Question about Mitsubishi VS-60805 60" Rear Projection Television
Mitsubishi Lamp is OUT
How hard is it to replace,I can fix just about anything.....Please let me know.Thanx!
  • 1,512 Answers
Hi ifixall
If the model you have listed your problem against is true for you, then you have a CRT set on your hands. Can you confirm model please. It does not have any lamps. You would also be hard pressed repair this set if you were not familar with television or electronic repairs. If you were just testing my ability to inform you correctly...did I pass the test
regards
robotek
Posted on Dec 17, 2008
  • 25 Answers
Replacing the DLP Lamp is actually pretty easy, all you'll need is a screwdriver, gloves, wire cutters and the new Lamp. Now the exact steps you take all depend on what brand and model you have, so I can't tell you exactly how to install it over the internet. However, if you haven't already bought your new lamp replacement, I suggest getting one from DLP Lamps.com. Each order comes with easy to follow instructions and even gloves! And if you get lost during the installation process you can call them up and they will walk you through it step-by-step. Hope this helps!
Posted on Dec 16, 2008
  • 3 Answers
Replacing the lamp is as simple as it comes. Consult your owners manual for step-by-step instructions. It's designed for the customer to change.
I have a 60inch DLP HDTV with we dots all over the screen. Can I do anything? Is it a bulb or lamp?
bad DMD chip
call Mitsubishi , they will send one to a servicer at no cost
you will only pay for labor
Sep 15, 2014 | Mitsubishi WD-60735 60" DLP HDTV
How to check lamp timer
Bulbs do not really have a certain lamp life they only have a lamp timer. You will want to be sure you can get a replacement lamp they can go anytime between 0 and 6000 hours.
Apr 22, 2013 | Mitsubishi SL2U Multimedia Projector
I have a Mitsubishi WD-62525 TV the lamp red light started to to flash red so i replaced the lamp did not fix the problem so i replaced the lamp ballast light is still flashing red...can someone please...
please count the flashing led light on the front..
after you count click this link www.fixya.com/users/bugoy31
then choose any of my services to help you fix it..
Feb 03, 2012 | Mitsubishi Televison & Video
I have a mitsub. model # wd- 65835... I turned my tv on and it will have the two clicks like it's about to come on (no pic), then it'll go off. The "lamp" light is on "red" do I need to...
Yes change the lamp. It is easy to do. All you need is a phillips screw driver and possibly a flat head. The cartridge that holds the lamp slides out.
Mar 14, 2011 | Mitsubishi WD65835 65" HDTV
I have a Mitsubishi 73"
I'm sorry, but your looking at an Optical Block Assembly which also includes the DM module. Latest figures are approximately $650.00 to replace. I would have called a service tech out to properly diagnose the problem first. Please let me know if you have any other questions.
Jan 18, 2011 | Mitsubishi WD-73735 Television
SCREEN IS BLACK ,BUT HAS SOUND
this is most likely just a lamp issue this lamps a made to last a average life span of 2-3 years of use
replacing the lamp should fix your problem that is the first thing to replace in this cases
here are few good online stores that have the lamp you need
http://www.discounttvlamps.com/915P028010-Housing-p/mitsubishi-915p028010-enc-ph.htm
http://www.discount-merchant.com/Mitsubishi-915P028010-915P028A10-Lamp-Enclosure-p/mitsubishi-915p028010-lamp-enc.htm?1=1&CartID=0
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!
Nov 05, 2010 | Mitsubishi WD-62528 62" LCD HDTV
Mitsubishi DLP - model #WD62725
We're under a service plan and had the guy out today. Same symptoms. He replaced the lamp and it didn't work and then called Mitsubishi. They said it is probably a very common capacitor problem on the power supply board. If you open the back and take a look you are likely to see bulging caps. Parts C9A37 and C9A38. The caps are cheap if you can find them, but the parts are really hard to find right now so Best Buy is actually replacing these for people under service plans rather than fixing them. You probably ignored the "warning signs" like we did and didn't think much of it when the TV said there was something blocking the air flow and the lamp was going to shut off. We now know this is a sign that the caps are getting too hot and need to shut down to cool off... Good luck! BTW, our guy said the repair will run you about $200 if you can't do it yourself.
Aug 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Dead lamp!!!
is it tha lamp cracked? are you using original lamp from mits? i founded people using aftermarket lamps with other specks this lamp is 150 watts ,this info its going to help.
if components on the Power board K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects are a deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010 let me know if you need anything else
Jul 04, 2008 | Mitsubishi WD-57732 Projection Television
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
