Question about Refrigerators
I have a topdown maytag refrigerator. The light to change the filter was glowing. I repalced the filter. Initially there was a weird noise when I tried to get water. After few seconds, the noise stopped but the water is slowing very slowly. Any suggestions??
  • priyam_vinod Dec 16, 2008
    Thanks You, as soon as I get home I will check for bad seal or 0-ring.
    The filter is compatible as I got it from Maytag technision the last time I changed the filter.
    Thanks for posting.
  • 26 Answers
Double check that the filter is compatible with your model, if so remove and reinstall the filter, usually they will only insert one way but...some model filters or universal filters can be wrongly inserted. also check any gaskets or o-rings at the connection as a bad seal or o-ring can crack and block the water flow or even just get out of place un-noticed and cause issues.
Posted on Dec 16, 2008
I changed the water filter and I can't change the red indicator light to green on the outside of the refrig. Help!!! Maytag side by side
AFTER CHANGING THE FILTER . YOU THEN HAVE TO HOLD DOWN THE LIGHT BUTTON AND THE LOCK BUTTON AT SAME TIME FOR APPROX 3 SECONDS AND THE FILTER LIGHT WILL FLASH THEN GO OUT
Dec 05, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
NO manual for Fridge.
I can get the service manual for you. Here is what the manual tells you on page 101.
WATER FILTER CHANGE REMINDER
(Select Models)
For some refrigerator models featuring
water filters, the Water Filter Change
Reminder function monitors the life of the
filter and provides a reminder when it is time
for the filter to be changed.
When the system detects either 12 months
of usage, or the filtering of 416 gallons of
water (whichever comes first), the CHANGE
FILTER
indicator light will illuminate. This
indicates that the water filter should be
changed and the light reset.
To reset CHANGE FILTER light: Press and
hold the LIGHT and LOCK pads until the
CHANGE FILTER light blinks (approx. 3
seconds). The control is now reset for 12
months or another 416 gallons.
Thanks, Sea Breeze
Jan 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag msd2454gr refrigerator how turn filter light off after replacing filter?
FILTER
Note: The Water Filter Reminder will
operate if the filter bypass is in place.
Nov 23, 2009 | Maytag MSD2454G Side by Side Refrigerator
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
Change filter light
you have to hold if my memory is good the two light and lock switch for 3 sec.... (the infos are written on your new filter box..)
the light doesn't go out by it self.....you have to make the reset....
Jul 04, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
HOW TO TURN OFF THE "CHANGE WATER FILTER LIGHT"
Press light and lock and hold until light blinks release and the light will go out
May 02, 2009 | Maytag Refrigerators
How do I turn off the "change water filter light" on the door? I just changed the filter
Hold the lock and light buttons in together for 3 secs. or so and the light will go out! You don't even need to change the filter to do this.
May 02, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Maytag lock and filter change
to reset the change filter light:
Press hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 sec.)
Dispenser lock:
to interrupt power to the water and ice dispenser so it cannot be used , press the lock pad 3 times within 10 seconds.
Jan 21, 2008 | Maytag MSD2454G Side by Side Refrigerator
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
