Question about Sherwood A-965 Amplifier
Sherwood AX-7030R amp - doesn't switch on.
I've had a local chap look at my Sherwood AX-7030R, he can normally mend most things and he says the standby circuit voltage regulator has had it. He can't get one.
Where can I get the bits please, or the wiring diagram for it?
  • j_constable Dec 22, 2008
    I didn't realise that you mostly in america, all i need is some
    parts but can't find who to get them from in the UK.
    Do you have a contact?
  • 4,234 Answers
Something doesn't sound right. The standby circuit is usually very simple. The "regulator" is just a transistor. Can you request and post the parts that he/she can't find. I should be able to get you a source or substitutes.
Dan
Posted on Dec 17, 2008
  • tony_ling
    tony_ling Apr 30, 2012
    It's probably the transformer
Sherwood AX-4103 amp keeps clicking
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Apr 21, 2014 | Sherwood Audio Players & Recorders
Sherwood ax 4050r
'Direct' disconnects the EQ normally. Don't trash your amp because of a noisy EQ when you can bypass it.
Mar 05, 2014 | Audio Players & Recorders
Are Tecomec Chaps any good?
Jose, I have tried the brand a year ago. No problems! The web site you posted has the chaps I used. This one is great for blackberry picking and turkey hunting
Tecomec Wrap Around Chap
May 25, 2012 | Desa International Garden
When power is turned on, standby light comes on normally, but in any playing mode, the receiver switches off and the standby light flashes.
It looks like this is a common problem with a lot of the Sherwood Receivers. I've had the same problem with my R-125RDS for a while now. Finally hit on solution today by replacing a power transistor. The transistor in question is not on the power amp board but instead screwed to the chassis and wired to the mainboard. I believe it is part of the output short protection circuit. In my case the component was a 2SD2059 (silicon NPN 100V,5A) replaced by equivalent 2SD1407. The transistor seems to run pretty warm so I guess this is why they ultimately fail after a few years.
Sep 17, 2011 | Sherwood RX-5502 Receiver
The main transformer in my Sherwood amplifier is down the primary winding is open circuit. I cannot find the transformer outputs as to replace it. does any one know the voltages and current ratings for...
I would contact Sherwood as Transformers are deemed to be safety components and should be replaced with excat parts or those recommended by the maker.
Jan 25, 2010 | Audio Players & Recorders
Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
Sherwood AX-7030R don't work
Try Googling (Sherwood)(AX-7030R)(manual) without parens.
Dec 20, 2017 | Sherwood Audio Players & Recorders
Sherwood AX7030-R
I have a number of suppliers that can deliver internationally or are located in Europe. If you can list the part, I may be able to locate a few alternatives that might be more readily available as well.
Dan
Dec 17, 2008 | Sherwood RV-7050R Receiver
587 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
