Question about LG KU990 Viewty
My LG Phone Screen is not working properly what should i do?
This is bad. go to a service :(
Posted on Dec 18, 2008
Km900 having touch problem please tell solution
My LG also had same problem, The touch was killing me, but than i changed the screen and it is working properly.
Just chanage the screen. I hear Most LG's have this problem.
May 29, 2012 | LG KM900 Arena Cell Phone
I have LG GT540 cell Phone. It was responding well but now it's not working properly. Even if I touch the screen or try to unlock my phone it gives no result.. While typing Text it gives error time and...
i was also facing this problem with my LG GS290 but it was in warranty period therefore i took my mobile to lg service center and they told touch pad is defected therefor they replaced with the new one without any cost
so if you have your mobile in warranty then take mobile to service center.
Jul 18, 2011 | LG GT540 Cell Phone
The touch screen doesn't work
here are various problems the lg ks660 touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Press and hold the home button as well as the reset button on the top of the lg ks660 phone to turn the lg ks660 off.
May 09, 2011 | LG KS660 Cell Phone
There are times that the screen on my LG Prime works, but then there are times when I can touch it and it won't even work. There are also time when I will touch it in one spot and it'll go to something on...
if your LG phone is with sliding keyboard then your phone's internal ribbon is damaged.
if your LG phone has no keyboard then may be your phone's touch sensor is not working properly.
Mar 05, 2011 | Cell Phones
My lg neon phone screen wont come one but my keys and vibrations work what can i d to fix it so my screen works again
If i remember right the neon is a slider phone. if thats the case and the phone hasnt been water damaged there is a flex cable that goes between top and bottom. its a common issue for those to go bad and can cause the phones screen and speakers to not function properly, or both.
Nov 20, 2010 | LG Neon GT365 Cell Phone
My LG BL40 touch screen is not working. I can't answer any call, make a call, send a txt....... Infact, I can't do anything with it. Am in Ghana and LG has no branch here where I can take it there. What...
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Take care
Hope this will help in solving the problem....
Nov 16, 2010 | LG CHOCOLATE BL40 (1 GB) Cell Phone
My phones toutch screen not working properly
First Step is that please get your mobile screen calibrated by acessing te mobile calibration option in your phone settings
Second step if still the problem exists then please check that if your phone is under warranty then get the screen repaired from the nearest LG customer care & if the mobile warranty is expired then if feseable then get it repaired from a reliable source but as far as my recomendation goes please go for genuine parts and proper source
Hope it helps
Oct 05, 2010 | LG Cell Phones
Lg kg800 screen stuffed up!!!
k..
since your in tight budget for service centers... try this do it yourself...
if you can open your phone, check its flex connector if it is still properly connected. press them or try taking them off and put it back..then try it again...
hope i helped you...
Oct 22, 2007 | LG KG800 Cellular Phone
LG KU990 Viewty Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
