No power Hi there we have a 3 year old servis 1100rpm washing machine. We first noticed it did not spin, then suddenly no power at all, no noise, no lights, nothing. We have replaced the fuse in the plug, and replaced the door switch, still nothing, yet when we bypass the switch, i,e, make a connection to the 2 out of the 3 wire plugs that go into the switch, it works. Any ideas? Thanks Elena
  • 135 Answers
This is a lack of neutral feed to the door switch. The feed comes from the circuit board which is where the fault lies. However if fitting a new board i would advise replacing door switch as it was probably the initial cause.
Hope this helps & thanks for using Fixya.
Posted on Dec 16, 2008
Won't spin gw608u
Fault code 41 if those are the correct lights. Service manual says faulty temperature thermistor & change the control module. Good luck with that as that model is nearly 20 years old and I don't think F&P supply that module any more.
May 02, 2017 | Fisher and Paykel GWL11 Top Load Washer
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kenmoore washing machine no longer spins during normal wash cycles
sounds like your spin cycle belt has come off or broken. it,s a simple fix at a repair shop.
May 02, 2009 | Washing Machines
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
I have a servis easi logic 1500 washer dryer....i do a lot of loads daily and just all of a sudden my washing machine is not spinning or draining amy water ....it was flowing out of the bottom of the...
HI THIS SOUNDS LIKE IT COULD BE THE CARBON BRUSHES IN THE MOTOR SO YOU NEED TO CHECK THEM OR GET SOMEONE TO DO IT FOR YOU IF THEY ARE LOW (APPROX 5MM LONG OR LESS) THE MACHINE WILL TUMBLE BUT WONT SPIN IF THEY ARE LONGER THAN THAT THOUGH IT COULD WELL BE A CIRCUIT BOARD PROBLEM WHICH UNFORTUNATLEY IS A COMMON PROBLEM WITH THIS BRAND IF THIS IS THE CASE BE PREPARED TO SPEND A LOT OF MONEY ON A REPAIR AS THEY ARE EXPENSIVE!
Jul 30, 2008 | Washing Machines
Miele w828
Hey you! I want to Miele w828 Final Spin Cycle 1100rpm Part 1/3 of 3/3 Part 1of3/3 of 3. Do you understand? Great Now let get to work.
May 24, 2008 | Washing Machines
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
Dobby
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Servis washing machine
the bushes might look ok but they only last a year and a half tops thats wat it sounds like to me if it cant spin right
Mar 03, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
154 people viewed this question
Top Washing Machines Experts
