory card and i put it in my lg ks360 . when i send some song to my phone it said my phone memory is full . but my micro sd's card is blank. so could anyone help me . so all the sound...
yes you need to format it. You can go to settings or tools menu and find "memory card" in there should be an option to format card. That's what you need! Rate high!!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/steven_958e67a4edcc47d5
May 03, 2011 • Cell Phones
Top Casio Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
