Question about KitchenAid KUDR01TJ Dishwasher
No power on KitchenAid (KUDr01tj) dishwasher
Dishwasher ran last night and appears to have not completed the cycle. Water in bottom of washer and no power on control panel. Same problem about a month ago - replacing the fuse resolved problem but appears to have happened again. Any thoughts on what to replace next? I'm thinking the heating element - I'm supposing that since it's the biggest power draw in the box that it's going intermittent...
  • 2 more comments
  • Jerry Counselman Dec 18, 2008
    Very similar problem, but happening each time we try to run unit after putting in new fuse. When turn power off to circuit then take out & reinsert the new fuse again, it seems to work, then stops mid cycle again leaving no power to unit and water in the bottom.
  • LenNagy Jan 01, 2009
    power coming in via cable, but buttons don't work.
  • rlrobbins1 Apr 12, 2009
    I appear to have power but the bottons don'e work. I just noticed today that there was water in the bottoms so it must have also gone through a partial cycle. If it is the fuse, where is it located?
  • 121 Answers
You must have fuse 16 amps or 20 amps.16A is enough if is heater
OK.If heater is broken You must replace it.
Posted on Feb 15, 2009
My new dishwasher wont completely drain?
Hi if the electrician installed your dishwasher Or (fixed it) he didn't !!, I'd ring the electrician and get him back....AND SHOULDN'T COST ANY EXTRA.......
Mar 18, 2016 | KitchenAid Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
When I turn on dishwasher, water not cycling through and cleaning on a kitchen aid dishwasher
you may have a defective water intake valve. common problem
Please give rate/vote on this response thanks
Dec 19, 2010 | KitchenAid KUDR01TJ Dishwasher
There is water sitting in the bottom after all the cycles finish I tried to cancel and rinse to no effect.
9 times out of 10 there will be debris stuck in the pump impeller... access from the bottom of dishwasher by tilting to side or back... common fault...
Oct 03, 2010 | KitchenAid KUDR01TJ Dishwasher
No power
check the thermal fuse located on electronic control 2 inch square fuse problalby no continuity through it, Replacemant comes with wires attached and instructions for installation
Feb 20, 2008 | KitchenAid KUDR01TJ Dishwasher
KitchenAid KUDR01TJ Dishwasher Cleaning Problem
Sinder...this sounds more like a water temperature issue than anything else. First, turn on your hot tap. If you can't hold your hand under it after it fully heats (over 125)...you should be okay. If not, raise your water temp or use the sani cycle to raise the temp. Change brands of detergent. Salt...I don't think so. You're using detergent...not soap...which would have been affected. Pressure should not be an issue...once the unit is filled, it makes its own pressure recirculating with the wash pump.
Oct 13, 2007 | KitchenAid KUDR01TJ Dishwasher
KitchenAid KUDR01TJ Dishwasher Logo
566 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
