Question about Acer Aspire 5100-5022 Notebook
My laptop is not receiving any current when plugged.
My laptop battery is not charging and no current is on it.And each time i plug it, no current is into it.But i tried to use it without the battery its still not working.So what do i do about it.
You can respond to me now and as well send mail to my email box.
My email box is sponkyfiam001@yahoo.com
    Guru:
  • 829 Answers
I suppose you try replacing the power adaptor and if you find battery charging then there could be problem with the power adaptor
Posted on Dec 16, 2008
Intermittent charging on my Dell Latitude E4310
AS long as your charger has the correct voltage extra current is fine. Your laptop will only take what it needs. The battery should not charge unless the power is low or the laptop is off.
Aug 26, 2015 | Dell Latitude E4310 Laptop
Hp g7 plugged in, not charging
get a new battery. They have a lifespan. After you get a new one, don't leave it in the laptop all the time. Running current through a battery with a full charge ruins it. If you are on AC power, you can use the laptop WITHOUT a battery! This will make the battery last about 20x longer. :-)
Jun 02, 2014 | Pavilion g7-1219wm Notebook PC
Battery wont work without the charger plugged in
All batteries have a FINITE amount of time before they can no longer hold a charge, if your battery is older then a year it is no longer covered under warranty either. Have you noticed prior to this that the battery was holding less and less of a charge? ALSO batteries do over heat and stop receiving a charge, best way to tell is to keep the laptop plugged in. unplug the battery for a minute, then plug it back in and see on your task bar if it says charging or plugged in not charging. let me know! good luck to you as well!
Sep 06, 2012 | Dell Inspiron 15 Laptop
Message to "plug in" even when plugged.
Either the adapter is faulty, or the port in the computer.
Most of the time, even if the battery is junk, the computer will still run on house current.
I have had one event where I had to take the battery out to get the computer to boot up.
Jul 04, 2012 | Dell Computers & Internet
Gateway laptop died. Several times it appeared to reboot only to go black and go off. No fan or lights. How can I fix this myself?
does it show that it is charging from the charging light/power supply? Is there any life left in the battery? is the charger charging the battery? the batteries dont last in laptops usually about a year before the go bad and have to be replaced, Is the charger working? The chargers go faulty all the time, The little plug that plugs into the laptop goes faulty and is a very common fault and doesnt charge/power the laptop, The only thing you can try is another power supply of the same name/model/output voltage and current with the same small plug and polarity or another battery of the same type/model, If you can do this and it doesnt cure your fault it needs looked at by a technician, Hope this helps, If you need more assistance let me know,
Sep 19, 2011 | Gateway Computers & Internet
Dell inspiron 1525 battery not charging
Take out battery & place it again.
If does not charge again, contact sevice centre.
Apr 16, 2010 | Dell Inspiron 1525 Laptop
LEAVING A BATTERY OPERATED TV PLUGGED TO A.C.
Mike ultimately it depends on the charging board and battery combination most modern units it won't hurt at all. I leave mine plugged almost all the time as well as my laptop.
Some DVD players will work without the battery plugged in anyway, and batteries store best with a partial charge.
I'm not going to get into battery science but Lithium Ion, NiCad and NmH batteries all like to be treated a little differently.
I think you are safe....but in time all batteries will fail regardless.
Cheers!
Feb 03, 2010 | Audio Players & Recorders
Plugged in, not charging
dont check by the nozzle size. Check according to technical specifications. If the power cord you bought is passing on less current or at lower voltage to the battery it wont charge. Get a certified cord from the battery manufacturer that would work with this battery.and this time take your notebook along to see its working or not :)
Aug 13, 2009 | Compaq Presario Notebook
Battery wont change
A problem is just like a mountain. You don't jump over the mountain, you climb it in steps, one step at a time.
1.How old is the battery? 1 to 2 years old, you can expect it to be at the end of it's Life Cycle. Batteries are rated in so many hours of usage.
Best bet is to let the battery charge 24 hours, then try it.
Would be nice if you someone else that has an Inspiron 1525, and they would try to charge your battery. If it doesn't charge up, you would know it's the battery. If it does charge up you can move on down the charging system, to try to find the problem.
2.AC adapter, (Charger) If you have a multimeter, set it to the 50 volt DC scale.
Laptop and desktop computers use DC current. (Direct Current) Your house, for example, uses AC current, (Alternating Current)
AC is converted to DC by the AC adapter, (Charger)
An example of DC current are flashlight batteries, and your laptop battery.
DC current has a Positive pole, and a Negative pole.
The center pin of the plug of your AC adapter is the Positive pole. Any of the four outside pins on the plug, are Negative.
The Red, (Positive), probe of the multimeter goes to the center pin. The Black, (Negative), probe goes to any of the outside four pins on that plug.
Example of a DC Power Jack, for the Dell Inspiron 1500 Series of laptops, 1525 and 1526, (This is the jack inside your laptop, where you plug the AC adapter into),
http://www.megaemarket.com/dc-power-jack-for-dell-inspiron-150150015011505.html
3.It may be that DC Power Jack itself is bad, or one of the solder connections is cracked. It's hard to see it clearly on the link I provided, (So I Right-clicked on it, Save Image As, and put it right in my My Pictures folder. Then I magnified it), but in the photo you will see some metal pins sticking out of the rectangular body.
The metal pins are sticking up. In reality those pins go down, when the jack is mounted on the motherboard. They go through the motherboard, via holes, and are soldered on the other side.
It is these solder joints that may crack, is what I'm referring to.
Solution to 1?
Obviously buy a new battery.
Solution to 2?
If your multimeter findings show lower voltage than needed, it's time to buy a new AC adapter. They have generic ones that can be used on a variety of laptops. The voltage will be stated on the top of the AC adapter.
Example: 19.2V-1.0A
That's 19.2 Volts at 1 AMP.
It may just be the plug end on the AC adapter itself. The plug end that goes into the DC Power Jack, on your Inspiron laptop.
Solution to 3?
Unless you are a skilled Electronics Technician, and have Excellent de-soldering/soldering skills, I advise taking it to a computer repair shop. It may not just be cracked solder joints. The DC Power Jack may need to be replaced. Maybe the motherboard is one of a bad design, and where the DC Power Jack attaches to it, has cracked.
Jul 25, 2009 | Dell Inspiron 1525 Notebook
Compaq Presario v2000 notebook reduced battery life
you may try:
1) check the battery alarm at windows power managment, to set 5-10% alarm level.
2) discharge the battery to the empty then charge longer time, you need monitoring how long it charged (see charge lights change), need to change new one if charging time much less then before(less then 10-20 minutes)..
3) plug-in AC adapter monitoring charging current,
this step you need a current meter to make a series connection in the circuite, the battery is over life cycle if the current less then 500mA.
May 02, 2009 | Computers & Internet
Acer Aspire 5100-5022 Notebook Logo
41 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
