Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Inverted drives My problem is that my c drive become d drive and d drive become c drive! On my d drive is operation system. How to fix it? helo please...
  • 112 Answers
Well dear it not a big problem
don't worry
system will work properly when you need to install a new win then you make win in c drive
Posted on Dec 16, 2008
  • 68 Answers
Hi, this is easily fixed, however you may have to re-install the operating system if your windows installation is on one of these drives:
In windows xp:
To start Disk Management:
  1. Log on as administrator or as a member of the Administrators group.
  2. Click Start, click Run, type compmgmt.msc, and then click OK.
  3. In the console tree, click Disk Management. The Disk Management window appears. Your disks and volumes appear in a graphical view and list view. To customize how you view your disks and volumes in the upper and lower panes of the window, point to Top or Bottom on the View menu, and then click the view that you want to use.
This will allow you to change the drive letter if you right click on the drive and click on change drive letter - you will need to change them both to drives which are not C or D before you can make them the right way around.
The same can be done on Vista by right clicking on my computer and the manage, then disk management on the left hand side, using the same method as above.
How to fix the inverted camera?
see if camera has a tightening know to its clip OR support braket, loosen while viewing, flip over and re-tighten
Jun 27, 2014 | Microsoft Windows 7 Ultimate for PC
Tip
Reasons why Hard Drives fail.
A hard drive's file system may become corrupted or damaged due to a virus or software malfunction, but this is not a true drive failure because in most cases you can reformat the drive and reinstall the operating system and everything is back to normal. Hard drives fail due to a malfunction in their mechanical or electrical components.
The following picture illustrates the major components inside a hard drive:
The following is a list of the most common mechanical failures that can happen.
1. The spindle motor can malfunction. The spindle motor works much the same way that cd-rom or dvd player spindle motor works and is located in the middle of the hard drive platters. In a hard drives case, it's job is to spin the platters.
2. The read/write heads malfunction or the actuator arm malfunctions and prevents the read/write heads from reading the data stored on the hard discs (the platters). The picture below shows a closer view of the platters, actuator arm, and read/write head.
3. The hard discs themselves can become damaged by rough handling (dropped) or can in some cases become scratched by the read/write heads if they touch the disc.
4. On the back side of the hard drive case you will see where the cable and power supply plugs in and you will also see where the jumpers are. These contain small pins and can easily be bent or broken.
5. Another problem that can occur is the cables and ribbons themselves become loose and do not make a proper connection or the cable themselves can become damaged. The power cable can also become damaged or malfunction.
Picture of an IDE cable.
Picture of a SATA cable.
Hard drives can also fail due to malfunctioning or damaged electronics on their circuit board.
The most common electrical components to malfunction are Transistors, Capacitors, and Resistors. Power surges are the common cause of these small components to fail, so remember to make sure you are using a good surge protector or a UPS system for your entire computer system. A good policy is to always unplug your computer system from outlets when a storm is capable of producing lightening. It is also important to remember that if any of these failures happen, it will be cheaper to replace the drive for a new one. You can return a hard drive to the manufacturer to be fixed if it is still under warranty. Read your documentation and warranty information carefully if you purchase a new hard drive to upgrade/replace your old one.
The following picture is an illustration of where the hard drive is located inside the computer case. In this case, it is a SATA hard drive.
on Jan 10, 2010 | Computers & Internet
The colors on my laptop's screen are inverted, how can I fix this?
Both OS X and Windows have inversion options for their displays. Their meanings, on the other hand, differ with the operating system. An inverted display on Windows refers to the display actually being upside down, while an inverted display on the Mac refers to the colors being inverted. Either way, these options can hinder the use of your computer, for obvious reasons. Luckily, an inverted screen can be fixed quickly, on both Windows and OS X.
Right click on the Desktop and select "Properties." Click the "Settings" tab and then select "Advanced." Click the "Driver" tab and then "Graphics Properties." Press "Display Settings" and uncheck the "Enable rotation" option. Click "Apply" and then "OK." On Mac OS X Click the Apple logo in the upper left hand corner of the screen. Scroll down and select "System Preferences." Select "Universal Access" and click on the "Seeing" tab. Check the "Black on white" option and the display should return to normal. Close System Preferences to save the changes.
Feb 28, 2013 | Dell Latitude D820 Notebook
Helo sir,the data of pen drive are not delating why?
the files might be write protected or you dont have administration rights on your computer to delete the data from your pen drive
if you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
if you need any more help with this post a reply
hope this helps you
Aug 09, 2011 | Computers & Internet
Helo sir, my dvd drive suddenly disappear from my computer which is a windows vista laptop
Please go to Control Panel->System->HW->Device Manager and click on Actions->Scan for new HW. It should be able to locate the DVD drive and load its drivers. Once drivers are loaded then the drive will be functional. Generally the drives are press fitted, ie, you can pull them out of the laptop casing. Then press fit again after cleaning the connectors. And then see if the drive is detected.
Jul 06, 2011 | Computers & Internet
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
MSI U135DX notebook has become infected by viruses I now have a blank screen that says Missing operating system_ How can i fix this
i have a msi u135DX notebook my daughter was using it and now only the mouse pad works and keyboard doesnt is it possible to lock keyboard
Jan 31, 2011 | MSI Computers & Internet
My compaq presario F700 laptop displays ''operating system not found upon start up. What does this mean an how do I fix this?
When I see this message, there are two very common reasons for it. The first being that the hard drive has failed and needs to be replaced. The second being, the hard drive has become loose and dislodged from its mounting interface.
Jan 07, 2010 | Computers & Internet
My Acer Aspire One A150 screen is damaged and in inverted colours
"I got somebody to replace the screen for me and it was working until now" this more likely affects your warranty as the warranty seal is tampered..
What did the guy do to get it right did you replace something or just got it serviced..??
I don't user acer but my friend had problems with his lap DVD drive n got replacement. It took 2 weeks though
Sep 05, 2009 | Acer Aspire One PC Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
