I am using Norton Antivirus 2005 with windows XP. A couple of days ago my I started having some problems with my ISP (I use Bell Sympatico service). Apparently they were making some changes to their servers. Now my Internet and email is working but I am having some problems. First, there are certain websites that I am not able to access. I get the following message: Internet Explorer cannot display the webpage Most likely causes: • You are not connected to the Internet. • The website is encountering problems. • There might be a typing error in the address. What you can try: Diagnose Connection Problems More information When I go to diagnose the connection problems it tells me: “Windows cannot connect to the internet using HTTP, HTTPS, or FTP. This is probably caused by firewall settings on this computer. Check the firewall settings for HTTP (port 80), HTTPS (port 443), FTP (port 21).” I have my windows firewall turned off so I no it isn’t a problem with that one. I have tried to run my Norton Antivirus and I get the following message: Norton Antivirus Scanner Module has encountered a problem and needs to close. We are sorry for the inconvenience If you were in the middle of something, the information you were working on might be lost. Please tell Microsoft about this problem. We have created an error report you can send to us. We will treat this report as confidential and anonymous. To see what data this error report contains , click here Have also seen the same message but with a Symantec Integrator
  • 6 more comments
  • katzmen Dec 16, 2008
    When I do this the IP address starts with 192.168.1.100
    Ok...came back:
    pinging www.1.google.com ( 72.14.205.103) with 32 bytes of data and then listed 4 replies after that with ping statistics indicating- sent 4, received 4, lost none.
    Ok...I did your first two steps and everything seemed to come back ok- found the local area connection and the properties indicated for both the top and bottom that it was set to be "obtained automatically".
    I am using Internet explorer as my browser.
    Event viewer for today:
    Today's System Errors: There are many of the first one I indcate below and one of the second
    Source, Category, Event, User, Computer
    DCOM, None, 10005, HP_Owner, YOUR-F78B...
    Windows, Update Agent, Software, 16, N/A, YOUR-F78B...
    Today's Security Errors: There are none
    Today's Application Errors:
    Application Error, None, 1000, N/A, YOUR-F78B...
    Application Error, None, 1001, N/A, YOUR-F78B...
    Application Hang, None, 1001, N/A, YOUR-F78B...
    Application Hang, (101), 1002, N/A, YOUR-F78B...
    Thats all of them for today. Thanks for your help!
  • katzmen Dec 17, 2008
    When I click on the LAN settings as described none of those options are selected (ie. both automatic configuration and proxy server have nothing selected).
    I believe it is Internet explorer 7 (but I am not positive- I am not sure how to check for this).
    When I copy and pasted it took me to the google website.
    I always thought I was running Norton antivirus (since 2005- and have regularly run live updates and updated my virus protection yearly). However, the icon for this does say Norton Internet Security..and when I try to access it I get that first message I put on :
    "Symantec Integrator has encountered a problem and needs to close. We are sorry for the inconvenience.
    To see what data this error report contains , click here"
    When I do click on it, it gives me the following error signature:
    AppName: nmain.exe AppVer: 103.0.2.10 ModName:ascompbr.dll ModVer: 2005.1.2.6 Offset: 00009179
    It also gives the option to view the technical information about the error report. When I click on this it lists a large number of nodules and numbers, threads, and stack numbers. I have sent this error report off to Norton several times but not sure if it is doing anything.
    The only other Firewall I have is the Windows Firewall but I have this turned off. The only other virus/spyware I run is spybot.
    Thank you again for all your help
  • Chase May 11, 2010
    Interesting, so you are resolving with pings but you can't browse..your results show dns is resolving correctly to some degree atleast. Lets take a look at Internet Explorer and see if for some reason you have a proxy server set up.
    • Open Internet Explorer
    • Choose Tools
    • Click Internet Options
    • Click Connections
    • Click Lan Settings
    Are any of those options populated with data? Are you using IE 5,6,7 or 8?
    Just for fun copy this: 72.14.205.103
    and paste it into your IE browser and try to get to it.
    Do you have Norton Internet Security or just Antivirus? Do you have any other Firewall programs such as Zone Alarm or Komodo? If everything checks out here I am going to have you run a Winsock fix - which I will explain once you post back if required.
    Alright so lets move on. There are plenty of things to look at here but lets go over them one at a time. To start lets check your Network Connections settings to ensure everything is configured properly.
    • Click Start
    • Settings (Or Control Panel if you don't see Settings)
    • Open Network Connections
    • Click View
    • Choose Details
    You should see Local Area Conection and unless you have wireless or blue tooth/vpn installed it might be your only connection.
    • Right click on Local Area Connection (Status should say Connected) and choose Properties
    • Locat Internet Protocol (TCP/IP) and select it
    • Click Properties
    Are both the top and bottom selections set as Obtain automatically? If not what's listed?
    Before we dive into your IE and system settings, what browser are you using?
    Last but not least for this post lets take a look at your event viewer.
    • Click Start
    • Choose Run
    • Enter eventvwr.msc and hit OK
    Here is where it gets a little sticky as there are a lot of options from here that could possibly be important. Click on System and notice the date, scan through today and look for anything that is the Type ERROR. Record them and post them back here, do the same for Security and Application. Do them only for today though, no reason for you to go back to far just yet.
    Ok good we clarified you have an IP address from your router, lets see if your machine is able to send a basic response request to an external website.
    • Click Start
    • Run
    • Type in CMD and hit OK
    • In the window type Ping www.google.com
    If you have access to the internet you should get a reply and we can continue troubleshooting the machine. If you get no reply we will need to take a glance at your router and verify that its functioning properly.
    Click start, choose run, type in CMD and hit OK. In the window that opens type in IPCONFIG and hit enter. Do any of your Local Area Connections have an IP Address that starts with 169?
