Question about Weather King 12AJA6001AH Air Conditioner
Thermostat setting I just bought a new house and I have a heat pump-we live in North Carolina. The name on the thermostat is Braeburn and it is a multi-stage 2 heat/ l cool digital thermostat. We have it set at 68 and when the blower first comes on it blows warm air-however then it switches to cool air. And sometimes cool air comes out first. We have set both stages to 68 and it is in the heat mode. Should the 1st and 2nd setting be different?
  • 700 Answers
What i would do is see if the outside unit is working at all. when you first turn it on the air was warm due to the fact that the temperature inside was cooler than the set point. when it get within 2 degrees the unit shuts off the backup heat and your running on the hp alone. with both stages at the same temp you are running the hp and the electric heater and that can become very expensive. What I would do is make sure that the filters were clean and look at the outside unit and see if it has a red reset button on it, if it does reset it and see if the unit runs. If it doesn't then you need to call a quallified service person out to take care of the problem.
Posted on Dec 22, 2008
We have 2 furnaces in our house, both on the braeburn 3200 model thermostats.
If you have a dual fuel system - gas/heat pump the heat pump should lock out at around 41 degrees depending on what the outside lockout sensor is set at. It may be that both the heat pump and furnace could be running at the same time if the outside lockout isn't working or there could be a problem with the thermostat. Best bet would be to have a service tech check it out. However if you want to check it out here are the terminals Terminations: R,Y1,Y2,W2,E,G,O,B,L,C. W2, E and B are the heating terminals for 2nd stage heat and emergency heat. First stage heat, compressor Y1 with B (reversing valve on heat pump) energized together. 2nd stage W2 energized for gas or electric heat . No power to Y1 and B when W2 is energized if gas. E can be energized with Y1 and B if you have electric heat or if you switch over to emergency heat, E will be energized.
Feb 02, 2016 | Heating & Cooling
Has anyone heard that t-stat on 4045 is supposed to installed reverse of norm?
User Manual - Braeburn Systems
www.braeburnonline.com/sites/braeburn/files/.../1010_manual.pdf
cooling system control board to test the thermostat installation. This could ...configures the thermostat for normal (NORM NON-HP) heating and cooling systems.
Heat Pump Thermostat - HeatPump-Reviews.com
www.heatpump-reviews.com/heat-pump-thermostat.html
Search Results
    [PDF]User Manual - Braeburn Systems
    This thermostat should only be used as described in this manual. ... configures thethermostat for normal (NORM NON-HP) heating and cooling systems.
Jan 17, 2016 | Toys
Braeburn 1200 thermostat cool air blows out when set to heat
I have a feeling your thermostat needs replacing. Check and see if there is a little screw that you can set to increase the temperature on the thermostat.
Oct 24, 2017 | Heating & Cooling
I have a new Rheem heat pump. The cooling works fine but won't blow hot air in HEAT setting. I have reset the breakers for heat pump and air handler, changed filters and pulled batteries and reset the...
if this is indeed a heat pump you rthermostat should also have a emergency heat setting does it work on that setting... a heat pump on heat wuns the outside unit and has a recersing valve that changes the refigerant flow ..is the outside runnignduring heat mode... if you turn the thermostat in emergency heat the outside should shut down and indoor heat should come on...of this is not happening you have a wiring issue if both are not working... braeburn thermostats usually have behind the cover dip switches... i am not exactly sure what model this is but if indeed a heat pump the thermostat should have a r,w2,y,e,g,c,o,and b terminal... rheem wiring should be as follows
red to r white to w2 , g=green , yellow to y terminal there should be a wire hooked to the b terminal usually brown sometimes orange on the b terminal that is your reversing valve terminal.
you are going to have to make sure the thermostat is configured to energize the b termianl and will have to go into the installer setup to do this...hopefully you still have the paper work on thermostat... most heat pumps use the o terminal for reversing valve but rheem uses the b terminal
hope this helps out some repost with anymore probs...also make sure the switches are set to electric or gas whatever you have heat pump or not etc. inside thermostat
Jan 05, 2011 | Heating & Cooling
I have a Nordyne Model Number FEEB-012HA with 7 wires. And an old Intertherm Thermostat. (White wire goes to w2)(Black goes to x)(Red goes to R) (Green goes to G) (Yellow goes to Y) (Grey goes to O)and...
Hi, what you have done is they sold you the wrong thermostat, it will not work with your unit. You have a heat pump w2 is second stage heat, and 0 or b if for the reversing valve. The new stat you have has the red jumper wire from R-C to R- H, W is for gas heat, G is for fan, and Y is for cooling or compressor. Draw you a diagram with your colors and connections and take it back and have them match this with a heat-pump thermostat. Draw this out as they can be difficult to wire up. The one they sold you will never work.
Sincerely,
Shastalaker7, A/C, Heating, & Refrigeration Contractor
Aug 08, 2010 | Heating & Cooling
Thermostat auto-changeover mode unavailable
when you programed it did you go through all the setup #1-0 ,#3-0 ,#5-5 ,#12-1
Nov 24, 2008 | Honeywell Electronic Programmable...
Weather King 12AJA6001AH Air Conditioner Logo
210 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
