Question about Dell E173FPf 17" TFT LCD Flat Panel Monitor
I am trying to repair or buy a P-TWO AWM 20696 E221612 cable
I was replang the power inverter board and the cable(P-Two AWM 20969 E221612) that goes between the lcd panel and the logic ripped a little. I am trying to either repair the ribbon cable or find a replacement.
  • 12 more comments
  • Rick Ciurej Dec 16, 2008
    I checked the Radio Shack web site and could not find a 30 conductor flat cable.
    I tried shopJimmys.com and they didn't have it, but recommended Vance baldwin and they could not locate it either.
    That is where I started, I purchased the inverter board at LCD Repair LLC. I then contacted them for the ribbon cable and they do not carry it at this time, so that is what brought me here.
    Like I just said to the previous posted solution, that is where I purchased the inverter board, but they don't carry the cable. http://www.lcdrepair.us/e173fpf-logic.ht...
    I tried the link and part of the cable number seems correct, but the picture doesn't look like the part that I need. In addition to that, the auction already ended for that item.http://www.oztion.com.au/buy/auction.asp...
    After removing the cable from the connector, I notice that the cable has the contacts exposed. I am not seeing any real way of rejoing the cable, other than cutting all the way accross and reinserting that to the connector. How would I expose the contacts?
    It has a couple folds. It is approx. 9" long if it was straight, but it has two folds to bring both connectors side by side, making the cables equally approx. 3" long
    I am replacing the whole inverter board, I am looking for the flat cable that connects the board to the LCD display.
    This cable that I'm looking for is for a DELL E173FPf LCd computer monitor.
    I am looking for the cable that connects the inverter board to the display.
    The number that I listed is the number that is located on the cable itself
    (P-Two AWM 20969 E221612). I hope maybe this might be more helpful.
    I purchased the inverter board from LCD Repair LLC and it did not include the cable. I also checked one other place that I was looking to purchase the inverter board and they didn't include the cable either. I contacted both places and I was told that they do not sell this cable.
    I tried using Dells web site for parts and ended getting no where. I was transferred and told to talk to different departments, but in the end I still can not locate the cable that I need.
    That would be great, the problem I am having is locating a place to purchase this cable.
  • Rick Ciurej Dec 17, 2008
    So far no luck
    I use digikey for many parts, but they don't have it.
    Sergeant:
    Novelist:
  • 327 Answers
You will have to order the required cable here
http://www.globalsources.com/manufacturers/LCD-Computer-Monitor.html
check out this link
if this link do not help then check out for this another link
http://sagacious-tech.com.cn/products.asp?gclid=CJnNjLbTxZcCFckrpAodfySWSw
u will have to contact them if the cable is not mentioned and they will get it for u and provide you.also u can send mail if the contact numbers r not working
Contact
Tel:086-571-87804996 I am trying to repair or buy a P-TWO AWM 20696 E22 - dot2.jpg Fax:086-571-87804033 dot2.jpg Email: sagacious@sagacious-tech.com dot2.jpg Email: nancy@sagacious-tech.com
Posted on Dec 16, 2008
    Genius:
  • 1,199 Answers
This part is not sold in as by itself and you will need to buy the whole inverter board!
Posted on Dec 17, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, You could do either of these. 1. You could contact this person  robcomp@suddenlink.net
who claimed that he has this cable in one of the forums.
2. Contact Dell http://supportapj.dell.com/support/edocs/monitors/E173FP/En/appendix.htm
or else, get a similar broken LCD from ebay and salvage the cable.
    Brigadier General:
  • 5,158 Answers
Try here for that cable.
http://www.digikey.com/
Robert
  • 449 Answers
Hello, the ribbon can not be repaired, you will need to replace the ribbon by buying another one. you can notify us when you are ready to get a new ribbon so that i can give you the link to shop online for a good ribbon.
  • Obiora Micheal
    Obiora Micheal Dec 17, 2008
    you need to be patient because if you cant get it from the dell stores and still you can get it online you will need to visit a computer hardware vendor/ repairer who have thesame monitor but the monitor is completely damaged so that he can repalce it for you. but it is going to be expensive.
  • 275 Answers
Buying a brand new interter board would cost you 39.99 or 49.99 including the cable.
    Genius:
  • 1,011 Answers
Sir,
check this link
if it is not worked, better to replace the whole board.
thanks
good luck
    Master:
  • 416 Answers
This site might be helpfull
Good Luck
http://www.indexworldwide.com/dell-spare-parts.html
    Genius:
  • 1,142 Answers
Use a tweezer..remove the contact from connector and then rejoin it
  • 112 Answers
Hi wellcome to fixya
well dear hit up this link i hope you will find your slovetion
http://www.lcdrepair.us/e173fpf-logic.html
  • 10,515 Answers
If u wanna replace inverter board and cable,
refer
http://www.lcdrepair.us/repair.html
Thanks.
  • Dell Master
  • 19,396 Answers
The seller below sells the replacement ribbon cable:
ShopJimmy.Com
  • 3 more comments
  • Ginko
    Ginko Dec 16, 2008
    The part is quite difficult to find, Contact andrea.zhoug_linksequipment@yahoo.com
    or
    Waltercastle@hotmail.com
    Check if they still have in stock
    Or contact HP to get the part, see: Contact Us page
  • Ginko
    Ginko Dec 16, 2008
    Try also techcomp@sbcglobal.net, note that E221612 is the part number for the HP touchpad ribbon cable, and not the LCD.
