Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
E30 error code
I have a Hotpoint Aquarius Ultima 1200 washer/dryer machine. It is showing a "E30 see manual" error code ,it will spin but stops with water still in it. Please help.
  • 2 more comments
  • benney35 Dec 27, 2008
    error code e30 changed brushes but sill have the prob
  • Rick M
    Rick M Mar 07, 2014
    Have same problem. Machine tripped main electric, now comes up E30 - motor error. As I understand it, the fuse on the power module has probably blown. I can't find this fuse - where is it? This seems like first port of call before / as well as changing brushes. Changing the brushes without replacing this fuse - if the machine has a fuse - makes little sense. The main circuit board seems ok, and the motor - no obvious signs of burning out, and as with the other comment, the spin works tho not the motor. Any tips on the fuse situation appreciated, I reckon I could change the brushes ok.
  • Rick M
    Rick M Mar 07, 2014
    Model is Hotpoint Aquarius Ultima 1200, serial might be: 016/3996/36
  • Anonymous Mar 31, 2014
    Machine not spinning no error code filter is clean no spin on dryer also
  • 135 Answers
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Posted on Dec 16, 2008
  • 750 Answers
Ned the complete model number!
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Ultima 1200 washer dryer. what does E30 mean
Hi .
E30 is a problem relating to the motor, check brushes, if o/k then could be faulty or broken tacho magnet on end of motor shaft, also check for broken wires in motor plug.
Please rate my solution.
Thanks.
Aug 04, 2009 | Hotpoint Aquarius WD63 Front Load...
I'm getting an E30 error code just after the first
Dear customer,
                     Error 30 (on Hotpoint) just means the motor isn't working. Several things, including the power module, can cause this. The most common cause though is worn carbon brushes. There is also a 7.5 amp fuse on or near the power module, which can blow. This fuse is on the motor circuit to protect the circuitry of the power module. If it blows, then the motor won't work and you will get error 30.
If it has blown, it's likely to be caused by the motor. I had one last week where the armature in the motor had shorted to earth which blew the 7.5 Amp fuse.
To check the brushes, with the machine unplugged! Have a look at
http://www.washerhelp.co.uk/spare-parts-shop/hotpoint-carbon-brushes-faq.html
http://www.washerhelp.co.uk/spare-parts-shop/Hotpoint-carbon-brushes.html
Plz rate this solution.. thank you..
Apr 09, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
I have a hotpoint aquarius ultima 1200 wm 72 but no users handbook where can I get one from
Goto;
www.hotpoint.service.co.uk
In the drop down list on left click on-----------hotpoint manuals , user guides, handbooks.
In the search box type in your model number, and download instructions.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Hotpoint Ultima WD72 Front Load...
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima 1200 Wm72 Erroe E14
I think you will find that the error relates to the heating element.
E14 on the Hotpoint WM75E means that there is a problem with the water heating.
Jun 05, 2008 | Hotpoint Aquarius WD63 Front Load...
I have a hotpoint ultima 1000 coming up with E30 problem. can you help, I do not have a manual.
Jan 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
1,219 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
