Question about Teac DC-D6300 CD Shelf System
Record LPs into desktop computer.
I am wondering if I can export from the turntable on the DC D6300 Teac into my computer. Want to record some LPs onto CD and do not want to spend an additional $3-400 to buy LP-to-CD recorder. (My manual is temporarily unavailable)
  • 247 Answers
I do this almost every week using a jack to jack lead from the headphone socket on the source device (in your case, the CD shelf system) to the Line In socket on the pc sound card. Starting with the shelf unit volume turned right down, wind it up gently until the sound level on the pc is right. Next, you'll need a piece of software on your pc that can record full length .mp3 or .wav files. I use a cheap tool called Audiolib MP3 recorder I downloaded at www.tucows.com a few years back. Finally, having recorded the sound onto your hard drive, use your CD burning software (Nero or whatever) to split it up into tracks and burn it onto CD. A.
Posted on Mar 21, 2007
    President:
  • 3,130 Answers
If you have an line level audio output on the shelf unit, you can as then the other end would connect up to your input to the sound card, if there is only a mic. input and no line input you can get whats called an antenuator, or get another audio sound card for the computer with a line level input jack. Good Luck
SOURCE:
33 Records are playing a bit too fast on my Wockoder Record Player... Is there any way to fix this?
Lots of quality turntables have a speed checker and a limited amount of speed adjustment.
Many ordinary record decks use a synchronous motor, the speed of which is regulated by the Hz of the mains supply and with mostly fixed gear ratios it is impossible for them to run faster - slower is the usual problem.
I expect there will be types driven by a dc motor and regulated by a switch mode power supply but I know nothing about them.
I suggest you begin by learning something about your turntable.
Dec 27, 2017 | The Audio Players & Recorders
Hi - I have been recording some of my vinyl albums onto CD's for several months now. All of a sudden, when I went to use the turntable yesterday, I can't get the Record light to light. What am I...
If the red indicator on the record button does not light, reload a record-able dics, wait a few seconds until "NO TOC" and "CR-R" (or "CD-RW") indicators light on the display, and press the record button again. BE sure your using the CD -R or -RW disc and make sure to use a disc bearing the "Digital Audio" mark on it.
Richard Roth
The FixYa Team
Aug 09, 2011 | Teac GF350 Turntable
I can play LPs, b ut when I click on "record", and
Uninstall the upper and lower filters scroll down to how here: support.microsoft.com/mats/cd_dvd_drive_problems
Also, this can be as easy as your burning software as have that problem allot. Download the below ad try doing something on the drive: www.nero.com/eng/downloads-nero8-trial
Hope helps.
Aug 01, 2011 | ION Audio Audio Players & Recorders
My Teac sl-a100 record player sounds like a chipmunk
hi,
somewhere on that player is a switch for 78-45-33 rpm the speed switch look up around by the tone arm above by where the record goes, it may not be on the front. switch it to the correct record you have 45's are small. 78's are medium and 33rpms are the big records..
jm
Apr 30, 2011 | Teac SL-A100 Turntable
I HAVE A TEAC CD RECORDER WITH TURNTABLE/CASSETTE PLAYER #GF-450F7\r\nWHEN A PUT IN A RECORDABLE BLANK CD I GET ERR4 OR ERR8 MESSAGE ALL THE TIME, UNABLE TO GO TO THE NEXT STEP TO RECORD, THESE CODES ARE...
Is it a recordable blank CD with "audio" or "music" printed on it? It MUST be.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Teac-GF-450K7-manual/id/23167bh436/t/2/
"ER **" (variable) IS in the manual on page 29 and it recommends power off, wait a minute and power on, which isn
Mar 23, 2011 | Teac GF450K7 Turntable
I lost my control for my teac hd plasma were can
a harmony remote will work along with many other universal remotes. if you give me the correct model i can find you factory remote
Apr 30, 2010 | Teac DC-D6300 CD Shelf System
Hi, the crosley will no longer record onto any music cdr/rw. It will indicate that the cdr is blank-i know it is- then the zeros/record appears but no recording takes place. thanks if you can help.
I turned it off for two (2) hours - turned it on and it worked. Apparently this unit overheats after one session: one (1) cd-r per session then shut-down.
It is worth it, when it works, because my lps have no hiss when finalized.
Sep 05, 2008 | Crosley CR248 Turntable
Volume
LPs were mastered back in the day with no real volume standard--ceertain sounds had to be mastered light because the engraving on the master disc was so sensitive.....digital technology does not have that problem....digital takes a lot of volume before it starts to break-up...
rick12string
Dec 27, 2007 | Teac GF-650 Turntable
GF-350
is it possible to fit a new laser unit to my GF350
Dec 01, 2007 | Teac GF-650 Turntable
Teac DC-D6300 CD Shelf System Logo
161 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
