Candian customer trying to see netflix canada on a dvd that I bought in canada only good for US Netflix
SOURCE: Region Problem
To change the region perform the following actions: Power on Player /Open/ (/eject/), then on remote /stop/ then /9735/ and then go to /setup/ and choose no region. It should know play all disks. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Philips MCD716
1.Press DVD "OPEN/CLOSE" key (RC (remote Control) or main unit) to open the DVD tray (note:if no disc on tray,then you have not to open it);
2.Press RC "SYSTEM" key to enter DVD system setup menu;
3.Press RC "direction "key to hightlight the forth item "PREFERENCE PAGE" (not entering the sub-item );
4.Press RC numeric key sequentially 811502(enter code, however no display on TV);
5.Press RC "down direction" or "up direction" key to change REGION CODE,"0" is all code.
6.Press RC "OK" key to confirm.
7.Press RC "SYSTEM" key to exit DVD system setup menu
SOURCE: Philips mini DVD PET702/75 multi region unlock code
To check the software version and change
region code of your DVD Portable
1. Power ON the DVD player and open the DVD
door
2. Press the “SETUP” button on remote control,
then select the “Preference MENU”
3. Press the remote button in the sequence as
9 -> 6 -> 5 -> 3
4. The LCD display showed the existing region
code. Press (navigation up) or
(navigation down) repeatedly to select the
number from 0 to 6.
5. Refer below table for your region code setting
Region
1=USA
2=Europe
3=Asia Pacific
4=Australia, New Zealand
5=Russia, India
6=China
Select “0” setting = Region Free (confidential)
SOURCE: multi region code for philips hts 3090 dvd player
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
I've done this to my 3090 and been using it like this for 3 years.
SOURCE: My DVD player isn't multi-regional
Here's the regionfree code..
1. Open Tray
2. Press 9,9,9,9,0
3. Press open/close to close the Tray
4. Regionfree..
Jay
