Question about APC Smart-UPS RT 8000VA (0731304239635) UPS System
Need a repair manual for a APC 800 RT
Alarms showing:
-No input voltage
-low batteries
-batteries are fairly new and are charged.
  • joseph_marin Dec 16, 2008
    fuse was blown but replaced and now ok.
    ac power is present at transformer.
  • zonkpc
    zonkpc May 11, 2010
    Firstly I would check the fuse on the plug, as this may be causing the error problems. There is no manual to be found for this unit, however it does include a 2year on site repair or replace warranty, if your unit is under two yeas old I would recommend using this service
  • 37 Answers
SOURCE: I have a apc 650 model bk650mus battery backup.
how long the lifespam is the battery you had are using it? if you check the voltage that is 13.5dcv but it could be the Ah is already running low.. try to change with a new batts and power up the ups ifi it not workin that mean it the hardware issue..
Posted on Mar 24, 2009
jvpacoin
  • 91 Answers
SOURCE: Overload light in APC RS 800 UPS
it seems that the inverter circuit of your UPS is dying. the solution here is you have to open up the UPS and check the inverter circuit. to make easier, check the power mosfet if its leaking.
Posted on Aug 14, 2009
JaxPlanet
  • 922 Answers
SOURCE: APC back-ups XS 800 battery backup : warning
Turn it off and unplug it from the wall.
Open it up and make sure that the red and black wires are connected.
If they are the battery needs to be replaced. They are only good for 2-3 years. If you are not comfortable with my instructions, call APC for free support. (800) 555-2725
Vote for this solution if it helps.
Posted on Aug 18, 2009
  • 541 Answers
SOURCE: Battery Charging Failed on APC Matrix 5KVA
you will need to replace the unit. the charging circut has failed
Posted on Dec 27, 2009
SOURCE: I have an APC XS1300. One year old. Very few
Mines, two or three years old and doing the exact same thing, you ever figure out what happen or how to fix it? I took the battery out and it reads 16 volts. I put a 2 amp load (fan) on it and it pulls fine, so I'm reluctant to buy a new battery pack for it now.
Posted on Aug 22, 2011
How can output voltage be adjusted when on battery power?
1. check either it is overloaded or the batteries are weak . check battery voltage to
May 10, 2014 | APC 620VA/390W Input 230V/Output 230V...
APC 800va inverter is not charging
Yadava,
If you need pricing on a new or replacement unit I can help. You may also want to look into APC's Trade-Ups program where they give you a discount on new equipment as long as you provide a serial number for your existing: http://buy.apc.com/commerce/storefronts/tradeups/
If you need UPS, Surge, or Power Related help contact:
Inside Service Sales
Daniel Salazar 800.260.2259 daniel@psihq.com
Power & Systems Innovations, Inc.
customerservice@psihq.com
Power & Systems Innovations, Inc. is an Elite Certified Service
Sales Partner for APC/MGE brands manufactured by Schneider Electric
Visit us at www.psihq.com
Apr 18, 2014 | APC Smart-UPS RT 8000VA (0731304239635)...
APC Smart-UPS RT 10000VA 230V battery charging voltage high
voltage is ac,,,,better get a new one before u fry your self
Nov 09, 2013 | Computers & Internet
APC BACK-UPS ES 500VA fails to provide back up during power failure
Get APC Powerchute Personal Edition for free and run it. If it says your battery isnt charged, check its voltage disconnected. Charge it with a car battery charger and see if its still a good battery. If not , replace it. If the battery is good, then check the charging voltage. Should be about 14 volts. if not, check the small transformer on the main board. Should be 120 in and 17 to 18 out. 4 diodes in a bridge for charge. The input to the transf has small fuse into it alone.
Jan 04, 2013 | APC BE500U ES 500 USB BACK-UPS 500VA/300W...
27.5 volt charging voltage
No, that right. The batteries are wires in series so the voltage is 24v and they need a little high input than that to charge correctly.
Jul 25, 2012 | APC Back-UPS Pro 1400 UPS System
@MY APC UPS SURT15KRMXLI is not charging after installation on single phase input
we have installed a new ups but the battery light indicates red light even though its on charge
Aug 12, 2011 | APC SMARTUPS RT 15KVA RM 230V...
"On Battery" Alarm Sounds when Power Available.
if this comes sometimes and goes, this means that the power to ups is sometimes deviating from the specific ups input range, hence the ups is rejecting it. mesure the input voltagesand frequency with a multimeter and check whether they match the specified ones in the ups manual. aslo with some ups there are switches that you use to set the input voltages or number of phases in the ups input. check the manual to see whetther your ups has such.
Oct 24, 2009 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
Charging apc 800va through home generators
The reason of this is the UPS cannot adopt on the frequency that is being generated by your home generator. you should use APC smart ups series coz smart-up series can work on a wider input frequency range.
Jul 27, 2009 | APC Smart-UPS RT 8000VA (0731304239635)...
APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
Apc ups flashes red light to replace battery, but battery is new
i think by replacing the battery has not been the solution to the problem
u need to check the battery charging voltage when turned ON with main electricity, if no voltage present from charger, there is no question of battery getting charged and also once the battery is down with charge it may not re charge hence the indicator and alarm.
recomended to nearest service centre
Mar 26, 2008 | APC (BE500U-WEB) (BE500UWEB) UPS System
APC Smart-UPS RT 8000VA (0731304239635) UPS System Logo
411 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