Turns out the whole problem was related to my version of Norton (which I have run/updated without problem since 2005) suddenly becoming defective. Once I removed Norton with their remove tool on the Symantec website everything worked fine again. Thanks for your help
Posted on Dec 19, 2008
Cannot sign into my yahoo account or sympatico account
Call your ISP (Bell for your SYMPATICO account) and get them to reset the password.
Yahoo has a "forgot my password" link on its "login" page.
Click that link, and follow the instructions.
Mar 13, 2014 | Computers & Internet
Norton Antivirus 2009
You can download the latest version of Norton Antivirus 2011 from the link www.norton.com/nav11 and install the program.
Once the installation is complete, it will ask for the product key, please enter the product key to activate the program.
regards,
Muhaim.
May 31, 2011 | Norton AntiVirus 2005 Retail Box...
I cant open my norton anti virus to type in my product key
How to Activate Norton Antivirus
Step 1:
Uninstall any previous versions of Norton AntiVirus before installing and activating a new version. To do so, click the Windows "Start" button and then "Control Panel."
Step 2:
Double-click "Add or Remove Programs" (Windows XP) to open the "Programs" window. Windows Vista users should instead double-click "Programs and Features."
Step 3:
Find the Norton version you have installed in the list of programs and click "Remove/Uninstall" in Windows XP or "Uninstall" in Windows Vista. Click "Restart Windows Now (Recommended)" when the program removal is complete.
Step 4:
Insert the Norton AntiVirus installation CD into the CD-ROM drive, or, if you downloaded the program from the Internet, double-click the installation file. Click "Install Norton AntiVirus" when the installation wizard opens. Click "Install Options" and click "Browse" if you want select a different location than the default for the program.
Step 5:
Click "User License Agreement." Read it and click "Close" when you are done. Click "Agree and install" to begin the installation. When the installation is complete, Norton AntiVirus will launch automatically.
Step 6:
Click "Activate Now" on the bottom-right corner on the Norton AntiVirus program window. Type in the product key and click "Next." The product key is usually on the installation disc packaging. If you purchased and downloaded the program from the Internet, Symantec will send you an email with your product key.
Step 7:
Type in your email address and click "Next." Type your password if you have a Norton account. Complete "Create a Norton Account" if you do not have an account and click "Next."
Step 8:
Review the subscription details and click "Done" to complete the activation.
Feb 24, 2011 | Symantec Norton AntiVirus 2005 for PC
I am using windows xp, i need free symanticantivirus, plaese give me the validlink for download the symmantic
you don't need Symantec Norton Antivirus 2009,Symantec is garbage download free avg or avast and spybot 10xs better then symatic
Sep 02, 2010 | Symantec Norton Antivirus 2009 1-User -...
How to uninstall the norton product
please go ahead and download www.symantec.com/nrt ,tool and run this tools and after running this tool please restart the computer and it will remove the norton products completely out of your computer
thanks....
Nov 18, 2009 | Symantec Norton AntiVirus 2002 8.0 for PC
Cant install norton
today quick heal is most successs antivirus if you want to install
Downlaod from here
http://download.cnet.com/Quick-Heal-AntiVirus-Plus-2009/3000-2239_4-10838310.html
Tehn update it from internet .
Then scan boot time.
Jun 23, 2009 | Norton Internet Security 2005...
Norton antivirus product key
buy the product, or if you did then contact norton for the product key if you have lost yours. www.norton.com
Mar 23, 2009 | Symantec Norton AntiVirus 2005 for PC
Norton Internet Security 2008 installation problem
Norton antivirus chat Number~ 1*8OO*289*6717 Norton internet security phone number, Norton Technical support Phone Number Norton Support Number/ 1*8OO*289*6717 Norton Technical support Phone Number Norton Support Number/ 1*8OO*289*6717 Norton Technical support Phone Number Norton help desk number, Norton internet security phone number, Norton internet security customer SUPPORT Norton internet security customer SUPPORT phone number Norton internet security help phone number Norton internet security phone number customer SUPPORT Norton phone number customer SUPPORT Norton phone number customer support Norton phone number Norton phone number Norton customer service Norton support phone number Norton customer service phone number Norton support Norton contact Norton technical support phone number contact Norton Norton contact number Norton customer support phone number Norton customer service number phone number for Norton support number Norton number Norton technical support number Norton telephone number Norton technical support phone number for Norton customer service Norton helpline number Norton phone support Norton help desk phone number. Norton 1800 number Norton phone telephone number for Norton telephone number for Norton customer service contact Norton customer service phone number Norton help phone number Norton customer care number Norton telephone number customer service Norton helpline number for Norton contact Norton by phone Norton phone number support phone number Norton customer service number for Norton Norton customer care phone number Norton online phone number Norton customer service Norton customer service telephone number Norton support telephone number Norton customer care Norton help number Norton australia renew Norton Norton problems Norton customer service helpline number Norton contact details Norton for phone contact Norton customer service Norton renewal Norton account call Norton customer service online Norton Norton help desk Norton help desk number www Norton antivirus, Norton 360 support number Norton customer phone number Norton 360 phone number Norton mobile technical support for Norton Norton technical support telephone number Norton removal tool Norton install how to install Norton Norton 360 customer service phone number Norton for mobile Norton USA+ 1*8OO*289*6717 Norton toll free number Norton troubleshooting Norton sale reinstall Norton Norton phone number customer service us Norton customer service phone number. Norton Support Number 1*8OO*289*6717 Norton Technical support Phone Number........
Feb 03, 2008 | Norton Internet Security 2005...
Admin issues with Windows XP
First install: NORTON REMOVER
Then Make a New account on your System
Dec 27, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
374 people viewed this question
Alun Cox
David Payne
David Payne
