Question about Refrigerators
I am inquiring about a Northland wine cabinet model CWC075B The cabinet section was damaged in shipping but is repairable, I need to replace a piece of trim and need a new handle. The door was dented were the handle is fitted but the insulated glass and frame are perfect. The side panel has 2 minor dents but they are not visible after the unit is installed or the optional side panel are added. Where can I get these needed parts and how much would it cost for the parts? Also, is replacing the above described components something that can be done fairly easily or would I need to hire a professional service company?
  • 26 Answers
Http://www.appliancepartspros.com/ can help you with most issues and are reasonably priced
Posted on Dec 16, 2008
N'finity wine cooler
call the repair man if probably needs recharged with freon
Feb 16, 2015 | allavino MWR-1682-BL-C 170 Bottle...
Tip
Sink Cabinet Replacement Bottom
IF your sink cabinet bottom is water damaged and in need of a replacement, this video gives step-by-step how to information for fixing it. This video was created by a cabinet professional who specializes in fixing Formica kitchen cabinets.
It is very informative for the person who likes to do it yourself" when it comes to repairing things around the home.
Tools and materials needed:
Saber saw
Diagonal cutters
Hammer
New sink cabinet bottom
Caulking
Caulk gun
Clorox Bleach
Three Support Struts
L-brackets
Finish nails
How to do the Repair:
Take the doors of the kitchen or bathroom cabinet off.
Remove the water damaged sink bottom by cutting it in half from front to back. You may need to use the hammer at this point. Just be extremely careful to not damage the plumbing.
Break off the staples with the diagonal cutters.
Clean the mold with the Clorox Bleach.
Install the struts designed to support the new sink cabinet bottom. Use L-brackets if necessary for attaching the center piece.
Install the new sink cabinet bottom replacement board. Attach it with finish nails.
Clean the inside of the kitchen or bathroom vanity cabinet.
Caulk all interior areas of the sink cabinet bottom.
Replace the doors.
Every sink cabinet is built differently. Make sure to examine how the cupboard was built to determine the best method for replacing the bottom of the cabinet. If you have a center style, you will need to cut it out and reinstall it using L-brackets.
on May 26, 2010 | Home
Cannot get temperature below 65F. Probably need replacement cooler unit. Model: AZMN HAL Odyssey Approx Size: 9" H x 15.5" W x 14" D. Serial #: AA4-Odyssey-01201-121
I have never heard of a wine cabinet getting below that range? Has this unit every reach temps that low before? I would make sure the unit is breathing, check the condenser and air flow through the unit. If the unit is not choking, and temps can go below 65, than yes you will need to have it serviced. It can be a thermostat issue.
Good Luck
Jul 13, 2011 | Vintage Keeper Koolspace Wine Cellar
Recently, the wine fridge has started to make a whirrring sound that lasts around 4 or 5 seconds, then stops for around 20 or 30 seconds, then starts whirrrring again. Sounds a bit like a man moaning....
it was the internal fan in the upper rear section of the fridge. Apparently, since it is mounted so close to the rear panel, the sound seems to amplify from the back. Anyway, a replacement fan was only $3.71 direct from Danby, but I did have to pay 7.99 for shipping. Also, there is a fair amount of disassembly and re-assembly needed, which might be challenging for those who don't typically make their own repairs. Once removed, the only thing I could find wrong with our old fan was that the shaft was very loose in the unit, which may have indicated a bad bearing.
Canby may be reached at the following link:
http://danby.com/customer_service
May 21, 2011 | Danby DWC283BLS Wine Cooler
Cost to replace transmission 1996 cadillac deville
Hi there
The repair or replacement cost for this particular section of your vehicle will cost around $1,800 to $3,000; Depending on the actual type of transmission mounted. If rear wheel drive equipped; this will have a fairly decent labor charge attached to the actual part price. Typical Cadillac transmission replacement charges will run around $1,900 dollars. I would recommend to inquire about repairing the actual damaged sector of the transmission/transaxle, if possible. If catastrophic damage has occurred, total replacement may be needed.
Apr 02, 2011 | 1996 Cadillac DeVille
My northland all refrigerator seems to be running but it is not cold
it sounds like its running,but all your hearing is the fans,you need to replace the rtc overload contactor located on the compressor body side,undo the spring clip wire unplug the rtc overload from the compressor and replace it,when you turn it on you will hear the compressor start then
Jan 16, 2010 | Northland Refrigerators
Wine cooler stopped cooling
I have seen this before. Get the thermostat off and put it's 2 wires together just to SEE if the wine cooler comes on. Be careful not to let it bite ya or ground against the cabinet. If it runs then thermostat replacement needed, now how simple is that?
Dec 23, 2008 | Refrigerators
Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at http://www.danby.com/manuals/DWC512BL.pdf -Ron
Dec 15, 2008 | Danby DWC283BLS Wine Cooler
Wine cooler noise
Dec 30, 2007 | Danby Silhouette DWC512BL Wine Cooler
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
