Question about Acer Aspire 5100-5022 Notebook
I dont know what really happened to my laptop.Its not the battery is no longer charging and i tried to use it without the battery but no eletric was supplied to it.
  • 68 Answers
Take a multimeter to the pin on the charger and check that it is still sending the correct current to the laptop. This problem is quite common. 90% of the time it is just a case of a new ac adaptor, if this does not work then it may be that the input jack has become loose and so is not making contact with the motherboard. You can fix this by taking of the case, taking the laptop apart and resoldering.
Posted on Dec 16, 2008
    Master:
  • 568 Answers
In this case i can say that you have check with your power adapter, if u change the adpater and if you still face the problem then there may problem with your motherboard, please get the laptop repaired
My laptop battery charge dont last long ?? Vgn-nr21j
if your laptop is longer than 1 year old is often that this happen. Try maybe more economic settings to brightness. Best you can do if battery is so important to you is to buy a new one. Dont forget to vote please.
Nov 01, 2010 | Sony Computers & Internet
Tip
Laptop preventive maintenance
After purchasing laptop when you are charging it first time take care that
power should not be absent meanwhile. If so happens after 80% charging then it always charge upto 80% offenly. Dont spill a water or tea on keyboard.Dont leave laptop in alone without lock dont put it in a conjusted place always keep open to free air dont expose it to sunlight, dont place laptop near loud speaker keep laptop away from magnet it destroys the laptop discharging of a battery is very essencial take the back up always
keep it always far from dust
on Feb 28, 2010 | Computers & Internet
My HP Pavilian laptop puts itself to sleep when it is not set to do this - It happens without warning - whether it is plugged into power or running on a battery that is charged Ok - Could this be related...
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
Do this outside with glasses on. .
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
Also If you dont already have one get a good 3 fan laprtop cooling pad, preferable one that has its own power sumply.
Never run laptops on sift surfaces as the act like a mini vacum cleaner and **** up more debris. and overheat a lot quicker.
Oct 04, 2009 | Computers & Internet
My Toshiba Satellite A10 S100 Laptop will not turn on. I've tried takeing out the battery for a minute & putting it back in but it still doesn't work. There is a orange light below the "power" icon...
It sounds like the power supply inside has gone bad. If its not under warranty it will most likely cost more to fix than its worth.
Try running it without the battery and just off the AC power....if that does the same..I'd say start looking for a new one.
Aug 27, 2009 | Toshiba Satellite A10-S100 Notebook
My acer laptop 4736Z's memeory dumping problem
HELLO..if you convert the memory and it is you experienced these problems may be the memory you bought is not compatible with laptop, can the FSB memory is high and the laptop is low and they do not match the FSB, or try to install a new OS / windows...GOOD DAY
Jul 28, 2009 | Acer Aspire 3690-2196 Notebook
Laptop computer won't turn on...
this is ur battery problem so just get ur baterry cheked
Jun 25, 2009 | HP Compaq Evo n610c Notebook
An unable to charge sign came up and i dont know what to do.
This usually happens when the battery is no longer being charged properly. It can either be the charger or the battery.
Note: these messages happen frequently when not using oem chargers or batteries.
Apr 08, 2009 | Motorola Mobility L6 Cellular Phone
Charging Problems with FUJITSU SIEMENS AMILO PRO V2055
SOunds to me like the charge board inside the laptop has gone bad. If it will not run off of the mains supply without the battery and will not charge the battery, this is your problem. AS far as where you can get the parts or have it repaired. I am unsure of because I would need the full model and make of the laptop which didn't fit in the listing title bar above If you could send me more info, I would be glad to try to help.
Dec 30, 2008 | Computers & Internet
Acer 4520 light going dim
Normally the way it works is if you plug in your AC Adapter to a laptop the computer screen will Brighten up since its no longer running off of battery and is actually charging . The reason why it should go dim is when you unplug the Ac adapter it goes dim to save battery life and last longer. If you are getting a really dim you can check and make sure that the Ac adapter jack on the adapter or motherboard isnt loose and it could be having contact to the unit and be loose inside and every small movement causes it not to charge / charge in and out and would cause this Dim effect. Again this depends on how old the computer is and I dont really think its the LCD or backlight going bad but you can try to mess with the screen brightness and If im not mistaken on that model it should be the FN key and the Right > and Left < Key for lower and higher brightness. Give that a try and check the adapter connection and you can pin point the issue . Hopefully it doesnt come worst to worst which could be a bad LCD going bad or damaged lcd internal cable. Hope my answer helped guide you closer to a solution.
Aug 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
AnyOne Know anything about batteries?
Try reinserting the battery. of nothing happens, then most likely you need to replace your battery as the circuit inside the battery might be fried already.
Apr 02, 2008 | Dell Latitude D620 Notebook
Acer Aspire 5100-5022 Notebook Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