    It will be useful knowing the laptop full model rather than the model number only.
  • Ginko
    Ginko Dec 16, 2008
    I know what it is , it is the LCD ribbon cable
    It would be easy if we got the model, part number you gave is for a touchpad cable.
    Here is the LCD cable for HP PAVILION DV1000 - 14.1" LCD SCREEN CABLE This is instead Display Inverter Cable that powers the inverter.
    Let me know if model is correct, and what part you need.
  • Ginko
    Ginko Dec 16, 2008
    I wanted to know the model, if this is a Dell, like in title you find the part at Dell - Replacement Spare Parts & Upgrades
    If it is an HP, as the part number you gave returns an HP part, contact: Contact HP parts page
    If it is a different manufacturer, please provide the exact model.
    Thanks
  • Ginko
    Ginko Dec 17, 2008
    You find the cable here: Dell - Replacement Spare Parts & Upgrades
    Contact them first, and possibly before answering to us.
    Give us feedback after contacting
    Dell - Replacement Spare Parts & Upgrades.
    Thanks.
    Master:
  • 479 Answers
Try radioshack websites for this replacement cables.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, is it with special bends,curves form? something like below
or straight like this image?
Pls try:
Good luck and Thank you for using FixYa. Happy Holidays.
No pic sound works
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electronicshelponline.blogspot.com/.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 26, 2015 | Samsung UN39EH5003 39 LED-LCD 1080p HDTV
Which model of Inverter Board does HP pavilion f1503 uses? My backlight keeps on dimming after 10 secs of start up. please be spefic with the model number
The part is a "ribbon cable" for an lcd monitor...ribbon made by Youngshin (AWM 2896 30V 80C VW-1).
2 ribbon cables for a hp pavilion f1503 LCD monitor (the two from the AD board to the TCP)
The LCD panel is made by HannStar (HSD150SX84).
Also, looking for other LCD parts, particularly:
the AD board for a Proview Pro-576 (I assume Sylvania PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
Jun 20, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Hello, I've been given a Sony Bravia KDL-26ML130 LCD TV which is not working but I believe it may have a repair solution (hopefully!). The TV powers on fine but the display turns off just a second...
This tv problems are those long board call the LCD inverter boards,it is dead.TV should have 1 or 2 long boards that call the LCD inverter boards it it dead,these 1 or 2 long LCD inverter boards only job are to provide a backlight to the tv LCD screen panel to have screen light produce a picture.Tries websites like Shojimmy.com,Ebay.com to buy those refurbihes 1 or 2 long LCD inverter boards for the replacment.
Jun 18, 2011 | Sony BRAVIA KDL-46SL14098 LCD TV
Picture come on for about 2-3 minute, then goes out has sound no picture, red light come on near power button
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board to get the picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 03, 2010 | Philips 60PL9200D Projection Televisions
When turned on, monitor power light comes on for a moment and then goes out. Monitor eventually comes on after several minutes. The same happens if the monitor is left on but goes into sleep mode.
This is a common problem on these monitors. There are three or four capacitors in the power supply, three on the inverter board and anywhere from 2 to 6 on the main board that go bad.
The number on the main board depends on how long the monitor has been having problems before it was serviced. The longer the wait, the more capacitors will have gone bad.
The power and inverter boards are easy to repair, the main board is not. As mentioned, it is a multi layer board so removing the old capacitors and the old solder can be troublesome. I would suggest you have someone experienced at soldering repair the main board.
Btw, our shop would charge $60 labour plus $2 for each capacitor.
Dec 18, 2009 | ViewSonic VP2030b 20.1" LCD Monitor
I am thinking about buying a used 65 sharp
I wouldn't recommend buying it unless it came with some type of warranty.
The most common thing you would be looking at for repairs if something goes wrong would be the Backlight Inverter Board or the Power Supply Board. It's what powers the big screen like that. Replacement board for one of them would be well over $200. And we're not talking about labor on top of that from the repair shop.
If you get it, try to get warranty with it. Add on extended warranty if possible.
Jun 04, 2009 | Sharp AQUOS LC-65SE94U 65 in. LCD HDTV
Flat Cable (P-Two AWM 20969 E221612)
Dec 16, 2008 | Dell E173FPf 17" TFT LCD Flat Panel...
Sceptre X30SV LCD display goes black with sound... Inverter? and other parts...
I too have the same problem...Searched and waited long time for parts. I have replaced everything and the thing still flashes and goes blank but has sound. Not worth anymore stress. My neighbor is an electrical engineer who I used to think can fix anything. He too is baffled. My fix suggestion... Getting a new LCD (not a Sceptre) tonight...with an extended warranty...Sceptre (and their tech's) no help if you don't have a warranty. I learned my lesson!
Oct 29, 2007 | Sceptre NagaIII X30SV 30 in. HD-Ready LCD...
Dell E173FPf 17" TFT LCD Flat Panel Monitor Logo
1,677 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
