Question about Power Acoustik PS2-820 Car Audio Amplifier
Beer Spilled on my Power Acoustik PS2-820 Amp
My Power Acoustik Amp got wet from a beer exploding on it. I instantlly unhooked my amp from all connections and did not put any power to it. I took it home and let it sit inside my house to dry off. I did not however take it apart or put a blow dryer to it. I wish i would have, but i just let it sit ontop of my heater for a while. Once i thought that it was dried out i hooked it all back up to my two 12" Audiobahns. I hooked everything up and I was ready for my system to come back from the dead. The only thing that stopped me was the fact that my fuses blow everytime i give my amp power. I even tried it a month later and every time that i plug in a fuse it instantly blows. As of now I am trying to figure out what is wrong with my amp and repair it. No repair shops are in my area and my only other option is to get a new amp. So i figured I'd try to fix it. I took it apart today and all of the circuits look normal to me. If anyone knows HOW TO FIX A WET AMP or what to do, PLEASE HELP ME!!!!
  • 38 Answers
If the fuse blows black u have a powersupply problem in ur amp output transistors mosfets
Posted on Mar 21, 2007
    Problem Solver:
  • 11 Answers
Hi , now that you have the amp apart , just check the underside of the printed circuit board and check for any corrosion ,rub it with a soft brush . then try connecting without speakers . see if it still blows fuse, if it does then there is a likelihood that your mosfets / outputs may have shorted the first time you reconnected it . Good luck
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
Ways to get rid of snails..........Please help!! we have recently started a veggie garden and are so excited to see the progress. However, we see that the snails love the veggie garden as well. last...
Is beer non-chemical enough for you?
Look for snail trails around your plants. The trail looks like a glossy wet slimy line. Then take the hand trowel and dig a shallow hole to the depth and size of the non-breakable shallow bowl or pie tin in the area you see snail trails.
Pat the earth down around the hole so that It won't crumble into the bowl or tin of beer.
Set a non-breakable shallow bowl or pie tin in the hole.
Fill the bowl or pie tin with any kind of beer. Fill it slightly below the top so the snails will have to crawl in to get to it. Cheap beer works just fine. Once the snails are in the beer they are trapped.
Clear out dead snails and keep putting beer in the bowl every two or three days as it evaporates. You can put more than one bowl of beer out in other areas that are tempting to snails.
Basically, the snails love the beer, they fall in and drown.
Mar 08, 2014 | Garden
A drunken fool spilled his beer in my amp. Now it doesn't work. Help!!!
This kind of problem is generally bad news, depending on the amount of beer will determine the extent of damage. I can tell if you are lucky to get it going the chances of it breaking down is extremely high, even taking it apart and cleaning it won't be enough. If I were in your shoes I would go after that drunken fool and make him replace the amp because once the board is compromised there is no way to reverse the damage. The ic pins corrode and get into the casing, along with the other components.
Feb 09, 2011 | Audio Players & Recorders
I have a hp 5070-4221 wireless keyboard I spilled beer on and now it does not work. Can it be repared
Once upon a time coffee was spilled on a wired keyboard and this mechanic I knew took the keyboard out of its case, poured water on it , and let it dry for a day or two.
Then he reinstalled it and it worked!
I am not saying that this solution will work for you, but the Beer may be causing the keyboard buttons not to work.
Good luck on this repair.
Jul 02, 2010 | Computers & Internet
I have a power acoustik bamf 2000 class d amp and i think when i had it unhooked the positive and negative speaker wires might of touched for a few minutes and now the amp comes on no protection light just...
internal components are very sensitive to things like that. sounds like you shorted out some of the fets internaly .. i recomend a complete diagnostic and proceed to repairs.
May 06, 2010 | Power Acoustik SL2-2000 Car Audio...
Spilled beer on plater Pioneer CDJ-800MK2
Well, the problem is that you spilled beer on your platter.
More than likely the beer dried up, and now it's all sticky.
Professional cleaning is highly suggested.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Jul 11, 2009 | Pioneer CDJ-800 Turntable
My amp goes in protect mode
Maybe the audio amplifier IC´s are damaged
Feb 06, 2009 | Power Acoustik GOTHIC OV2-1200 Car Audio...
Dell Latitude cpx
Try to connect and external keyboard to it
with the external monitor.
If the shortcut is in the keypads where most off the beer propably came in contact.
will now be seen if its boots up.
If it boots up with external keyboard the ptoblem is in the beer soaked keyboard.
change or clean the keyboard with isoprophanol
to dissolve moisture and beer.
This is the solution. Please vote!!!
Jul 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Power Acoustik PS2-820 Car Audio Amplifier Logo
181 people viewed this question
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
