Question about DeLonghi Microwave Ovens
DELONGHE AC930AMQ MICRO/OVEN. THE INSIDE LIGHT HAS BLOWN, HOW CAN I RPLACE IT, I'M NOT SURE WHERE IT IS LOCATED. TONI.
  • DeLonghi Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Dec 17, 2008
Jenn-air combo micro and oven
need to open the unit up and look for a fuse to be blown..
Jan 08, 2014 | Microwave Ovens
Micro oven Does not operate at all. When the door opens the light is on. We put the stuff to be warmed up inside, close the door. Then click time and start,it does not start.We are in East Marredpally
there is usually a fuse inside which could have blown but they are hard to get to however if the light is on I would guess it's a problem with your doorsendor that tells it the for is closed. not a hard fix but sometimes there are safety screws on theshell
Dec 27, 2011 | Microwave Ovens
It's completely dead?? Not sure what happened. Power supply is fine.
Microwaves that suddenly loose power could have many causes with the easiest being a blown fuse inside the cabinet of the oven. To check for this unplug the unit and remove the screws that hold the cabinet in place. Be sure to not touch any of the electrical components inside to avoid shock. Visually follow the path the power cord takes as it enters the unit. The fuse ( usually clear glass with metal ends and cylindrical in shape ) should be located not far from where it enters the cabinet. Once located use a fuse puller or other means to carefully remove the fuse to check the element inside. If the fuse is blown take it to a hardware or electronics store for replacement. These fuses are cheap as this has happened to me before. Good luck!
Jun 19, 2011 | Whirlpool MH6110XE Microwave Oven
Micro wave simply quit. How an I check to see if
The fuse is located inside the microwave. You will need to remove the front panel to get to it. It will be located on the black power wire inside the microwave and installed inline. Make sure that the microwwave is unplugged before removing the front panel. Once you locate the fuse inside you will need to remove it and test it with a continuity tester to see if it is blown. If it is make sure you replace the fuse with the same amp rating you found. If the new fuse blows again then there is an electrical short somewhere inside the microwave.
Dec 24, 2009 | Emerson MW8778 Microwave Oven
Micro wave won't heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 20, 2009 | Kenmore 62702 Microwave Oven
GE PROFILE PURCHASED 2006 RUNS BUT NO HEAT MICRO/CONV MODEL JEB1095BB
Sep 10, 2009 | GE JVM1630 Microwave Oven
Light inside microwave dos not illuminate
bulb to be replaced with same similer, if it is not available please get me touch, 9791055855, india, The bulb cost is Rs: 125.00
G.K.Mahendran
Aug 01, 2008 | GE JVM1340AW/BW/WW Microwave Oven
Delonghi AC930AMQ Microwave, Interior Light Bulb
The bulb is usually run by one of the door switches, but in some cases they are run by a relay on the board.
I would suggest you look over our files on safety & door switches here:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/doorsw.txt
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | DeLonghi MW 605 Convection/Microwave Oven
Light bulb replacement in a Tappan Microwave
Hi Mike.
Difficult to say on yours. You may try the following. On the back or side, if there is a little cover that's screwed into the panel. Otherwise browse around on the inside. Be sure to unplug the micro before checking. Once found be sure to replace with a microwave lamp and not a fridge lamp. There is a difference. Good Luck,JUS004
Feb 28, 2008 | Microwave Ovens
Fridgedaire stove top micro oven
Blown 20 amp fuse inside the cabinet. You could try just replacing the fuse, but experience on these says that it blew out for a reason. Something has shorted out inside the cabinet; magnetron, transformer... I highly recommend contacting a local appliance repair company and have them come diagnose this for you. They'll have to remove it from above the stove to gain access for diagnosis, big job! I know this is not what you wanna hear, but they are trained on these and have the necessary tools for removal and proper diagnosis. (plus, if they mess anything up getting it down from there... they are insured) To make things go faster, remember to tell the dispatcher that it's an over the range microwave... this way, the tech will be sure to bring the necessary tools on the first trip.
Sep 25, 2007 | Frigidaire PLMV168 Microwave Oven
Microwave Ovens Logo
133 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Steve Mason
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
