Question about Panasonic DVD-LS50 Portable DVD Player
Flashing Power Light
My portable Panasonic DVD-LS53 suddenly stopped working. When I turn it on the red power button flashes, but nothing else happens. I exchanged the battery and plugged it in, but nothing seems to work. Suggestions?
4 Suggested Answers
SOURCE: Panasonic Portable Player DVD-LS53
Check this site out, I helped me.
http://www.pechorin.com/m/2007/07/05/panasonic_dvd_ls91_error_code_H03-296059.html
chemguy
Posted on Jul 27, 2008
CPU solution
  • 164 Answers
SOURCE: portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Posted on Dec 18, 2009
  • 11 Answers
SOURCE: flashing red light Panasonic portable DVD-LA95
check the microswith near the hinge . its generally located on near the back right corner of the player , on the control surface. it looks like a very small white plastic button or pip. sometimes these stick down and look like part of the player casing, when they actually are a switch. it needs to be raised , so when the lid is closed it pushes the pip down and turns the screen off. Try prising it gently free with a pin or needle. this happened tome and i was on the verge of binning it. when i looked at the manual and it says power light flashing slowly means screen turned off.
if the light is flashing very quickly then im afraid its knackerred and just not worth repairing.
if this is helpful to you then just drop me a line at choonzy@googlemail.com
good luck
choonzy
Posted on Feb 07, 2010
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
Flashing standby light
Flashing red light can sometimes be fixed by holding down the power button on TV until it stops flashing then turn it off then on again. Disconnect everything except power cord before trying this. Mine was fixed this way and saved $500+ repair. Still going over 6 months on. Worth trying.
Apr 08, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
My sony SLV-D300P suddenly would not turn on. The blue ps button/light just flashes, but no attempt to turn the unit on works. It was working fine, without any problems, until this one occurred.
I have the same problem -- tried power reset, tried holding stop button for 5 second reset, nothing works. If I push the power button or the eject button, the blue light flashes momentarily then goes out.
Aug 28, 2010 | Sony SLV-D300P DVD Player/VCR
Stopped working while running.
flashing power light ??
thought you had to turn them off to charge it.
Jun 02, 2009 | Panasonic DVD-LA95 Portable DVD Player
Panasonic LA95 Portable DVD
any flashing red powerlight ?? (assuming theres any charge left)
if the powerlight flashes quickly then the units kaput ( bin it)
slow flashing means the microswitch may be stuck (the one that turns off the screen when you close the lid.
you may have to be sneaky at a dealer and ask to plug in to a new mains unit ( most new panasonics still use the same power supply voltage and ampage. if it works then run away quickly and go buy a universal power supply, if it doesnt , well your in the right place tobuy a new one ??
Mar 11, 2009 | Panasonic DVD-LA95 Portable DVD Player
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Flashing red light Panasonic portable DVD-LA95
good luck
choonzy
Jan 03, 2009 | Panasonic DVD-LA95 Portable DVD Player
Panasonic DVD-LS50 Portable DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
