Question about Tefal Aquaspeed 155 Iron with Auto Shut-off
Iron turns on but will not work, red auto stop light stays on
I have a tefal 400 power jean iron the auto stop warning light flashers and when i pick it up to use it the light stops flashing and stays on and my iron stays cold
  • Anonymous Apr 13, 2009
    red auto stop light stay's on will not work
ginko
  • 19396 Answers
SOURCE: tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Posted on Apr 22, 2009
  • 65 Answers
SOURCE: red light on
element is shot,take it back or send it back for repair
Posted on May 31, 2009
  • 43 Answers
SOURCE: the auto stp security light is on and the iron
i'm not quite sure what the STP security light is but on my iron a security light comes on when the iron is idle. It shuts the power to the iron when no movement has happened mine is about 5 mins.
Posted on Sep 18, 2009
SOURCE: how can i clean my tefal iron/ surface
tough soapy sponge
Posted on Dec 27, 2009
heatman101
  • 43501 Answers
SOURCE: Tefal program 8 500 Iron
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
The auto shut off on my new iron has stopped it from heating... is there a reset option? or do I need to purchase a new iron?... The auto shut off light flashes when first plugged in, then stays off......
it has a adjusment try to adjust by rotate it to clockwise it is located inside of your iron use a screw driver to adjust then observe unit. if not u purchase new unit.
Feb 17, 2011 | Philips Irons
Continuous steam and green light flashing on my tefal steam generator iron.
I found this on a site and it works!! Put 50/50 mix of water and viniger in your iron, let it run, after a while start pressing the steam button, you may have to do this a few times, but it will eventually stop the light flashing, then the steam function will return to normal. You'll need to clean the iron out a few times afterwards
Jun 22, 2010 | Tefal Pro Express GV 8120 Iron
Tefal prog 8 500 series iron not heating up properly -
My Tefal Program 8 400 iron will not heat up. Light is on but nothing coming through. I has used it 10 mins before this happened
Apr 05, 2010 | Tefal UltraGlide Easycord FV4256 Iron
My tefal express 2941 steams constantly when switched on and cannot be stopped, please advise?
Fill the iron with 50/50 water and vinegar and let it steam for as long as it will. This will clean out the iron thoroughly, the green light will stop flashing and it will go back to normal. Then remember to clean your iron on a regular basis. Mine did!! Found this solution on another site
Feb 20, 2010 | Tefal Irons
The auto stp security light is on and the iron does not heat up i have a tefal ultra glide iron
Sep 16, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal iron - security auto stop has locked me out, have switched off for some time but lock out still in place - help!
If you know how to open it, it's just a mechanical lock, check for anything that stuck or broken
Aug 18, 2009 | Panasonic NI-R73NR Iron
Hi My iron seems to auto shut off in 2 secs when I plug in the power, it shows the red light for a sec and off, what could be the issues.
How old is it?
Is it still under warrenty? if it is take it back to where you bought it.
Otherwise it sounds like the thermostat is broken. Wallmart has some very nice cheap irons.
Aug 02, 2009 | Tefal Avantis 130 Iron
Red light on
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Tefal Aquaspeed 155 Iron with Auto Shut-off Logo
124 people viewed this question
Top Tefal Irons Experts
Marvin
Marvin
shaun taylor
Are you a Tefal Iron Expert? Answer questions, earn points and help others
