Fujitsu 18C1 Air Conditioner
Problem for Fujitsu 18C1 Air Conditioner
Wall Hung A/C unit remote
By jhenders on Dec 16, 2008
Wall Hung A/C unit remote control # AR-DL10 batteries died last. Replaced remote batteries with 4 new duracell batteries. Unit came back on but running to warm. I tried to figure out the programming of the remote but can not get it to even swing the louver. This cools a computer server room that needs to cool down soon. Looked for remote mannual online but could not find one. Please help me get this remotre working. At present I tried to set it to 64 degrees. That usually kept the room at 70. I keep pushing buttons and the remote will change but the wall hung unit will not respond to its commands.
Jack (Facitities Director for Paulsboro School District in NJ)
Same Problem
Jan 07, 2009
-   Having changed the batteries in remote, hit ACL and reset the remote's time, it is unable to communicate with the air con unit at all. Other remotes can still activate the air con but not this one.
Does anyone have a link to manual?
-   mailcheck
Jan 04, 2009
-   I have exactly the same problem! Still searching for a solution. Cheers.-   ausgaz
Solution #1
posted on Jan 04, 2009
Somewhat Helpful)
ausgaz
Rank: Apprentice
Rating: 75%, 5 votes
I just got onto a technician who solved the problem for me. What he had me do was:-
  1. Pull dowwn the slider and use a pen to press the ACL button.
    That didn't fix it so...
  2. Take off the slider (the way you would to change the batteries). There is an ABCD slider switch and mine was set to "C". I moved it back to "A" and now it works! I am not sure how it got to "C" though ???
The other thing is I had been messing around with the "Manual/Auto" button under the grill on the wall unit. It was set so that the A/C was off. I'm not sure if that is significant.
Hope that helps.
Cheers,
Garry Rogers (ausgaz)
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Fujitsu 18C1 Air Conditioner
Questions and Unsolved Problems for Fujitsu 18C1 Air Conditioner
Do you recommend Fujitsu 18C1 Air Conditioner?
Answer
Answer
unit will not turn even if manual switch is pressed on indoor unit
Answer
The wall unit won't respond to the hand held timer/control. Worked fine a month ago. Batteries... (More)
Answer
Timer and operation light flash similtaniously 5 times then 5 second gap then flash again. continues... (More)
Answer
evap is blinking two green light flash and condensor will not operate on my fujitsu aou30clx split... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Fujitsu 18C1 Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
