Question edited for all the typos and add Maker.
Please don't type in all CAPS, it is considered SHOUTING and harder to read.
Fridges don't like being moved. If it stays upright the whole time, leaving 2 hours is fine. If laid down, they need 24 hours for the refrigerant and oil to settle.
It sounds like there is a bad connection on the display, so take it apart and check or call for service.
I own the same PRW-2500-1A (all black).Check if under the hours reading, PS appears.If yes,power saving function is activated.
Normally, Power Saving Function is enabled automatically (if activated) if the watch stays in complete dark for sometime.If after a couple of hours in the dark the watch comes suddenly under bright light,the display goes on immediately.Hour interval (10pm-6am) has nothing to do with Power Saver.
Try the following:
a)Deactivate and reactivate (or vice versa) the PS.
b)Leave the watch in the dark for a couple of hours .Then,still in the dark,try,using a very low power light (just that you can,barely read) to check if display is blank.If not you may have a problem with the light sensor found at the bottom of the display.Will be a very rare case but you have to take the watch to a CASIO authorized service.
Ron, You're right to be concerned but I'd just keep an eye on it for the time being - if it ain't broke, don't fix it!! It's entirely possible that it's throwing a hissy fit after the power outages and it just needs peace and quiet so it can settle down!
Hold down the feed button on the front of the printer for a few seconds and watch for the contrast on the LCD panel to start changing. Keep holding it down (screen will cycle continuously from light to dark until you let go) until you get to the desired contrast then let go.
Hold down the Menu button on the front of the printer for a few seconds and watch for the contrast on the LCD panel to start changing. Keep holding it down (screen will cycle continuously from light to dark until you let go) until you get to the desired contrast then let go.
hi try this
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
You can either change the image darkness level on the printer or through the printer drivers.
on the 525 control panel, you can go to the setup menu, and search through it until you see image darkness, select it, and change the values, go up or down by 10 points at a time.
in the printer drivers, go to printing preferences, and there is a tab that will have image darkness in it.
