Question about Lexmark Office Equipment & Supplies
Lexmark Printer X6570 using Cartridge 44 XL - expected output 500 pages but got only 375 pages. 43 XL (colour) - expected 350 pages but printed less than 100 pages and printer cartridge indicates that nearly empty. Any solution Please ???? Salim Kanji - saakanji@rogers.com
    President:
  • Lexmark Master
  • 1,314 Answers
The expected cartridge life that you are given is an estimate based on 5% coverage. If your pages have more than 5% coverage on them, you use more ink and therefore will get less pages than what they say you could get. For instance, if you are printing full page photos, you will get far less pages per cartridge than if you were only printing 3 x 5 photos. So there is nothing wrong with your printer, you are just using it more than the "standard".
Thanks and please take a moment to rate as fixya.
Posted on Dec 16, 2008
What is the life of a Xerox 6505 toner cartridge
The life of a toner cartridge is governed by how much printing it does.
As an example: the average full toner cartridge was expect to yeald approximately 10.000, A3 prints of approxamatly 5% coverage.
That equates to your average business letter :=
Dear Sir, blah, blah, blah ... Yours sincerely.
If you want to print construction plans and black and white drawings expect to get less prints than you expected.
On average they don't do too badly, but if you want to print advertising flyers expect less if there in full colour with bleed.
If you print 4 colour black then don't expect not to use the C,M & Y that also gets used up at a similar rate.
Good luck.
Jun 09, 2014 | Xerox Phaser 6128MFP AllInOne Laser...
Lexmark x6570 print black on colour cartridge
In your control panel, devices and printers, click on your printer. you can make it print black from there
Apr 04, 2012 | Lexmark X6570 InkJet Printer
Lexmark X6570 printer cartridge black or colour not recognised error 005, they are correct cartridges, contacts are clean, will not print test page, used diagnostic tool and quote: incorrect cartridges,...
The Lexmark X6570 printer uses these cartridges: - #41, #41A, #42, #42A, #43XL, #44XL
Follow the steps below to fix the problem: 1. Remove the print cartridge that is indicated and close the cartridge carrier lid. 2. Close the scanner unit. 3. Disconnect the power cord from the electrical outlet. Wait a few seconds. 4. Reconnect the power cord to the electrical outlet. 5. If the power button is not lit, press it to activate. 6. Reinsert the print cartridge and close the cartridge carrier lid. 7. Close the scanner unit. 8. If the error reappears, then it could be a faulty cartridge. Replace the print cartridge with a new one, close the cartridge carrier lid, and close the scanner unit.
Jul 28, 2011 | Lexmark X6570 InkJet Printer
I have just changed both the colour and black cartridges in my Lexmark X6570 printer. The printer acknowledges that there are full cartridges but when I aligned the colour all that was printed was grey -...
Silly question, have you inserted cartridges in their right compartment?
Id yes!, To save yourself time, suggest you remove printer prog and reinstall latest update from Lexmark, rememeder to leave printer switched on while setting up
May 24, 2011 | Lexmark X6570 InkJet Printer
I put in a new ink cartridge and I can't print....it keeps saying..."align printer". This has never happened to me before. What should I do? Thank you for your assistance.
You need to align a printer everytime you put a new cartridge in. It is a 2 step process
1 the printer will print an alignment page - usually coloured squares. 2 You then scan this page back into the printer - alignment is then complete.
this is the link to the manual page 42 through 44 explain about installing a new cartridge and the alignment process.
Dec 14, 2010 | Lexmark X2470 All-In-One InkJet Printer
I have a Lexmark 1200 printer. Colour promlems
It could be that the cartridge has become dry.
you have to try several head cleans using the printer software and if that doesnt help then the cartridge needs to be replaced.
Nov 03, 2009 | Lexmark Optra Color 1200 Led Printer
Cannot find the ink cartriges on my x6570
  1. Make sure the printer is on.
  2. Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
  5. If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You can download the manual from
http://support.lexmark.com/index?page=downloadFile&actp=CONTENT&productCode=LEXMARK_X6570&id=DR4580&segment=DOWNLOAD&userlocale=EN_US&locale=en
Please rate this solution. Thanks.
Oct 12, 2009 | Lexmark X6570 InkJet Printer
Lexmark printer x6570 unable to allign after putting in new cartr
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........ Good Luck
Feb 01, 2009 | Lexmark X2470 All-In-One InkJet Printer
Lexmark X6570 refill cartridge
Lexmark has High Yield inks for that product that will give you a better cost per page.
Sep 11, 2008 | Lexmark X6570 InkJet Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
